    LAN side gateway traffic problem
    6 Posts 2 Posters 1.1k Views
      gsmithe
      Hello all,
      I searched the forum and couldn't find this scenario already asked about.  I am replacing a watchguard branded firewall that routes all traffic with no problem.
      Pfsense 2.3.2_p1
      LAN: 192.168.1.1/24
      LAN_GW: 192.168.1.5 (routing to 10.0.5.0/24)
      I created a static route based on the above (and created the gateway). No policy based routing.
      I checked the box for "Bypass firewall rules for traffic on the same interface" option located under System > Advanced
      Checking the firewall logs shows that no traffic to / from 10.0.5.0 is blocked.
      I can ping and get successful traceroute results from my windows PC's to 10.0.5.10. I can bring up webpages on other 10.0.5.xxx servers. By all accounts, routing appears to work fine.
      We have a software package that connects using tcp 1600 on 10.0.5.10. This software times out when PFsense is in place. If I put the original firewall back in, all starts working in a few seconds.
      Software support says the logs indicate that the traffic is partially coming through, but appears to be cut off or blocked.
      Any help is appreciated.
      • GS
      • DerelictD Offline
        Derelict LAYER 8 Netgate
        Draw your network. Please be thorough.
        If you put a gateway on Interfaces > LAN that is almost certainly wrong. it needs to be defined in System > Routing, but not set on Interfaces > LAN.
        Chattanooga, Tennessee, USA
          gsmithe
          Thanks for replying.
          Under Interface-> LAN, I have no gateway.
          I have 2 attachments, the network diagram and the screenshot of my static route.
          ![2016-12-28 16_20_09-tpdpfsense.troypd.local - System_ Routing_ Static Routes.png](/public/imported_attachments/1/2016-12-28 16_20_09-tpdpfsense.troypd.local - System_ Routing_ Static Routes.png)
          ![2016-12-28 16_20_09-tpdpfsense.troypd.local - System_ Routing_ Static Routes.png_thumb](/public/imported_attachments/1/2016-12-28 16_20_09-tpdpfsense.troypd.local - System_ Routing_ Static Routes.png_thumb)
          ![2016-12-28 16_45_41-netdiag1.ndg.png](/public/imported_attachments/1/2016-12-28 16_45_41-netdiag1.ndg.png)
          ![2016-12-28 16_45_41-netdiag1.ndg.png_thumb](/public/imported_attachments/1/2016-12-28 16_45_41-netdiag1.ndg.png_thumb)
          • DerelictD Offline
            Don't put hosts on the same subnet as routers. that creates an asymmetric routing situation.
            Make a transit network interface on pfSense and put the router on that.
            Pass the traffic you need to pass from the downstream networks on the transit interface.
              gsmithe
              I appreciate your time on answering this.  The router @ 192.168.1.5 I consider to be a "black box" that I cannot configure and will receive pushback in that the old firewall worked just fine.
              I understand the asymmetric routing, though.  I will try to get the responsible party to change the internal IP of the additional router so I can put it on the firewall as a separate network.
              If they won't do that, then I guess it will be adding routes to each PC.
              • DerelictD Offline
                Or make a 192.168.2.0/24 interface and put the PCs on that.
                You can make it work but it's a crappy design and should just be fixed instead.
