    Incorrect bandwidth monitor values
    40 Posts 2 Posters 4.3k Views 2 Watching
      Hmm, do you see an outbound state for the openvpn traffic on vmx1?
        MindlessMavis @stephenw10
          Hmm, you could try something more radical like importing the config into a new VM and seeing if it's still replicated.
              Mmm, I mean it looks like some values have been switched somehow such that pf is referencing the wrong interface(s). But if that was the case I would expect the policy routing and firewall rules to also be wrong. Also I've never seen that happen before and really I have no idea how it could!
              I could imagine the interfaces becomes switched, for example ovpnc2 is no longer the tunnel you think it is. Or the interfaces are re-ordered in vmware. But that would not account for traffic switching from vmx to ovpn.
                  You could create a new NIC on the same vswitch and then reassign WAN to that, vmx2 for example.
                  pf has an interface for all OpenVPN traffic that is uses for firewall rules on unassigned interfaces. I wonder if somehow the ovpnc8 graph is pulling data from that. Though that would still include data from ovpnc9.
                  For anything like that to happen it would have to very low level. I assume ifconfig still reports the correct number of interfaces with the correct names?
                    MindlessMavis
                      MindlessMavis @MindlessMavis
                        @hvr-lust said in Incorrect bandwidth monitor values:
                        PPROMISC
                        Hmm, that's.... interesting!
                        Is it in a bridge by any chance? Or are any of those interfaces in a bridge?
                        I wouldn't normally expect to see a TAP mode client in a bridge in that sort of setup but...
                            Mmm, it seems the interface is being used in some unexpected way to cause it to be flagged like that. This seems very likely to be related.
                              And the actual pfctl output shows that data on the wrong interfaces too?
                                It would be good to test a 2.7 snapshot if you can. There have been a lot of pf changes there recently. There's a good chance it will at least behave differently.
                                    Ok so to be clear you don't have any bridge interfaces?
                                    No TAP mode openvpn clients?
                                    Did your config include the RRD data? Definitely worth testing without it if so.
                                          Is that a config from 2.4.5?
                                          SSH keys were not included in the config until 2.6. You can probably remove that section from the config to allow it restore.
                                            MindlessMavis
