    Problem with pppoe over vlan
    44 Posts 2 Posters 9.8k Views 4 Watching
    • fireodoF Online
      fireodo @stephenw10
      @stephenw10 said in Problem with pppoe over vlan:
      Mmm, exactly Snort applies promiscuous mode when it starts.
      What happens if you just restart Snort?
      Snort restarts without any issue.
      What interfaces do you have Snort running on?
      WAN interface only.
      It looks like the VLAN here is correctly being recreated because the parent interface is brought down. That's why I can't replicate it here. I'll try with Snort....
      Thanks, a lot!
      Here are all the pkgs I use: Cron, iftop, iperf, LCDproc, nmap, pfBlockerNG-devel, RRD_Summary, Shellcmd, snort
      • stephenw10S Online
        Hmm, I can't replicate seeing the NIC link go down however I try to apply it....
        fireodoF 1 Reply Last reply Reply Quote 0
        • fireodoF Online
          fireodo @stephenw10
          I crashed myself my head - I have no clou where to set the axe ... definitiv clear is that every time I save a interface (without any changes) (LAN or WIFI or the OPT2 igb1-temporary created) the vlan gets remade ... and that kills the pppoe!
            Yup. I see it it happening for you I just can't re-create it here...yet.
            fireodoF 2 Replies Last reply Reply Quote 1
            • fireodoF Online
              fireodo @stephenw10
              Thanks for not giving up! ๐Ÿ‘ ๐Ÿ‘
              • fireodoF Online
                fireodo @stephenw10
                Hi anything new in this problem? Just asking! ๐Ÿ˜Š
                Regards,
                fireodo
                  No I've been unable to replicate it. Something you have set there is causing the NIC to flap and I'm not sure what.
                  We might need to review your config somehow...
                  fireodoF 2 Replies Last reply Reply Quote 0
                  • fireodoF Online
                    fireodo @stephenw10
                    OK, understood!
                    Thanks anyway!
                    fireodo
                    • fireodoF Online
                      fireodo @fireodo
                      • fireodoF Online
                        fireodo @stephenw10
                        BTW: I set up a identical machine (APU2C0) with a fresh pfsense 2.4.5-RELEASE-p1 with no other packages and the behavior is exactly like my productive pfsense. Saving the LAN(igb0) or the WIFI(ath0_wlan0) interface without any changes made, make the vlan to be remade! (Vlan is on igb1). Anyway seems I have to live with it ๐Ÿ˜ข
                          Hmm, wondering if it's because of the bridge maybe... Though without igb1 in the bridge you would not expect that to hit WAN...
                          • fireodoF Online
                            fireodo @stephenw10
                            igb1 is not in the bridge. The bridge is between LAN (igb0) and WIFI (ath0_wlan0). igb1 has no interface assign on it (only the vdsl-modem is connected to it) and is only parent for vlan7 and pppoe connects via vlan7.
                            Regards and fine weekend,
                            fireodo
                              Yes, exactly. Without igb1 in the bridge I wouldn't expect to see changes made to the wifi interface affect it.
                              But I'm unable to replicate it. The interfaces do not lose link and come back up when you make a change. Even on the interface you apply the change to.
                              You must have something in your config that is applying a setting to all interfaces everytime they are reloaded. Like maybe putting them in promiscuous mode for monitoring. I could imagien iftop or snort doing that. I did test Snort though.
                              Anyway this is not a problem with PPPoE over VLANs, not specifically at least. The VLAN is being rebuilt here because the parent interface is flapping.
                              • fireodoF Online
                                fireodo @stephenw10
                                This is maybe an explication for my "productivity" pfsense but not for the clean install pfsense on the the secondary machine - there is no snort or anything else like that.
                                In the mean time I get a vdsl-modem who is setting the tag 7 (neccessary for getting a connection on my provider) so I dont need the pfsense vlan7 anymore. Now I can store any interface without loosing connection! (but the vlan7 gets still renewed every time - I didnt deleted the vlan7 because I will observe in the future whats going on with it) So this is my personal "workaround".
                                Maybe you cannot reproduce the situation because of running pfsense in a VM? Just a supposition ...
                                Regards and thanks,
                                fireodo
                                  No, I've tested a number of different hardware devices too. No insight at this point.
                                  • fireodoF Online
                                    fireodo @stephenw10
                                    That let me "speechless" - as you can imagine I crushed my head long time before writing in the forum because I dont want to steal the time from nobody, with a problem that I can solve myself, but I did not find a hook from where the problem may be get solved.
                                      Try just doing a basic install and testing this. Add the parts of you config one at a time until the issue shows up.
                                      • fireodoF Online
                                        fireodo @stephenw10
                                        Thats what I have done on the secondary machine - just basic setup and the vlan7 problem was there.
                                          Was it dropping the link on the parent NIC without the VLAN on there? Just a basic WAN and LAN config? And that wasn't on an APU?
                                          • fireodoF Online
                                            fireodo @stephenw10
                                            The parent link wasnt dropped. Only the vlan was renewed. Yes only Lan and Wan. It was a identic APU like my productive system (APU2C0)
