    "Tailscale is not online" problem
    Scheduled Pinned Locked Moved Tailscale
    56 Posts 14 Posters 18.9k Views 16 Watching
    • chudakC Offline
      chudak @mathwilp1011
      @mathwilp1011
      Today TS is again shows Tailscale is not online. Refresh or check the Tailscale status page.
      The scrip says tailscale has been started.
      But in fact TS is down :(
      WTH
        mcury Rebel Alliance @chudak
        @chudak 4 months later, I think this time frame tell us something.
        Problem should be with tailscale itself, or the other node..
        chudakC 1 Reply Last reply Reply Quote 0
        • chudakC Offline
          chudak @mcury
          @mcury said in "Tailscale is not online" problem:
          Frankly, there is nothing to update and I still did not get to the bottom of it.
          TS sometimes is up and running and very stable for long periods. And then it gets flaky and can't connect.
          I do run "restart_tailscale" script in crontab, so I assume it makes it start.
          But in general, I am puzzled ...
          Any clues?
            @chudak said in "Tailscale is not online" problem:
            Any clues?
            Any logs when the problem starts ?
            What happens when you try to ping the other node ?
            What status it shows in the GUI ?
            I have been using that script with the following scenario, which works fine:
            I have a customer that runs multi WAN in their headquarters.
            One of this links is a CGNAT and other is not.
            The branch office connects directly to the primary non CGNAT link (I have opened a port in the firewall for that connection).
            If a link failover happens in the headquarters, sometimes it loses connections to the TS network and that's when the script "fixes" the problem by forcing the headquarter firewall to restart the service but now using the CGNAT link, thus connecting through the TS node and not a directly connection anymore.
            The reverse is also true, I mean, when the primary link which is not CGNAT comes back online.
            • chudakC Offline
              chudak @mcury
              @mcury
              I don't know exactly where to look :(
              On a high level, only what I see is TS service is green (which is confusing but that's in a different thread and unrelated) and TS connection status is down.
              My use case is:
              pfS runs TS
              iPad runs TS
              iPhone runs TS
              Windows 11 VM runs TS
              So when psF is down, others actually work fine.
              I even noticed that routes get resolved.
                isn't the script working for that ?
                script tries to ping and if it fails, it will restart the service.
                • chudakC Offline
                  chudak @mcury
                  That's an interesting part.
                  Yesterday I found TS down
                  I tried to start it manually, and switched Kea DHCP to ISC DHCP and back, removed /tmp/kea4-ctrl-socket.lock and could not make it start.
                  Then today in the morning - everything is up and running normally
                    I don't see how one thing could interfere with each other.
                    But, I'm still using ISC-DHCP for that customer.
                    Can't switch to KEA yet...
                    • chudakC Offline
                      chudak @mcury
                      Do you know by chance how to catch related to TS stop/start errors/warnings in the logs?
                        You can search old system logs in /var/log directory if I'm not mistaken. Shouldn't be hard to find it, I mean, if problem started yesterday at 15:00hrs, so there you go.
                        • chudakC Offline
                          chudak
                          TS in conjunction with pfS instability is really frustrating
                          I’m travelling now and TS is simply down with the error:
                          Error executing command (/usr/local/bin/tailscale status)
                          Health check:
                          - not logged in, last login error=invalid key: API key does not exist
                          unexpected state: NoState
                          So far nothing I’ve done, rebooting, deleting a lock file, nothing helped.
                          Thx G.. I still have OpenVPN as a backup option.
                          I’m surprised no one else is complaining about this…
                            @chudak did you create the key at the tailscale's console and then imported it to pfsense ?
                            also, set the key to do not expire.
                            • chudakC Offline
                              chudak @mcury
                              I did set my key to not expire.
                              I have used the original key with pfS and did not regenerate it
                              And have seen it’s working normally after this error.
                              So suspecting it’s unrelated
                              I’m hesitant to mess up with keys now as it used to work literally two days ago.
                                Ok, if the problem happens again, try to create a key, import it, and then set it to "don't expire".
                                  mcury Rebel Alliance @mcury
                                  I want to improve the script above to make it "force" direct connections.
                                  Another issue with this script is that its pinging only once and if that ping fails, it stops and then starts the service.
                                  I think it would be much better if the script pings 10 times, and if 10 out of 10 fails, it will restart the service.
                                  This would increase the reliability of the script and also in the same time, make connections leave the relay and connect directly.
                                  But I'm failing to do so, any ideas to improve the code with the insights above in mind ?
                                  Edit:
                                  I think I got it..
                                  1- It will ping "headquarters" 10 times using tailscale.
                                  This will help connections through tailscale prefer "direct" instead of relay.
                                  2- If at least one of the tailscale ping works, it won't do anything.
                                  This will avoid the service to being brought down every time.
                                  3- If all pings fails, it will restart the tailscale service.
                                  #!/bin/sh
                                  DEST="headquarters"
                                  SUCCESS=0
                                  COUNT=0
                                  while [ $COUNT -le 9 ]
                                  do
                                          for DEST in $DEST
                                          do
                                                  COUNT=`expr $COUNT + 1`
                                                  tailscale ping --c 1 -timeout 1s $DEST >/dev/null 2>/dev/null
                                  #                ping -c 1 -t 100 $DEST
                                          if [ $? -eq 0 ]
                                                  then
                                                  SUCCESS=`expr $SUCCESS + 1`
                                          fi
                                          done
                                  done
                                  if [ $SUCCESS -ge 1 ] && [ $COUNT -eq 10 ]
                                          then
                                          exit 0
                                  else
                                                  /usr/local/sbin/pfSsh.php playback svc stop tailscale
                                                  sleep 5
                                                  /usr/local/sbin/pfSsh.php playback svc start tailscale
                                                  sleep 5
                                          exit 1
                                  fi
                                  done
                                  One important observation is, if there are more peers in the tailscale network, you can and should add them to this script.
