    Problem with pppoe over vlan
    44 Posts 2 Posters 14.9k Views 4 Watching
    • FireOdoF Offline
      FireOdo
      Hi there,
      I am on 2.4.5-RELEASE-p1 and I have a similar issue as in this thread: pfsense 2.4.4 fails all pppoe's after disabling one. The WAN (pppoe) is on igb1.7 (igb1 with Vlan 7).
      If I only save the settings (for example) on the Wireless (ath0_wlan0) Interface (without changing anything) the Wan goes down and don't come up same as in all the examples in this thread pfsense 2.4.4 fails all pppoe's after disabling one. What has the Wireless interface to do with the Wan pppoe connection?
      In the log file I found that in the moment I saved the settings on the wireless interface something caused this:
      "vlan0: changing name to 'igb1.7' " (the vlan seems to be deleted and remade) It seems that in this moment the pppoe is "in the air" (it tries to keep connection to an inexistent interface). When I manually hit the "Connect" button the pppoe-connection get back without problems. I have done this a few times to be sure it is reproductible.
      Regards,
      fireodo
      pfsense 2.9.0 CE
        Hmm, that was exactly what that patch should have fixed. I use PPPoE over VLANs and am not seeing that.....
        You see the same errors, like?:
        Nov 26 12:23:44	ppp		[wan_link0] can't remove hook mpd63022-0 from node "[52]:": No such file or directory
        Nov 26 12:23:44	ppp		[wan_link0] PPPoE: can't connect "[52]:"->"mpd63022-0" and "[8d]:"->"left": No such file or directory
        Is your wifi interface bridged to igb1 maybe?
        FireOdoF 1 Reply Last reply Reply Quote 0
        • FireOdoF Offline
          FireOdo @stephenw10
          @stephenw10 said in Problem with pppoe over vlan:
          Yes, this kind of errors has brought me to my initial search (where I found the threads in my original post).
          Aug  8 15:30:40  ppp: [wan_link0] PPPoE: can't connect "[25c]:"->"mpd82722-0" and "[25a]:"->"left": No such file or directory
          Aug  8 15:30:40  ppp: [wan_link0] can't remove hook mpd82722-0 from node "[25c]:": No such file or directory
          No, the wifi (ath0_wlan0) is bridged to igb0 (Lan)
          There is nothing else bound to igb1 (except vlan7 and of course pppoe)
          Thanks,
          fireodo
          pfsense 2.9.0 CE
            Hmm, do you see the code from that patch on your system?
            https://github.com/pfsense/pfsense/commit/433a8e71f3b68c39634e11b62d8bf3d9e8ec878c.patch
            • FireOdoF Offline
              FireOdo @stephenw10
              Yes - i checked that in the interfaces.inc before posting my issue!
              pfsense 2.9.0 CE
                Hmm, curious. Something you have configured must be matching the code that requires the parent to be re-configured. You have anything else on igb1?
                • FireOdoF Offline
                  FireOdo @stephenw10
                  No, only vlan7 and the pppoe bound on vlan7.
                  pfsense 2.9.0 CE
                    Hmm, is it any change to any other interface that triggers it?
                    • FireOdoF Offline
                      FireOdo @stephenw10
                      Yes, I made a test now, only saving the LAN Settings (without changing anything) and I had the same behaviour and this also:
                      Aug 17 18:22:39	ppp		[wan_link0] can't remove hook mpd72282-0 from node "[13]:": No such file or directory
                      Aug 17 18:22:39	ppp		[wan_link0] PPPoE: can't connect "[13]:"->"mpd72282-0" and "[6fa]:"->"left": No such file or directory
                      and here (from dmesg) in order of actions:
                      1. I save the lan settings:
                      igb0: link state changed to DOWN
                      igb0: link state changed to UP
                      1. after that came this:
                      2. I hit the Connect Button (without hitting the Button the connection dont get back) in interfaces:
                        ng0: changing name to 'pppoe0'
                      3. and internet connection came back.
                      pfsense 2.9.0 CE
                        Hmm, I can't replicate that. Though interestingly the box I'm testing on (my home edge device) has all its interfaces, including pppoe, as VLANs on the same lagg0 parent. You might expect it to force a vlan reload in the situation but it does not....
