    Difference between 2.4.0 memstick-serial & memstick images - and to ZFS or not
    5 Posts 2 Posters 2.1k Views
    • bingo600B Offline
      bingo600
      I just got my QOTOM-Q355G4 (Core i5) , and have it equipped w. 8G Ram & a 240G Toshiba SATA SSD
      I installed the "memstick image" yesterday , but had to use the "tv" as HDMI monitor , in order to use the console.
      That did NOT bring happiness @SWHMOB
      As there's a DB9 comport on the unit i was thinking about instaling the memstick-serial instead , and was wondering if it was the "same base image" , just using serial as console instead of VGA/HDMI.
      That way i could just connect a FTDI Serial adapter to the QOTOM, if/when i need a console.
      I was considering ZFS instead of the normal *FS , but the install procedure (correct selections) for a single SSD install is a bit confusing. And someone i know using pfense ,even mentioned his SATA SSD disk never had problems with corruption, and said ZFS would just complicate things.
      Any hints to the parameters needed for a single SSD ZFS install would be appreciated.
      /Bingo
      pfSense+ 23.05.1 (ZFS)
      QOTOM-Q355G4 Quad Lan.
      • U Offline
        uknownme123
        The serial version is the same, just using serial as console instead of VGA/HDMI. Keep in mind, if you decide to use the serial port on the QOTOM you need a null adapter for console access.Ā  You can install the VGA version and also enable console output in system settings, this way you get two outputs.
        • bingo600B Offline
          bingo600
          @uknownme123:
          That would prob be the way to go then , thanxĀ  ;)
          Any hints on the ZFS install , or should i just use the old FS ?
          /Bingo
          • U Offline
            uknownme123
            Sorry I'm not expert on file system. I would stick with what pfSense came with, less complicated. Did find this link, https://www.reddit.com/r/PFSENSE/comments/5lynkq/zfs_on_24/
            • bingo600B Offline
              bingo600
              Thanx
              I tried to write here
              https://forum.pfsense.org/index.php?topic=126597.msg721366#msg721366
              But received no ansver.
              I suppose i'd have to go with UFS
              /Bingo
