    Snort problem
    104 Posts 21 Posters 48.7k Views
      jamesdean
      @simonchs:
      i'm running pfsense version 1.2.2
      thanks James
      Theres usually a date like mine says
      1.2.3-RC1
      built on Wed Apr 22 15:36:34 EDT 2009
      • F Offline
        firbc
        @jamesdean:
        Hey firbc, simonchs..
        Can you guys tell me what version of pfsense your running. I have a feeling its 1.2 and not 1.2.3.
        Also, please tell me whats the output of "pkg_info".
        Help me help you.
        james
        I am running version 1.2.3-RC1, built on Fri May 22 16:32:57 EDT 2009 of pfSense.
        bandwidthd-2.0.1_1  Tracks bandwidth usage by IP address
        gd-2.0.35,1        A graphics library for fast creation of images
        grub-0.97_1        GRand Unified Bootloader
        jpeg-6b_4          IJG's jpeg compression utilities
        libdnet-1.11_3      A simple interface to low level networking routines
        libiconv-1.11_1    A character set conversion library
        libosip-3.1.0      A low layer of SIP implementation
        mysql-client-5.0.77_1 Multithreaded SQL database (client)
        mysql-client-5.1.34 Multithreaded SQL database (client)
        packages            BSD Installer mega-package
        pcre-7.8            Perl Compatible Regular Expressions library
        pcre-7.9            Perl Compatible Regular Expressions library
        siproxd-0.7.0_1    A proxy/masquerading daemon for the SIP protocol
        snort-2.8.4.1      Lightweight network intrusion detection system
        Any idea? Thx
          jamesdean
          Fixed the problem waiting for new snort packages to be built.
          Please be pationant.
          Snort will be working on pfsense 1.2.2 soon.
          james
            Guest
            Welp i'm having similar problem with snort too.  I reinstalled a fresh copy of pfsense 1.2.2 because i mess it up and when it was running i had snort running beautifully until i reinstall snort after i did a fresh install of pfsense.  Before i install Snort i looked at the platform and it was for 1.2.3 but i was hoping it would work for 1.2.2 but i guess not.  Will the fix be up soon?  I would also like to suggest or request something from the pfsense team to put up multiple applicatoin for different platform so we won't get confuse.
            For example:  Snort 1.2.2
                              Snort 1.2.3
            Instead of a just single update.  Anyhow, you guys are doing a great job and we all appreciated.  Please let us know when the fix is up.  Thanks for everything.  Look foward to the fix.
            • L Offline
              lordarcane
              I´ll guess that my problem is related to the fact that I updated snort and now i´m unable to update the rules. Getting md5 signature mismatch and snort refuses to start.
                jamesdean
                @lordarcane:
                Thanx for the heads up. Snort.org changed there md5 format to day to go along with there nice new website.
                From this > c2844479ed68cc0f13ab61f69e35bc7a
                To this >MD5 (snortrules-snapshot-2.8.tar.gz) = c2844479ed68cc0f13ab61f69e35bc7a
                Going have to code a fix.
                Man Snort Package is killing me this week.
                If they change it back after I code a fix, Im going on a vacation ASAP.
                james
                  mentalhemroids
                  My thanks to JamesDean and anyone else working on this problem.  I know others appreciate the hard work done with this and all other packages.  It's not a easy task keeping up with technology, or life for that matter.
                  Thanks!
                    Guest
                    So has there been a fix?
                      serialdie
                      Waiting for the MD5 fix as well :)
                      TIA!
                        Guest
                        Can anyone tell me if this is normal?
                        May 31 12:56:05 snort[12638]: Warning: flowbits key 'PtakkS_Keepalive' is set but not ever checked.
                        May 31 12:56:05 snort[12638]: Warning: flowbits key 'dce.bind.wkssvc' is set but not ever checked.
                        May 31 12:56:05 snort[12638]: Warning: flowbits key 'snipernet' is set but not ever checked.
                        May 31 12:56:05 snort[12638]: 316 out of 512 flowbits in use.
                        Thank you.
                          jamesdean
                          I updated the the snort package today to fix the md5 error and snort.org's new oink code verification urls for rule updates.
                          Snort should work but there might be errors when snort.org goes down.
                          I still need to add code for primium snort.org oink users and clean up the code.
                          Have patience.
                          I need people to install the snort package post here. Post failers and success here. Please post your pfsense version and system specs.
                          Remember to update the rules befor starting snort after reinstall.
                          If anyone cares this is what happened this month with the snort package.
                          1. Snort.org changed there code codebase for rpc, result broke the pfsense snort packge.
                          2. I fixed the snort package.
                          3. Snort.org changed there md5 checksum format, result broke the pfsense snort packge.
                          4. I fixed the snort package.
                          5. Snort.org changed there urls, result broke the pfsense snort packge.
                          6. I fixed the snort package.
                          7. Snort.org changed there new oink code verification system , result broke the pfsense snort packge.
                          8. I fixed the snort package. All is good so far.
                          Thanx
                          James
                          P.S. 1clicc
                          Its normal.
                          Snort is just telling you you need to adjust your rules for your system. Read the snort manual for more help.
                          • AhnHELA Offline
                            AhnHEL
                            So far so good on my custom micro-atx box.  Startup completed with:
                            May 31 18:50:37 SnortStartup[59091]: Ram free BEFORE starting Snort: 112M – Ram free AFTER starting Snort: 112M -- Mode ac-bnfa -- Snort memory usage:
                            May 31 18:50:30 snort[58996]: Not Using PCAP_FRAMES
                            May 31 18:50:30 snort[58996]: Snort initialization completed successfully (pid=58996)
                            Much appreciated James, thank you for your work and service to the community.