                                  See, if you are only pinging one host, if that host goes down, the script will take the entire tailscale service down affecting other hosts.
                                  Code for multiple hosts
                                  #!/bin/sh
                                  DEST="server-1"
                                  DEST1="server-2"
                                  DEST2="servier-3"
                                  SUCCESS=0
                                  COUNT=0
                                  do
                                          for DEST in $DEST
                                          do
                                                  tailscale ping --c 1 --timeout 1s $DEST >/dev/null 2>/dev/null
                                          if [ $? -eq 0 ]
                                                  then
                                          fi
                                                  tailscale ping --c 1 --timeout 1s $DEST1 >/dev/null 2>/dev/null
                                  #               ping -c 1 -t 100 $DEST1
                                          if [ $? -eq 0 ]
                                                  then
                                          fi
                                                  tailscale ping --c 1 --timeout 1s $DEST2 >/dev/null 2>/dev/null
                                  #               ping -c 1 -t 100 $DEST2
                                          if [ $? -eq 0 ]
                                                  then
                                          fi
                                          done
                                  done
                                          then
                                          exit 0
                                  else
                                                  sleep 5
                                                  sleep 5
                                          exit 1
                                  fi
                                  done
                                  The code above will sum SUCCESS variable, and if any of the hosts answers, tailscale service will be considered to be UP and no actions will be taken.
                                  • Y Offline
                                    yobyot
                                    I'm late to the party but unless I misunderstand this thread it's not about Tailscale not starting up but instead about the auth key expiring.
                                    Auth keys are good for a maximum of 90 days. If you reboot pfSense on day 91, Tailscale will not come up and the "API" error will be generated (it's actually an auth key expired error).
                                    Thus, unless you never reboot pfSense, starting with the 91st day, you must re-generate an auth key and input it to Tailscale even if you have key expiry disabled.
                                    What makes this worse, IMHO, is that the longer you go between reboots, the more obscure the problem. So, Tailscale is not a reliable service because it cannot survive a reboot after 90 days.
                                    This occurs on both CE 2.7.2 in a Protectli Vault Proxmox VM and on a real SG-1100 running Plus 24.11 (packages as distributed with those releases).
                                    chudakC J 2 Replies Last reply Reply Quote 0
                                    • chudakC Offline
                                      chudak @yobyot
                                      @yobyot said in "Tailscale is not online" problem:
                                      I wish TS would introduce a new feature "a la Acme update" so that this would be done automatically.
                                      Y 1 Reply Last reply Reply Quote 0
                                        Jim Coogan @yobyot
                                        @yobyot I think maybe it is node key expiring at 180 days?
                                        fwiw I have discovered that running in shell
                                        tailscale down
                                        tailscale up --force-reauth
                                        will give you a URL you can then paste in browser and it re authenticates and gets pfsense back online as the same machine and status shows this in pf tailscale UI. This is reauthing the node key.
                                        The node key shouldn't expire when you set it not to on the tailscale admin but I just caught is note on https://tailscale.com/kb/1028/key-expiry
                                        "A change to the Key Expiry value applies to any devices that are logged in after you make the change. The key expiration for any devices that are already logged in remains unchanged, until the next time the device is logged in."
                                        So maybe when we setup pf tailscale and the subsequently disable node key expiring it doesn't take effect until reauth which maybe doesnt happen until --force-reauth and doesn't become apparant until after 180 days?
                                        However, what I don't understand and undermines my theory somewhat is that after doing reauth, at first I noticed that restarting tailscale in pf UI caused me to be logged out again with error "You are logged out. The last login error was: invalid key: API key does not exist"
                                        I manually updated tailscale to 1.84.2 (see https://forum.netgate.com/topic/174525/how-to-update-to-the-latest-tailscale-version/155 but basically run pkg add -f https://pkg.freebsd.org/FreeBSD:15:amd64/latest/All/tailscale-1.84.2.pkg) and then did tailscale down and up --force-reauth and this time it made me resign (I have tailnet lock on) after auth it. Now restarting the service in UI works.
                                        Not sure yet what is going on and what role the new tailscale pkg played. One thing I suspect that maybe also is a factor is the fact that /usr/local/pkg/tailscale/state/tailscaled.state is the state file with node key instead of the standard /var/db/tailscale/tailscaled.state could be a factor On pf tailscale, /usr/local/etc/rc.d/tailscaled uses /var/db/tailscale/tailscaled.state as state directory so maybe sometimes somehow tailscale is looking for state there and it doesn't exist.
                                        But this wouldn't really explain why everything is fine for a while initially (usually 90 to 180 days Im not exactly sure in my case). This may explain why it logs out on reboot if you if you use ram disk though.
                                        M 1 Reply Last reply Reply Quote 2
                                        • Y Offline
                                          yobyot @chudak
                                          @chudak Yup. That's exactly what we need for this to be reliable.
                                            AlphaDog45
                                            I am also effected by this and it happened upon a reboot within the 180 day key expiry. Running the tailscale down and up with reuath, followed by pasting the URL into a browser fixes it, but is far from ideal.
