    Problem with pppoe over vlan
    44 Posts 2 Posters 9.8k Views 4 Watching
      Ah, that's a different problem then! Yes, the VLAN should not be regenerated if the parent is not dropped/reconfigured.
      Reviewing here it looks like your other test system was also an APU and also had a wifi card. Was it also bridged? But, to be clear, on that other system you don't see the links go down like you do on the original system?
      fireodoF 1 Reply Last reply Reply Quote 1
      • fireodoF Offline
        fireodo @stephenw10
        @stephenw10 said in Problem with pppoe over vlan:
        You will be laughning - since I switched the Wan from vlan7 to igb1 and let the modem do the tag 7 neither the productive system is dropping the links - only the vlan gets renewed ... its weird ...
        pfsense 2.8.1 CE
          Hmm, so even though you no longer have vlan7 assigned it still gets rebuilt when config changes are made?
          fireodoF 1 Reply Last reply Reply Quote 0
          • fireodoF Offline
            fireodo @stephenw10
            YES! (I checked a few times on both machines)
            pfsense 2.8.1 CE
