    PureVPN connection issues
    29 Posts 5 Posters 3.5k Views 5 Watching
    • johnpozJ Online
      Get with this nonsense vpn company to update their shit!!
      And this has ZERO to do with pfense - ZERO!! Your not even trying to use pfsense as a client.
      There cert is not verify.. Its right there in what you posted!
      manjotscM 2 Replies Last reply Reply Quote 0
      • manjotscM Offline
        manjotsc @johnpoz
        @johnpoz I tired using pfsense in build openvpn, but it's successfully connects and then there is no internet, gives dns probe errors.
        Vendor: HP
        Version: P01 Ver. 02.50
        Release Date: Wed Jul 17 2024
        Boot Method: UEFI
        24.11-RELEASE (amd64)
        FreeBSD 15.0-CURRENT
        CPU Type: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
        Current: 3606 MHz, Max: 3400 MHz
        4 CPUs : 1 package(s) x 4 core(s)
        • johnpozJ Online
          Well how about we actually troubleshoot that vs trying to do something that doesn't even look supported by this company.. They have their own "windows" software - where did you think you could use the current actual openvpn client with them?
          • manjotscM Offline
            manjotsc @johnpoz
            @johnpoz This is what is did in configuration file, TCP file attached works fine, only UDP connection is causing this issue.
            Thanks everyone for help and suggestion......
            in2-udp-purevpn.txt in2-tcp-purevpn.txt
            Vendor: HP
            Boot Method: UEFI
            • johnpozJ Online
              And as you can see the CA certs listed in those are different!!!
              Let me say this yet again... Get with them to support their shit... this has zero to do with pfsense, zero!!!
              manjotscM 1 Reply Last reply Reply Quote 0
              • manjotscM Offline
                manjotsc @johnpoz
                @johnpoz Ya I got, I was just sharing the files so, Could have a look,
                Thanks for helping........................................
                Vendor: HP
                Boot Method: UEFI
                • johnpozJ Online
                  Clearly the UDP one is NOT the right one, and the cert given isn't signed by the CA...
                  Doesn't match up to what you posted!
                  Your error is from CA in the tcp.txt file... Not the same as what is in the udp.txt.. So yeah no shit its going to fail.. As your error stated the certs don't verify!!
                    Moved to general discussion as this is unrelated to pfSense (and definitely unrelated to DNS!).
                    • johnpozJ Online
                      We should prob edit the subject as well...
                      Maybe "Problems with connecting to purevpn - non pfsense related"