                            1.2.3-RC1
                            built on Tue May 26 15:14:15 EDT 2009
                            FreeBSD 7.2-RELEASE i386
                            2 Gigs RAM
                            Processors  2
                            Model Genuine Intel(R) CPU 2160 @ 1.80GHz
                            CPU Speed 1.8 GHz
                            PCI Devices
                            • atapci0: Intel ICH5 SATA150 controller
                            • ehci0: Intel 82801EB/R (ICH5) USB 2.0 controller
                            • fxp0: Intel 82559ER Pro/100 Ethernet
                            • fxp1: Intel 82559ER Pro/100 Ethernet
                            • fxp2: Intel 82559ER Pro/100 Ethernet
                            • isab0: PCI-ISA bridge
                            • pcib1: ACPI PCI-PCI bridge
                            • uhci0: Intel 82801EB (ICH5) USB controller USB-A
                            • uhci1: Intel 82801EB (ICH5) USB controller USB-B
                            • uhci2: Intel 82801EB (ICH5) USB controller USB-C
                            • uhci3: Intel 82801EB (ICH5) USB controller USB-D
                            • vgapci0: VGA-compatible display
                              IDE Devices
                            • acd0: ASUS DVD-E616A3T/1.01
                            • ad0: WDC WD400JD-22MSA1 10.01E01 (Capacity: 39.10 GB)
                              SCSI Devices none
                              USB Devices none
                            AhnHEL (Angel)
                              jamesdean
                              Thanx onhel.
                              I need more user sytem info. Hope the community helps out.
                              Please post pfsense version and system specs.
                                Guest
                                First of all I would like to say Thank you and an excellent job well done.  As of right now i think snort is down so i couldn't get my oink code so i can't test the update.  But snort working great.
                                May 31 18:16:21 shinigami snort[14439]: [ Port Based Pattern Matching Memory ]
                                May 31 18:16:21 shinigami snort[14439]: +-[AC-BNFA Search Info Summary]------------------------------
                                May 31 18:16:21 shinigami snort[14439]: | Instances        : 655
                                May 31 18:16:21 shinigami snort[14439]: | Patterns         : 111013
                                May 31 18:16:21 shinigami snort[14439]: | Pattern Chars    : 1088067
                                May 31 18:16:21 shinigami snort[14439]: | Num States       : 801960
                                May 31 18:16:21 shinigami snort[14439]: | Num Match States : 148254
                                May 31 18:16:21 shinigami snort[14439]: | Memory           :   20.44Mbytes
                                May 31 18:16:21 shinigami snort[14439]: |   Patterns       :   3.58M
                                May 31 18:16:21 shinigami snort[14439]: |   Match Lists    :   6.99M
                                May 31 18:16:21 shinigami snort[14439]: |   Transitions    :   9.71M
                                May 31 18:16:21 shinigami snort[14439]: +-------------------------------------------------
                                May 31 18:16:21 shinigami snort[14439]: Snort initialization completed successfully (pid=14439)
                                May 31 18:16:21 shinigami snort[14439]: Not Using PCAP_FRAMES
                                I will ilet you know once i get my oink code.  Thanks again for your hard work and you are certainly highly appreciated.
                                  try
                                  THanks to Jamesdean snort working again in my pfSense running
                                  pfSense 1.2.2
                                  built on Thu Jan 8 22:39:31 EST 2009
                                  FreeBSD 7.0-RELEASE-p8 i386
                                  rules update in progress..
                                  I'll let you know when the update finished.
                                  edit:
                                  yes, the rules update also work, Snort says:
                                  Your rules are up to date…
                                  Cheers,
                                    jamesdean
                                    Man oh man.
                                    Snort.org changed the way there files are downloaded. Third night in a row….
                                    The md5 file downloads but is emty. This is there way to enforce the 15 min wait for updates.
                                    thanx
                                    james
                                      Hugovsky
                                      2 boxes:
                                      1-1.2.3-RC1
                                      built on Sat May 30 22:26:25 EDT 2009.
                                      snort package v.2.8.4
                                      Doing ppoe with bridged router. Can't update rules and everytime ip changes, snort won't restart. Restart snort mannualy to work.
                                      2-1.2.3-RC1
                                      built on Tue May 12 00:32:03 EDT 2009
                                      behind router. working like a charm.
                                      Can't update rules.
                                      Your work IS GREATLY apreciatted by me. It's because of people like you that I learn something every day. I just hope some day I could do something to help the community, just like you.
                                      BIG thanks for your work.
                                        serialdie
                                        James,
                                        Do you have a pay pal link?
                                        I wont mind sending you a donation for all your work!!!
                                        Thanks!
                                          jamesdean
                                          Thanx serialdie, Hugovsky. Your type of peple I'm doing this for. Send mony to the pfsense core developers so they can buy me a mini-itx.
                                          Added today
                                          Updates work again.
                                          "when did I last download, time stamps info" (just started)
                                          Adding latter today. If I have time.
                                          Rules backup option. you will need 180 megs for this.
                                          Alerts to system log. (Requested don't know why.)
                                          Identify snort package version.
                                          redo Update rules automatically option.
                                          RSS feeds.
                                          If there is any one here in the forums that is a Premium snort rules user, Please email me.
                                          james
                                          • L Offline
                                            lordarcane
                                            Hey!
                                            Snort up and running again.
                                            Running pfsense 1.2.2
                                            ReInstalled snort package, downloaded the rules.
                                            Had to save the rules before I could start snort, otherwise it said unable to load the rules.
                                            Thanks for all the hard work!
