    problems unblocking my sip provider
    76 Posts 6 Posters 14.4k Views 4 Watching
    • randomaustralianR Offline
      randomaustralian
      there are heaps of states from that device... but it also runs other services from my provider. the IP address to the sip server shows up nothing.
      https://justpaste.it/4rnti
      2 x UP board, 4GB RAM + 64 GB eMMC w/ vesa case (http://up-shop.org/)
      1x UP^2 Pentium Quad Core, 8GB RAM, 128GB eMMC w/ vesa case (pfSense)
      1x UP Core Plus E3950, 8GB RAM, 64GB EMMC+ Net Plus i210-IT
      1x Dell Power Edge R510
      2x Dell Power Edge R610
        randomaustralian
        that wont work either because the information is not being sent to port 5060 at my end
        • chpalmerC Offline
          chpalmer
          Remember that when you make a change and it somehow registers then you have to sometimes wait for the registration to clear out of your providers server..
          One thing I had to do at one point was to turn on TFTP proxy on so that some of my devices could get their config files.. That one stumped me for a bit.
          But if it already has its file I wouldn't see that as an issue. If it has registered ever it should.
          Systemm/Advanced/Firewall&NAT twards the bottom.
          • chpalmerC Offline
            chpalmer @randomaustralian
            @randomaustralian said in problems unblocking my sip provider:
            Its coming from the firewall at that port. Thats a randomized port that the firwall does by default. Thats what the static port would stop.
              randomaustralian
              but the logs read like its coming from the source at port 5060 and arriving at my firewall on a random port
              • chpalmerC Offline
                Its trying to report back to where its told to go. If you do a static port that will change.
                • chpalmerC Offline
                  chpalmer
                  Do you have any WAN rules pointed at 10.0.0.150 now?
                    randomaustralian
                    i put it in as you had it in the picture and its "being ignored" i cant activate it
                    and no id didnt auto create a new WAN rule
                    • chpalmerC Offline
                      @randomaustralian
                      Create a WAN rule with source (their server) destination 10.0.0.150 any on the ports.
                      Put it on top of all your rules.
                      Log the rule..
                      Then if anything is happening between the boxes then it will show up in your firewall logs.
                        randomaustralian
                        the phone is still not ringing for incoming calls
                        • chpalmerC Offline
                          @randomaustralian
                          Now you need to find out where your RTP comes from.
                          Make a call and watch the states. When you call out it will probably connect to a different server.. Some do some dont. Depends on the carrier.
                          If you look at my WAN rules above from 30 minutes ago you will see that I have rules for RTP for at least a couple of different locations.
                            randomaustralian
                            that is with a connected outgoing call. that all i get in hte :50** range
                            • chpalmerC Offline
                              chpalmer
                              Looks like the inbound SIP port for you is 5065..
                              Your RTP is most likely somewhere other than at 5004 then.
                              • chpalmerC Offline
                                chpalmer
                                Do a packet capture of your device from the firewall while making a call..
                                or you can go to status/status graph and set it for remote. See what is constant while the call is in progress.
                                  Still watching. Looks like you guys are getting close.
                                  The 1:1NAT rule we tried some time back should have taken care if the static outbound NAT and allowed back any traffic as long as you had firewall rules to pass it.
                                  The fact you were seeing the reply traffic blocked at all shows the states had closed. The keep-alives my be too far apart, or not there at all.
                                    CHRIS.DAVIDSON
                                    I have this same problem with Telstra SIP and pfsense. Outgoing calls work but incoming calls don’t work.
                                    Packets seem to get to the WAN interface of pfsense, but go no further.
                                    I will try another firewall in the next few days to confirm that it is indeed pfsense that is causing the issue. Then I will go back to pfsense.
                                    Tried just about everything I can think of.
                                    Cheers
                                    Chris
