    Upgrade to 23.01 WAN speed halved
    106 Posts 19 Posters 37.9k Views 17 Watching
    • stephenw10S Online
      Has anyone been able to test this in a FreeBSD 14 snapshot?
        superbree @stephenw10
        I see that 23.05 beta has been released. Has anyone tried it to see if this fixes the problem or if they're even trying to?
          There are no changes to the cxgbe driver in 23.05 yet. I would not expect any difference.
          The maintainer is investigating.
            debo4479 @stephenw10
            Per comments on redmine bug, no change with 23.05
            https://redmine.pfsense.org/issues/14207
              It would very helpful if anyone hitting this can test a FreeBSD 14 snapshot. That would allow us to rule out any changes pfSense might be doing. It will also give the driver maintainer something specific to test against.
                I spun up a FreeBSD14 VM on Unraid and it does not find drive for my T520-CR. It says no driver attached. I have attached screenshot of both boot log and pciconf.
                  You might have to load the module in FreeBSD:
                  kldload if_cxbge
                    If I run that command I get "can't load if_cxbge: No such file or directory"
                    I can see the file in /boot/kernel/ does that mean it is already loaded?
                    I even tried to load from that directory and same message. Even tried with sudo. I am mostly windows guy so maybe I am just doing something wrong.
                      Try using the full path:
                      kldload /boot/kernel/if_cxgbe.ko
                        @stephenw10 said in Upgrade to 23.01 WAN speed halved:
                        if_cxbge
                        Oh I typo'd it!
                        kldload if_cxgbe
                          Duh, I should have picked that up.
                          OK I was able to load and pull ip address. I tried iperf3 - s and I doesn't look like it is installed by default.
                          UPDATE: ok, got it installed. below are my results using chelsio t520-cr
                            That's the send rate, the iperf3 client sends by default. If you run it reversed -R do you see the half speed when receiving?
                              I was running iperf3 server on FreeBSD14 so it was receiving. Screenshot is me sending data from unraid host.
                                But you see full line rate both ways?
                                What does ifconfig -vvvm cxl0 show under FreeBSD 14? It could just be different off loading options set.
                                  Yes, both ways look good
                                  output of ifconfig
                                    Hmm, well it appears to have similar hardware off-loading options enabled but I don't have anything to compare it with directly. Do you have that same output from pfSense 23.01?
                                    pfSense has TSO and LRO disabled by default. Both are enabled there. You might try disabling those and retesting.
                                      SteveITS Rebel Alliance @stephenw10
                                      Those with Chelsio hardware might want to review this thread:
                                      @user1337 said in Reroot exposes SSH, Telnet, Web UI to WAN:
                                      ...I found the answer: https://calomel.org/freebsd_chelsio_toe_firewall.html:
                                      The Chelsio Offload Policy (COP) manages when the TCP Offload Engine (TOE) takes affect allowing the card to only offload TCP connections which you want to offload and leave the other connection to the default FreeBSD TCP stack.
                                      SECURITY NOTE: The Chelsio TCP Offload Engine (TOE) will completely bypass the FreeBSD TCP stack as well as any Chelsio filter rules. This means that traffic using TOE will NOT be filtered using our Chelsio Rules of Engagement filter rules or the Pf packet filter, nor will Pf log TOE connections. Netstat will show the connections using "netstat -np tcp" though.
                                      Upvote 👍 helpful posts!
                                        Ok this appears to be due to ratelimiting in the kernel. Thanks to the Chelsio driver maintainer who dug that out.
                                        If you're seeing this please try setting the following loader value:
                                        hw.cxgbe.niccaps_allowed="1"
                                        Add that to /boot/loader.conf.local
                                        Create that file if it doesn't exist.
                                        Let us know if that removes the issue.
                                        D J B 3 Replies Last reply Reply Quote 4
                                          Looks good after upgrading to 23.01, creating that file and adding the entry. Also went to 23.05 and speed still looks good.
                                          Thanks for getting this figured out.
                                            battlebot32
                                            @stephenw10 Thank you for posting this.
                                            I applied the hw.cxgbe.niccaps_allowed="1" value to the /boot/loader.conf.local file as recommended and after a reboot I am also seeing correct speeds. Full gigabit out the WAN interface up and down along with full 10gb speeds to an internal speed test server that I host. This appears to be the fix to this issue. Thank you for all that you do!
