Throughput problems on 4100
Yeah, I read that as using igc as WAN fixed it. In which case it's probably linking differently than ix to whatever is upstream. Potentially with or without flow-control.
You'd have to check the ifconfig output from each to know more.Steve
@stephenw10 igc as WAN fixed it. What would cause this behaviour..?
@gertjan correct. Once I removed ix from the ports used my line is at full speed on all uploads again! Amazing.
Thank you everyone!
@ahxcjay said in Throughput problems on 4100:
I would think it must be something in the link negotiation there. I would check the
ifconfig -vvoutput for each NIC to start with. It 'feels' like a flow control issue. You would see 'rxpause, txpause' in that output. It can be disabled (or enabled) on ix if it is that.Steve
@stephenw10 great info. Thank you! I am so happy this is fixed as I love the product.
@stephenw10 said in Throughput problems on 4100:
I would think it must be something in the link negotiation there. I would check the ifconfig -vv output for each NIC to start with. It 'feels' like a flow control issue. You would see 'rxpause, txpause' in that output. It can be disabled (or enabled) on ix if it is that.
For the one and only 'ix' I use as a WAN to my 1Gbits/sec ISP router, I see :
ix3: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: WAN options=e138bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,WOL_UCAST,WOL_MCAST,WOL_MAGIC,VLAN_HWFILTER,RXCSUM_IPV6,TXCSUM_IPV6> ether 90:ec:77:xx:39:2a inet6 fe80::92ec:77ff:fe29:392a%ix3 prefixlen 64 scopeid 0x8 inet 192.168.10.5 netmask 0xffffff00 broadcast 192.168.10.255 media: Ethernet autoselect (1000baseT <full-duplex,rxpause,txpause>) status: active nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>In short :
media: Ethernet autoselect (1000baseT <full-duplex,rxpause,txpause>)for the port that is in use.
This is normal / not normal ?
Btw : I don't mind for now, as I have 23 Mbits/sec down and 2 Mbits/sec up for now.
Gbit fibre is coming at the end of the month. -
@keyser said in Throughput problems on 4100:
We alle want to help, but it’s not very motivating when posts like yours just flame the product
Fair point, and I apologise. I was just so frustrated that I really really like the product, yet the upload speeds were killing my enjoyment of it. I asked the mods to change $subject to something more appropriate.
The problem is that google searches from people also finds this post, and some people only read headlines….
Understand, and that was in my thinking also, hence the request to change the $subject.
Fair point, and I apologise. I was just so frustrated that I really really like the produt, yet the upload speeds were killing my enjoyment of it. I asked the mods to change $subject to something more appropriate.
This post on the other hand, just earns the full respect of all of us
We can all make mistakes, especially when frustrated - but it takes a real man to own up to it, acknowledge a mistake was made and apologise.
If only all people showed this kind of respect instead of fleeing the “crime scene”, the Internet would be SO much a better place.Thank you for responding and kudos to you
S selfjc referenced this topic on
