    Help with physical interfaces and VLANs
    70 Posts 5 Posters 14.9k Views 5 Watching
      BlankSpace @johnpoz
      @johnpoz said in Help with physical interfaces and VLANs:
      what about 8.8.8.8
      That 192.168.100.1 is your current router..
      Correct, which would be the WAN gateway. Its actually a port off of a linksys LRT214 with its own vlan and subnet. If I plug my pc directly into that, I would get the same DHCP and have internet access.
        Well if you can not ping 8.8.8.8 then you have something wrong with upstream.. Do a sniff on your wan while you ping 8.8.8.8 - do you see it go out??
          BlankSpace
          From the shell when trying to ping, I get no route to host. Packet capture shows:
          16:15:19 IP 192.168.100.100 > 192.168.100.1: ICMP echo request. id 2892, seq 3180, length 8
          16:15:19 IP 192.168.100.1 > 192.168.100.100: ICMP echo reply. id 2892, seq 3180, length 8
            Then you don't have a gateway setup if you don't have a default route... Post your gateways, show your routes..
            Did you get your wan via dhcp, or did you manually set it?
              BlankSpace
              Ok, I put a USB NIC on this PC so I can copy and paste directly from pfsense. Yes the gateway was obtained from the DHCP. My routes are all weird:
                Dude why do you have openvpn setup... Get the thing working before you start trying to setup pfsense as a vpn client!
                And your not going anywhere without a default route..
                  BlankSpace
                  I was testing with no WAN, just using the LAN interface with openvpn, which did work just using the LAN. Shouldn't the default have been created automagically? Do I need to go System>Routing>Add and put a new static route?
                    You have gateway set to auto? specifically set it to your wan gateway. Like you see in my post.
                      BlankSpace
                      That would be it. I am not sure why it was set to auto, I've been playing around with so many things before I was able to create my own little network to test the WAN.
                        BlankSpace
                        Thank you for all of the assistance, first time with pfsense here. So "technically" I can drop this in off my cable modem and should at least have one interface and vlan up and running.
                          It should yes - keep in mind that almost always when you change something connected to a cable modem, ie swap out your router for pfsense you would have to reboot your router. I would disconnect your router... Power cycle your cable modem... Wait for it to show online, then connect pfsense and it should grab a public wan IP.. And then yeah all your networks behind should be up and running.. that have rules to allow :)
                          Auto should work - but I have seen it be finicky myself sometimes.. Especially if you have something else setup as a gateway - where I saw it have a problem was when I had a downstream router setup (ie another gateway)... But if your not multiwan or whatever doesn't hurt to hard code it.
                            BlankSpace @johnpoz
                            ...keep in mind that almost always when you change something connected to a cable modem, ie swap out your router for pfsense you would have to reboot your router. I would disconnect your router... Power cycle your cable modem... Wait for it to show online, then connect pfsense and it should grab a public wan IP..
                            Found that out last night, actually had the cable company come and replace my modem cuz it took a shit when I put it in bridge mode. It was a Pace D5001. I plan on upgrading to gig internet (500/50 now) so they gave me a docsis3.1 Arris CM8200a which is no frills bridge, easy to work with.
                            Now gotta get my Netgear managed switches figured out with the VLANs and I'll be set.
                              Nice... How much a bump in cost for the move to gig, and is it 1k/1k - or is it asymmetrical? I'm also on 500/50 plan - but really want the more up, down 500 is more than enough... But could use more up.. Not worth the cost bump for 1k/100 currently - if it was 1k/1k - would be all over it ;)
                              Not so much the monthly cost - but my current modem won't do gig.. It handles 500 without issue, but not really looking to drop money on a new modem, and monthly bump for 50 more up... I don't need the down.. And sure wouldn't be happy paying the extra monthly if couldn't actually get the gig down, even if don't really need it ;) hehehe
                              I wish they had a 500/500 plan or 500/200 would be freaking sweet! That would be a sweet spot for me...
                              Enjoy your new speed and pfsense - your going to love it!
                                BlankSpace
                                It'd still be 50 up which sucks. I think they also increase the total up/down max data from 4000gb to 6000gb, which I'll probably never hit anyway. I believe its around 20 more a month. I do, however, almost always get 50 up when testing.
                                  I'm on no cap.. So not something I would have to worry about.. I do about 2TB a month..
                                  But curious what the next couple of months will be like - work just put us on work from home for next few weeks. Not sure how long that will last with all this virus stuff, sure hope it gets back to normal sooner vs later..
                                  And all friends and family all going to be home more, etc. So sure my plex server will be seeing more traffic ;)
                                    BlankSpace
                                    holy #)(U% that's alot! I'm in PA and the gov just shut down all schools for two weeks so I got a 6yo and 8yo who'll be home. My wife is also on work from home, she works for a hospital and they do not want anyone in the office who doesn't need to be.
                                      BlankSpace
                                      Next question as I try to draw my future topology for the 1000th time. Management switches - the IP's of those switches only matter to be able to manage them, correct? So if my main LAN and management vlan is vl100 192.168.200.0/24 - ALL my managed switches should have an IP in that subnet, correct? It doesn't matter what VLANs are assigned to ports on those switches as long as one is the trunk with vl100?
                                      • DerelictD Offline
                                        Derelict LAYER 8 Netgate
                                        Generally the only layer 3 interface on a managed layer 2 switch is for management, yes.
                                        Chattanooga, Tennessee, USA
                                          BlankSpace @Derelict
                                          @Derelict said in Help with physical interfaces and VLANs:
                                          So am I correct in thinking that as I go from my Pfsense box with 4 LAN interfaces, I can put each interface to separate ports on my main, lets call it my "BDM" 16 port managed switch. Then from that BDM switch, I'll go out one wire each to what I'll call my "IDE" managed switches.
                                          • DerelictD Offline
                                            Just put the management interfaces for your switches on a VLAN you can access from your management workstation.
                                            Just like any other host you want to connect to.
                                            You will find different capabilities in switching gear depending on what you get. Some have to be managed on the untagged VLAN, some allow you to set the VLAN of the management interface. it depends.
                                            It all boils down to just setting an IP address, subnet mask, and default gateway of the management interface though. DHCP can be used if that fits with your network design.
