    Starlink problem with SG2440 22.05
    38 Posts 6 Posters 6.9k Views 6 Watching
      A.Bursell @Gertjan
      @gertjan said in Starlink problem with SG2440 22.05:
      netgate.com
      Thanks - I tried. I can't even get out to the DNS test site you linked. I cannot get anywhere with a web browser. I have tried running with pfSense DNS and with forcing outside DNS servers and it fails the same. BUT, if I use another router it works fine. This leads me to believe the problem is in pfSense. The earlier StarLinks could be used without their router - this is a v2 so it is required unfortunately. I would have preferred that as well.
      @serbus said in Starlink problem with SG2440 22.05:
      Hellol!
      I have several round starlink dishes running through sg-1100's.
      Some are on 21.05.2 and others are on 22.05.
      All are running the starlink equipment in router mode (double nat). Bridging was flaky.
      All are running the dns resolver. No forwarding.
      All interfaces connected to starlink have the IPv6 Configuration Type set to NONE.
      I am not seeing any issues resolving netgate.com or any other names. The connections have been stable.
      Have you checked your connection stats and outages?
      John
      Thanks - but it's not an outage issue. It instantly starts working if I swap router for an old Netgear I have here. When I put the SG2440 in, it fails like this every time. And I swap to the other router and it works again.
      Adam
        A.Bursell @stephenw10
        @stephenw10 said in Starlink problem with SG2440 22.05:
        @a-bursell said in Starlink problem with SG2440 22.05:
        DBG(1)[50074]> Fetch: fetching from: https://pkg01-atx.netgate.com/pkg/pfSense_plus-v22_05_amd64-pfSense_plus_v22_05/meta.txz with opts "i"
        pkg: https://pkg01-atx.netgate.com/pkg/pfSense_plus-v22_05_amd64-pfSense_plus_v22_05/meta.txz: Authentication error
        This is odd since there is no authentication on that server. One explanation might be that the clock on your 2440 is so far out the server cert appears invalid. Is that possible?
        That would also break DNSSec (which is enabled by default) for all DNS servers that support it.
        Try disabling DNSSec in the Resolver settings.
        Thanks. I checked and the time is exactly right - pfSense is seeing the correct time and date. I disabled DNSSec anyway - no change.
        Also, just for the heck of it, I went back and changed pfSense to ignore local DNS and use remote DNS - which had no change, and then I forced the DNS on the client to a remote DNS (8.8.8.8) and no change again.
        Adam
          Can that client can ping 8.8.8.8?
          Do you see states in pfSense to 8.8.8.8 on port 53 from the client?
            Client can ping 8.8.8.8 and 1.1.1.1 and 9.9.9.9 ok. Can also ping www.google.com and www.ebay.com -- but cannot ping other addresses like www.netgate.com for example.
            Don't have enough knowledge of states, but here is what it looks like for the client to 8.8.8.8 on port 53: Screenshot 2022-08-17 125116.jpg
            Adam
              Hmm, weird. States look good. It's clearly resolving some things.
              What's the actual error you see when you try to ping netgate.com from the client?
                Not real informative, but it's the usual error...
                  It does imply it is not resolvable though. Which is odd. 8.8.8.8 should be able to resolve that and we can see it is reachable.
                  Something local on that client maybe? Some filtering?
                  Try running a pcap for traffic to/from 8.8.8.8 on the LAN and then try to ping www.netgate.com and see if it's actually sending the query.
                    Steve,
                    Thanks again for continuing to try to help. I don't think it's a client issue, remember I tried the DNS lookups on pfSense and they failed there was well- for SOME sites. And of course when I swap pfSense for the other router everything works as it should on the client.
                    I don't know why, and I know I shouldn't have to, but I'm tempted to try a fresh install of pfSense. If it works it won't give us the answer, and of course if it doesn't work I really don't know. But I have that idea in my back pocket if you think it might be time to try that.
                    I'll run the pcap when I get back in a little bit and report.
                    Adam
                      Yup, sometimes a reinstall helps when nothing else does even though it makes no sense. Usually because there was some obscure setting we forgot about! Hard to see what that could be here though.
                      • S Online
                        serbus
                        Hello!
                        Wild guesses...
                        When swapping routers with the same ip for testing, could there be arp issues?
                        Can pfsense get a webpage the client cant? Diagnostics -> Command Prompt -> Execute shell command :
                        curl -s https://www.pfsense.org
                        curl -s https://www.netgate.com
                        John
                        Lex parsimoniae
                          Thanks - I think I'm getting to that point now.
                          Hello!
                          Wild guesses...
                          John
                          The routers actually have different IPs - never really thought about that mattering. The pfSense is 192.168.2.1 and the Netgear is 10.0.0.1.
                          I tried both of those commands and just saw a shell output command at the top with the same command. I tried it in Putty and again didn't see anything. Not sure what I was supposed to see?
                          Adam
                            A.Bursell
                            Went with the nuclear option and did a fresh install of pfSense 2.6 (can't go to 22.05 unless I get out of the local network). NO CHANGE. I didn't touch any settings except the time, and it is exactly the same. No errors during install, everything looks exactly like it should, but I have the exact same problem.
                            What do I do now?
                            Is it possible there is some type of hardware incompatibility? This is an SG2440 -- it just works and has worked on everything I've ever used it on for years. And it still works -- just not with my Starlink.
                            Thoughts?
                            Adam
                            • S Online
                              serbus
                              Hello!
                              The curl command should show the html served up by the address. No output could mean a lookup error. Verify by using the -sv switch with curl.
                              This thread talks about putting a switch between the starlink v2 ethernet adapter and the customer router to solve a similar (?) problem. Worth a try...
                              John
                              Lex parsimoniae
                              A 2 Replies Last reply Reply Quote 0
                                A.Bursell @serbus
                                Hello!
                                John
                                Well I don't even ... sure enough that thread sounds like exactly the same problem except with a Netgear router (ironiclly my Netgear router works fine), and I did a quick search and even saw the same thing with a Peplink router. There are probably more. I'm going to try the extra switch when I get back later. I don't know why or how it would work, or what the poitential consequences might be, if any, but it's for sure worth a shot.
                                Thanks,
                                Adam
                                  A.Bursell @serbus
                                  @serbus
                                  I'm genuinely surprised, but sure enough- I put a simple unmanaged switch in-between the Starlink and pfSense and it instantly started working. Don't really understand it except that there must be some type of hardware issue with Starlink that conflicts with certain brands of routers? Suppose it could be software too but definitely a Starlink issue. My next stop will be trying to send info to their tech support and getting them to listen and understand. I don't like the idea of having an extra unnecessary switch installed there.
                                  Thank you everyone for your help!
                                  Adam
                                    Hmm, really weird. Hard to see how that could possibly affect some DNS queries only...
                                    • S Online
                                      serbus
                                      Hello!
                                      For reference, here is a teardown of the starlink ethernet adapter. Maybe there is a workaround other than a switch.
                                      John
                                      Lex parsimoniae
                                        A.Bursell
                                        Update! I heard back from Starlink. They were nice enough to let me know I should only have one router in my network and sent instructions on how to change DNS addresses. 🤦 I reopened the ticket, explained again, and asked for it to be escalated to a higher tier support so it can be sent to hardware engineering. We will see.
                                        Adam
