    Help required for a simple QoS setup
    8 Posts 4 Posters 1.9k Views 5 Watching
      NinthWave
      I recently migrated from DD-WRT to pfSense and installed most popular packages with success but I must say that setting traffic shaping is quite a challenge for a noob in this matter.
      I have a Videotron cable 100/30 connection which has very bad bufferbloat behavior w/o any QoS setup.
      I have done those exact settings:0ecc8fdf-39c3-418b-94a9-fb8b14cacdcb-image.png
      that solved the bufferbloat problems but sends a continuous error message in the console; 69c35066-a882-437f-87e6-1e8c287296f8-image.png
      And I still have some problems with my generic (VoIP.ms) that I would like to solve before the wife decides to cancel the service 😧 :-)
      I have read this: 23a1b789-085b-441a-9e2a-136b416148ef-image.png
      And browsed this: 9ac385b1-59a6-4cba-bef9-88a156ec9b29-image.png
      But honestly, I just don't know how to reconcile all those sources in something functional.
      What I want to achieve with my cable 100/30 connection is:
      • low bufferbloat
      • LAN VoIP
      • LAN devices (2 PC, 2 Android TV box)
      • WLAN devices (2 iPads, 2 cell phones with WiFi calling)
      • 1 gaming teenager
      • MS Teams meetings
      • 1 streaming Android box
      Can anyone help me finding my way ?
      • DaddyGoD Offline
        DaddyGo @NinthWave
        @ninthwave said in Help required for a simple QoS setup:
        welcome in the team 😉
        try based on that:
        https://forum.netgate.com/topic/138092/fq_codel-error-config_aqm-unable-to-configure-flowset-flowset-busy
          NinthWave @DaddyGo
          @daddygo I tried the Wizard. Seems to be working. But still, if anyone has any input.
            tman222 @NinthWave
            Hi @NinthWave - have you tried the exact steps detailed in this post?
            https://forum.netgate.com/topic/112527/playing-with-fq_codel-in-2-4/815
            If yes, are you still seeing issues?
            Hope this helps.
              NinthWave @tman222
              @tman222 said in Help required for a simple QoS setup:
              Hope this helps.
              I tried it yesterday but now, my upload vanishes to zero and dslreports stops.
              I posted as a reply on the "playing with FQ-Codel" thread.
              DaddyGoD A 2 Replies Last reply Reply Quote 1
              • DaddyGoD Offline
                DaddyGo @NinthWave
                dslreports stops.
                look at this too:
                nperf
                https://www.nperf.com/
                  andresmorago @NinthWave
                  @ninthwave
                  I’m having exactly the same upload issues. I also reported them on that thread. https://forum.netgate.com/topic/112527/playing-with-fq_codel-in-2-4/1045
                  I temporarily fixed that by multiplying the upload bandwidth parameter by 10.
                    NinthWave @andresmorago
                    @andresmorago said in Help required for a simple QoS setup:
                    @ninthwave
                    Thanks for quoting me. Since my problem could not be resolved, I reverted back to using the wizard.
                    I will closely look at your thread to see if it finds any resolution.
