    need help setting up!!!
    25 Posts 6 Posters 2.7k Views 6 Watching
      darktech311
      i recently got my hands on a protectli vault and have installed a new version of pfsense on the box but really confused at how to set this up. My goal is to have the box mounted in between my modem Nighthawk modem and Nighthawk wifi router. if anyone can lend any assistance whatsoever would be GREAT.
        Jarhead @darktech311
        @darktech311 It works right after install.
        What do you need help with?
        • jimpJ jimp moved this topic from Problems Installing or Upgrading TNSR Software on
          darktech311 @Jarhead
          @jarhead I have tried several ways to get this thing setup but I just keep striking out. I would like to have my cable line come in to my modem then out to the WAN port on the box . Then out of the LAN port and into my Wi-Fi router. If you can please spread some knowledge my way to be able to get this running that would be amazing.
          • AndyRHA Offline
            AndyRH
            The default config will give your PC an IP. The default gateway is the management interface for pfSense. So point your browser at 192.168.1.1 and you should get the logon page.
            o||||o
            7100-1u
              @darktech311 said in need help setting up!!!:
              Connect the modem to the wan port, then power cycle the modem.
              You should be good from there.
              D 2 Replies Last reply Reply Quote 0
                @jarhead after the modem power cycles I need to make sure that it was assigned a public or private IP Adress.
                  @jarhead as of right now an ethernet cable is connected to the wan port and i showing an ip 192.168.1.199/24.pfsense-image.jpg
                    @darktech311 Should get a public.
                    Is it a modem or modem/router combo?
                    What's the model number?
                    And why do you only have 1 interface?
                      @jarhead i have netgear moden and seperate netgaer wifi router
                      modem is CM1000v2
                      router is AC2300
                      johnpozJ J 2 Replies Last reply Reply Quote 0
                        @jarhead The firewall box i trying to use is a Protectli Vault FW10001
                        • johnpozJ Online
                          johnpoz LAYER 8 Global Moderator @darktech311
                          modem is CM1000v2
                          Your isp is handing out a 192.168.1 address - that seems highly unlikely.. ISP using nat would hand out a cgnat range.. You sure your pfsense box wan, this em0 is plugged into your cm1000 ?
                            modem is CM1000v2
                            router is AC2300
                            How is the router connected?
                            Should be modem right to the pfSense WAN port.
                            Also, are you sure the modem has internet?
                            They will hand out a private address if there's no internet connected.
                            Plug a pc into the modem, power cycle it again, what IP do you get?
                            • johnpozJ Online
                              johnpoz LAYER 8 Global Moderator @Jarhead
                              @jarhead said in need help setting up!!!:
                              Good point - but do they use the 192.168.1 range - everyone I have seen uses 192.168.100 something..
                                Jarhead @johnpoz
                                @johnpoz said in need help setting up!!!:
                                Same here but who knows.
                                My guess is he has his router between the modem and pfSense.
                                • johnpozJ Online
                                  My guess as well..
                                    SteveITS Rebel Alliance @johnpoz
                                    "you have chosen to remove the LAN interface" means it was deleted from the console when it wasn't assigned. I would think if OP assigns LAN then it would work, but since the default IP of pfSense LAN is 192.168.1.1 that IP/subnet would need to be changed since it can't be the same as WAN.
                                    Q: if pfSense is only set up with one interface does it assign its LAN subnet to that interface?
                                    Upvote 👍 helpful posts!
                                    J johnpozJ 2 Replies Last reply Reply Quote 0
                                      Jarhead @SteveITS
                                      @steveits said in need help setting up!!!:
                                      Can't imagine it would. Don't people use 1 interface with vlans in VM's? Maybe even physical?
                                      Plus it would then be 192.168.1.1.
                                      No. I'm sticking with my gut, he still has his router connected.
                                      • johnpozJ Online
                                        johnpoz LAYER 8 Global Moderator @SteveITS
                                        No, it would be wan - but when wan is the only interface it sets rules to be able to access gui from that interface. And as @Jarhead correctly mentions if pfsense was using its default lan IP, then it would be .1 not .199..
                                        Something handed his pfsense wan that IP. Now it could be his isp, but that would be very odd.. I guess not impossible that some ISP is handing out 192.168.1 IPs to its users - but wtf?? Why would they not be using the normal CGNat range of 100.64/10 if they didn't have or didn't want to hand out public IPs to their customers.
                                        And looking, it sure seems the nighthawk modems, the cm1000 he mentions does use the common 192.168.100 range for addresses. So its not his cable modem handing out rfc1918 when it doesn't have a connection to the isp.
                                        https://kb.netgear.com/000059644/How-do-I-log-in-to-my-NETGEAR-cable-modem
                                          I imagine it failed to work initially here because the WAN and LAN were using the same subnet.
                                          If you reset pfSense to the default config and then changed the LAN to, for example: 172.16.1.1/24
                                          If would probably connect OK. It would at least allow access to the gui on the LAN diagnose further.
                                            Jarhead @Jarhead
                                            Can't imagine it would. Don't people use 1 interface with vlans in VM's? Maybe even physical? (yeah, that would then be two interfaces... realized it after I typed it and turned off laptop. 😊
