    Improving power consumption on Nuc 11 pro
    kmodi915tigerlakenuc 11
    28 Posts 6 Posters 7.1k Views 7 Watching
      ph0ton @keyser
      @keyser I can see that. My biggest wish is a port of Pfsense CE to run on a Raspberry PI Compute Module + df robot router shield. However, I think that would be too disruptive to Netgate's business model.
      • stephenw10S stephenw10 referenced this topic on
        thebear @stephenw10
        @stephenw10 said in Improving power consumption on Nuc 11 pro:
        Just working through this here for the Minnowboard in 2.7. Try this, edit the file /boot/defaults/loader.conf and comment out the line:
        module_blacklist="drm drm2 radeonkms i915kms amdgpu"	# Loader module blacklist
        That should allow it to load at boot as expected in 2.7.
        This one is commented out at my system with 23.01 at default.
        https://vermaden.wordpress.com/2018/11/28/the-power-to-serve-freebsd-power-management/ >> scroll to UPDATE 1 โ€“ Graphics Card Power Saving
        Do you think these new options could help reducing power consumption within 22.05 or 23.01? @ph0ton
        Just added your 3 lines to my 23.01 install, lets monitor.
        added to /boot/loader.conf.local:
        compat.linuxkpi.i915_enable_dc=2
        compat.linuxkpi.i915_enabled_fbc=1
        compat.linuxkpi.i915_disable_power_well=1
          ph0ton @thebear
          Hi @thebear
          Sorry for the late reply... yada yada work yada yada
          Yeah, I think you might get some power consumption improvements out of it. As written in an earlier post, I think it gave around 1W improvement.
          One hiccup I met on the way is that, unless you reboot after removing the display cable, the GPU seem to be in a high power consumption state with display connected, which invalidated some testing. This confused me and the measurements i did on the CPU in the beginning.
          In the end I have concluded that setting the C states is the most effective way of reducing power consumption, rather than trying to initialize the gpu driver. The power savings are not worth it vs the effort.
          Now that the power costs are down in Europe as well, I have decided to leave it until 2.7.0 stable :)
          stephenw10S fireodoF 2 Replies Last reply Reply Quote 0
            stephenw10 Netgate Administrator @ph0ton
            @ph0ton said in Improving power consumption on Nuc 11 pro:
            Tell that to my wallet! ๐Ÿ˜‰
              thebear @stephenw10
              @stephenw10 down down? My provider still uses the 2022 prices, need to wait to April.
              Yes C states is enough, thanks for posting back to me photon.
              • fireodoF Online
                fireodo @ph0ton
                Glad that it works for you - I had here unpredictable shutdowns with C States lower than C1 (The CPU - see my signature - allows max C-State C3)
                Just my 2 cents
                pfsense 2.8.1 CE
                  ph0ton @fireodo
                  @fireodo poops. I have never come a across a machine in the past 15 years how had problems with C-states, unless it was related to instabilities in the BIOS / UEFI bios.
                  @thebear @stephenw10 : I feel for your wallets ๐Ÿ˜… . I pay by the hour, based on "energy zones", which set prices at set intervals during the day. Sometimes I pay nothing (excluding taxes and utitility fees) and sometimes I pay 1.5 eur. If the wind is in the trees, then it's a good day here ;)
                  fireodoF 1 Reply Last reply Reply Quote 2
                  • fireodoF Online
                    fireodo @ph0ton
                    I have now reactivate (because I cannot exclude that maybe something else has caused the shutdowns - at that time I made also some changes regarding the USB-Ports and the update from 2.5.2 -> 2.6.0) the setting: hw.acpi.cpu.cx_lowest=C3 (it sets automatic the dev.cpu.0/1.cx_lowest to C3)
                    and I keep a eye on it and will give feedback if something happends ... ๐Ÿค”
                    Result:
                    dev.cpu.0.cx_usage: 30.82% 69.17% 0.00% last 637us
                    dev.cpu.1.cx_usage: 59.30% 13.53% 27.15% last 267us
                    Interesting: dev.cpu.0 never go to C3 ๐Ÿ˜
                    Edit 09.05.23: After rebooting the system dev.cpu.0 is going also to C3:
                    dev.cpu.0.cx_usage: 62.51% 7.06% 30.42% last 1250us
                    Regards,
                    fireodo
                    pfsense 2.8.1 CE
