    Multi physical interface with same subnet
    44 Posts 7 Posters 10.4k Views
      jaf
      @johnpoz:
      The point is you can not have the same IP on the same network and expect it to work..
      Where did I say this can works???
      Sorry again if my explanations was not clear…
        You didn't - just pointing out this fact so everyone is clear ;)  How you create the different networks is up to you.
        • JKnottJ Offline
          JKnott
          @jaf:
          I think the problem is that my English is not so good, and my explanation not clear. :(
          Or maybe I'm an idiot? I hope not.
          And yes, I don't understand how it can be technically impossible to develop a VM integrating the 2 devices solution, and developing a special HMI to control all that. After, you call this VM "pfsenseMulti".
          Isn't this a heck of a lot of trouble to avoid the proper solution, that is change the IP address to a different subnet?
          UniFi AC-Lite access point
            Or even a different IP on the same subnet ;)