                        • FireOdoF Offline
                          FireOdo @stephenw10
                          Its strange because I have nothing special here and i have not made any change to the pfsense Installation - its a simply firewall-router with a few packages (see signature). The vlan7 on the pppoe is required by the Internet-Provider.
                          Hmmmm
                          PS. Until a few weeks I have used my pfsense without vlan7 thats why the problem had not occured in the past (I suppose).
                          PPS. I have now, made an extra check of the patch pppoe-patch
                          and it confirms that the patch is allready on the system.
                          pfsense 2.9.0 CE
                            On other test systems where I have VLANs on different parent interfaces they are not rebuilt:
                            Aug 18 14:10:46 	check_reload_status 	425 	Syncing firewall
                            Aug 18 14:10:53 	check_reload_status 	425 	Restarting ipsec tunnels
                            Aug 18 14:10:56 	check_reload_status 	425 	updating dyndns lan
                            Aug 18 14:10:58 	check_reload_status 	425 	Reloading filter
                            That's resaving LAN with no changes.....
                            Either not all that patch code is in your system somehow or you config is triggering the VLAN rebuild with something. Hmm
                            • FireOdoF Offline
                              FireOdo @stephenw10
                              Hi Steve, would you mind to send me your interfaces.inc and interfaces.php? Thanks a lot!
                              pfsense 2.9.0 CE
                                Hmm, one thing I notice here is that the igb0 link goes down when you saved that. That would not normally happen if you save an interface without changing anything.
                                I assume igb0 is your LAN there? What settings do you have on that interface?
                                • FireOdoF Offline
                                  FireOdo @stephenw10
                                  Look:
                                  I also downloaded the original files from github
                                  https://github.com/pfsense/pfsense/blob/RELENG_2_4_5/src/etc/inc/interfaces.inc
                                  https://github.com/pfsense/pfsense/blob/RELENG_2_4_5/src/usr/local/www/interfaces.php
                                  and have compared with mine and they are identical.
                                  pfsense 2.9.0 CE
                                    Do you have Snort or Suricata running? That can cause interfaces to reconnect sometimes. In in-line mode perhaps.
                                    If you assign/enable igb1 does that also go down/up when you resave LAN?
                                    • FireOdoF Offline
                                      FireOdo @stephenw10
                                      Yes, i have Snort but not in in-line mode.
                                      igb1 is assigned to vlan7 and to pppoe ...
                                      PS. Its only the vlan that get renewed, igb1 is left untouched.
                                      In conclusion - when settings are applied (in my case) on LAN (igb0) or WiFi (ath0_wlan0) only the vlan gets affected! (When applying settings on LAN (igb0) its normal that igb0 go down/up)
                                      pfsense 2.9.0 CE
                                        Right, but I'm saying if you assign igb1 as a new interface and enable it with no config but just so it's up does that also go down when you make a change. That would explain why the vlan is rebuilt, but not why igb1 goes down.
                                        • FireOdoF Offline
                                          FireOdo @stephenw10
                                          Yes it also goes down, here the dmesg output:
                                          igb1: link state changed to DOWN
                                          igb1.7: link state changed to DOWN
                                          igb1: link state changed to UP
                                          igb1.7: link state changed to UP
                                          PS. Maybe its helpful to know that my system was continuously updatet from 2.4.3 (I'm using pfsense longer but 2.4.3 was a fresh install with config recovery)
                                          PPS. Another Idea: Snort needs interfaces in promiscuous mode - could that be a possible culprit?
                                          pfsense 2.9.0 CE
                                            Mmm, exactly Snort applies promiscuous mode when it starts.
                                            What happens if you just restart Snort?
                                            What interfaces do you have Snort running on?
                                            It looks like the VLAN here is correctly being recreated because the parent interface is brought down. That's why I can't replicate it here. I'll try with Snort....
