    Snort problem
    104 Posts 21 Posters 48.7k Views
      r3dn3ck
      The issues with the netbios rules are most likely due to sourcefire revamping of the ruleset. They have added some extra preprocessors to handle the recent MS08-067 vulnerabilities.
      Check this out if you want more information:
      http://isc.sans.org/diary.html?storyid=6151
        ColdFusion
        Seems about right. Just updated rules to 5/14 and get the error now on this pf box.
          goulou
          @ColdFusion:
          @goulou:
          I've got a stange issue with snort as well… after gracefully shutting down my network for a week later I brought PFS back up and updated Snort rules... I now have this message in my log:
          snort[3004]: FATAL ERROR: Warning: /usr/local/etc/snort/rules/netbios.rules(24) => Unknown keyword ' dce_iface' in rule!
          I can't locate that reference in any of the netbios.rules and the Snort Service does appear to be running (in services menu) and stays up but no alerts and nothing is being blocked… I would say it's not working correctly if at all.
          I've tried both reinstalling and uninstalling the package already and no help there… any ideas would be appreciated!
          You know what's strange about this also is I get the same error on my other PF box with Snort version
          2.6.21_10, but I don't get it on my other PF box that has version 2.6.21_08. Both have latest rules from 5/11/09.
          Thanks for the feedback on this… Wish I could say that I have another sugesstion but I don't.
            Guest
            Can anyone help me with this error that i got with snort.  I don't know what it means but i have 2GB or ram and only 12% is only beening used.
            May 22 01:15:15 snort[14339]: FATAL ERROR: Misconfigured dynamic preprocessor(s)
            May 22 01:15:32 SnortStartup[14422]: Ram free BEFORE starting Snort: 112M – Ram free AFTER starting Snort: 112M -- Mode ac-sparsebands -- Snort memory usage:
            May 22 01:23:22 snort[1843]: Alert on commands: None
            May 22 01:23:22 snort[1843]: /usr/local/etc/snort/snort.conf(276) unknown dynamic preprocessor "dcerpc2"
            May 22 01:23:22 snort[1843]: /usr/local/etc/snort/snort.conf(277) unknown dynamic preprocessor "dcerpc2_server"
            Thanks guys.
              ColdFusion
              Do you have netbios rules enabled?? Seems to be an issue if you look at the previous posts…I found this that's why I asked??
              www.snort.org/vrt/tools/using-dcerpc2.html
              • jimpJ Offline
                @1clicc:
                [snip]
                The snort package is being updated, but there is an issue with it that didn't get fixed last night. Hopefully it will get fixed at some point today.
                Do not Chat/PM for help!
                  Guest
                  @ColdFusion:
                  Nope i don't have netbois rules enable.
                  @ColdFusion:
                  It couble be because i just install snort last night.  When do you think this will be fix?
                  • jimpJ Offline
                    @1clicc:
                    Last I heard they were waiting to hear back from the person who submitted the updated package. If it can't be made to work, I imagine it will get rolled back to the last working version. You can watch the package commit logs to see if anything has changed:
                    https://rcs.pfsense.org/projects/pfsense-packages
                      Guest
                      Hope this can be resolve very soon.  Please do keep us updated when there's a fix.  Thanks you.
                        Guest
                        Hey guys, may i have the previous working version because i think this going to be awhile before it will be fix.  Anyone know where i can download the previous version? and how would i manually install it?  Thanks and much appreciation.
                          shaddow501
                          Hello Guys
                          attached please find the snort.inc that now fix the problem, and snort is running again.
                          the thing is I have disabled the new "dcerpc2" & "dcerpc2_server" and got back to the old "dcerpc" that does exist.
                          go to Edit file under pfsense menu and load: /usr/local/pkg/snort.inc and replace the content of this file with the one that is attached.
                          thats it, snort will be working perfectly now.
                          good luck. :)
                          Snort.inc.txt
                            Guest
                            @shaddow501:
                            Hello Guys
                            good luck. :)
                            Actually i got this error now:
                            May 23 10:18:54 snort[2335]: FATAL ERROR: /usr/local/etc/snort/snort.conf(214) => FTP Commands are no longer than 4 characters: '#MACB'.
                            May 23 10:19:11 SnortStartup[2408]: Ram free BEFORE starting Snort: 88M – Ram free AFTER starting Snort: 88M -- Mode ac-sparsebands -- Snort memory usage:
                            Any recommendation? because snort is not start also.
                              shaddow501
                              Its mean that you didn't save the file correctly cause the change wasn't implemented.
                              after implementing the file you need to save. and then save again in the snort setting page.
                              also I have checked and the netbios rules should not be checked till the dcerpc2 and dcerpc2_server, will be compiled correctly into the snort package
                                cmb
                                this is fixed in the package now
                                  shaddow501
                                  What is fixed?
                                  i do not see any package update?
                                  can you please be more specific what is fixed? and how? did you add the preprocessor "dcerpc2" and the preprocessor "dcerpc2_server" ?
                                  or just modify the snort.inc to disable the use of them?
                                    Guest
                                    @cmb:
                                    OK, Confirm that it is now working after i uninstall and reinstall from the package.  Thanks guys you guys are highly appreciated.
                                      shaddow501
                                      Well it is not really fixed…. netbios rules still get snort to fail.
                                        Guest
                                        @shaddow501:
                                        Use the netbios.rules from the so_rules folder.
                                          Roodawakening
                                          I've tried all of the suggestions contained within this thread and it's still not functioning properly. My PfSense box has been up and running for over 30 hours and not a single Snort alert in all that time. I just don't understand what the problem is. Can anyone advise?
                                          Thanks…
                                          "The descent to hell is easy. The gates stand open day and night. But to reclimb the slope and escape to the upper air: This is labor."
                                          –Virgil, Aeneid, Book 6
                                          Rob
                                            Guest
                                            @Roodawakening:
                                            Thanks…
                                            Do you have any snort rules in the Categories section of snort?  If you are using pfsense 1.2.2 version i believe that it's haveing problem updating the rules so you might have to manually download the latest rules from snort.org and do a SSH and also manually install the rules.  If you have the latest rules already install than you might have to start the service.
