    Help with physical interfaces and VLANs
    70 Posts 5 Posters 16.3k Views 5 Watching
      BlankSpace
      Ok, in my Netgear I can set it to any vlan. So if my main lan is vl100, which will only have my main pc's on it, I should set that to 100 and give it the required IP info from vl100. And every other switch will be the same way with different IP's, most likely sequentially numbered... 192.168.200.3, 192.168.200.4, etc.
      • DerelictD Offline
        Derelict LAYER 8 Netgate
        Depends. I do not work for Netgear. I would expect that to need to be set to VLAN 100 though if you are accessing that interface from VLAN 100.
        Chattanooga, Tennessee, USA
          BlankSpace
          Now that I have my VLANs designated, I understand pfsense is default deny for everything. So for any VLAN that I only want to be able to access the internet, all I need is a pass rule from that VLAN net to WAN net ? Everything else to anything else is default blocked, correct?
          • DerelictD Offline
            No.
            WAN net is not the internet. any is the internet.
            You need to block the destinations you do not want them to have access to then pass everything else (the internet).
              BlankSpace @Derelict
              @Derelict said in Help with physical interfaces and VLANs:
              No.
              I would want everything blocked but the Internet so would I need to create a block rule to every other VLAN and then change WAN net to "any"?
                BlankSpace
                Found some pointers from johnpoz in another thread.
                How's this look:
                • DerelictD Offline
                  fine if This Firewall and rfc1918 cover everything you don't want them to be able to access.
                  B 2 Replies Last reply Reply Quote 0
                    So I take it they are going to use external dns?
                      Well, I don't want them accessing anything on pfs other then ping their gw. And my alias of rfc1918 includes all private networks. I think that should work?
                        BlankSpace @johnpoz
                        @johnpoz said in Help with physical interfaces and VLANs:
                        That is what I want to happen, I want dhcp to provide external dns servers from my isp. Whether or not I have it configured that way .... 'Nother story lol
                          BlankSpace
                          Regarding DHCP on my VLANs, if everything is setup correctly on the interface, dhcp server, vlan, etc., should I be able to grab an address by plugging a PC directly into that interface on pfs? I am trying to troubleshoot not getting the correct DHCP address downstream. I am only getting the main LAN address after configuring my switch port VLANs. Obviously something is not correct or it'd be working. When I plug a pc directly into the interface, I do not get any address.
                            BlankSpace @BlankSpace
                            @BlankSpace said in Help with physical interfaces and VLANs:
                            Well I got it working, not sure if it's how it's supposed to be but it works. Not a pfs issue - I changed the pvid of the device port and marked it untagged on the downstream switch to match the VLAN and it got an address from that VLAN.
                              BlankSpace
                              I done did it now. I somehow locked myself out of pfs except for console. I was trying to troubleshoot why one of my VLANs (100) was not giving DHCP and I found that igb0 did not have VLAN100 assigned, it was just the physical NIC under interfaces. So when I assigned VLAN100 to igb0, I no longer could access pfs. I would assume that's because I have something screwed up downstream and its not tagging my port with vl100?
                              Any ideas how to remove the VLAN 100 from igb0 and just have igb0 be the physical interface using the console?
                                Got pfs reverted to igb0 being the physical nic and not VLAN100 by assigning the PVID on the switch to 100, reconnecting and changing it back.
                                  @Derelict I think I am starting to get this. Maybe. For purposes of this scenario, say I have 4 physical LAN interfaces on pfs. If I only have the need for 4 subnets, then really no need to VLAN if each subnet will be contained to only their physical interface? Just setup each interface with DHCP and use rules to segregate as needed? So if I have one subnet that goes to an outbuilding and in that outbuilding is a consumer Netgear wifi router with no VLAN capabilities, I would simply set that interface up with dhcp or static, no VLAN. The netgear router would be static or grab an IP from that interface and be good to go.
                                    ^ true... But unless your going to have these networks physically isolated on their own switches or AP, you would need to do vlans on your switches and APs. But pfsense doesn't need to know anything about that.
                                      BlankSpace @johnpoz
                                      Thanks, yes one of the outbuildings I have is actually an "in-law" suite where my aunt resides. She uses my internet but has her own Netgear consumer wifi router. I'm going to do a direct connection to that interface on pfs. I've actually setup a little test network exactly how I want it and so far so good after working out some bugs.
                                        BlankSpace
                                        Is it possible to find the MAC address of an IP that's listed in the firewall logs? I want to find out what this is or what machine it's coming from:
                                        • JKnottJ Offline
                                          JKnott @BlankSpace
                                          @BlankSpace
                                          If you want to find the MAC address, ping the IP address and then you can check the ARP cache.
                                          UniFi AC-Lite access point
                                            BlankSpace @JKnott
                                            @JKnott said in Help with physical interfaces and VLANs:
                                            @BlankSpace
                                            It doesn't ping... it looks like its one of those default windows IP's if the machine can't get dhcp.
                                            Pinging 169.254.196.231 with 32 bytes of data:
                                            PING: transmit failed. General failure.
