    VPN point-to-point problem
    17 Posts 3 Posters 1.7k Views 3 Watching
    • federicopF Offline
      federicop
      Hi, I have a point-to-point VPN connection and everything works.
      That is, I can see the pfsense web interface remotely (of the two VPNs).
      just that I have a problem, I have a small nas with a web interface on the "B" lan that I can not reach and I do not understand why!
      LAN "A" 192.168.0.0 - PFSENSE 192.168.0.1
      LAN "B" 192.168.1.0 - PFSENSE 192.168.1.1 - NAS 192.168.1.2
      if from lan "A" I enter 192.168.1.1 I enter pfsense quietly but if I enter 192.168.1.2. I can not see the nas login page
      obviously inside the "B" lan typing the ip of the nas it works!
      what could it depend on?
      • N Online
        netblues
        Most probably nas doesn't have a default gateway, or has security that doesn't allow access from remote lans.
        Can you actually ping/access other hosts on B from A?
          federicop
          once I can access other hosts other times no!
          the Gtateways defoult was and the OpneVPN rules are ipv4 Protocol * source * port * destination *
          • N Online
            netblues
            What are the settings of the ipv4 local networks on the server configuration?
              federicop
              Server:
              WAN 192.168.1.2 - WANGW 192.168.1.1
              LAN 192.168.0.1
              Server OpenVPN
              IPv4 Tunnel Network: 192.168.4.0/24
              IPv4 Remote network(s) 192.168.2.0/24
              Client:
              WAN 192.168.1.3 - WANGW 192.168.1.1
              LAN 192.168.2.1
              Client OpenVPN
              IPv4 Remote network(s) 192.168.0.0/24
              • N Online
                netblues
                Seems ok. Check the nas for security settings. Can you ping it?
                  federicop
                  @netblues said in VPN point-to-point problem:
                  Can you ping it?
                  Yes
                  • N Online
                    netblues
                    If you can ping the nas, then pfsense configuration is ok. Probably the nas has some access list functionality.
                      federicop
                      the nas is ok. I have the same problem on other hosts that of switch management
                      • chpalmerC Offline
                        chpalmer
                        • chpalmerC Offline
                          chpalmer
                          Can you show your VPN firewall rules on both routers?
                            federicop
                            Client:
                            Server
                            OpenVPN Client
                            OpenVPN Server
                            • chpalmerC Offline
                              chpalmer
                              For your tunnel network you can use a /30 I usually like using something way outside my LANs.. 10.10.1.0/30 here.. but to each their own..
                              Your LAN on network A is now 192.168.6.0/24 ??
                              What is CimaVPN?
                                federicop
                                LAN A (Server) 192.168.0.0/24
                                LAN B (Client) 192.168.6.0/24 .
                                CimaVPN it's the name of my VPN
                                • chpalmerC Offline
                                  chpalmer @federicop
                                  @federicop said in VPN point-to-point problem:
                                  And that VPN relates to this scenario in what way?
                                  Is it directly associated with your OpenVPN connection somehow?
                                  Your screenshot above shows tabs for both on the same router..
                                    federicop
                                    • chpalmerC Offline
                                      chpalmer
                                      Are both of these routers on the same WAN router right now? Physically located at the same location?
                                      I see. I don't assign my openVPN connections to interfaces in that fashion myself so was trying to make sure.
