    Upgrade to 23.01 WAN speed halved
    106 Posts 19 Posters 44.9k Views 17 Watching
      JensErling @stephenw10
      @stephenw10 I have been using this fix for a while now and it is working great on version 23.05. Thank you to everyone that has put in an effort to solve the problem, it is much appreciated! :)
        bigtimmyc @stephenw10
        @stephenw10 I have added this line to my bootloader but I have not seen any performance change.
        I am running a T422-CR card on 23.05.1-RELEASE of PFsense+
          What speed are you seeing now? What CPU is that system running?
          Did you see the throughput go down after upgrading? From something before 23.01?
          B 3 Replies Last reply Reply Quote 0
            @stephenw10 I appear to be capped at 470mbs. This issue appeared to happen back in April when I upgraded from the latest CE to Pfsense plus back then. I didnโ€™t realise there was a specific Chelsio fix potentially so I had not attempted to rectify.
            CPU is an Intel 4th gen Xeon 1230 v3. It barely sits above a couple of percent when speed testing.
            Hereโ€™s a copy of my boot log after adding in the tuning variable suggested:
            https://pastebin.com/fUSVp71K
            Iโ€™m not too familiar in with what a normal output in the boot log should look like
              @stephenw10 here is my conf file:
              Here are my advanced network settings:
                @stephenw10 Looking through that bootlog I can see the following referencing the card:
                pci1: <ACPI PCI bus> on pcib1
                pci1: <network, ethernet> at device 0.2 (no driver attached)
                pci1: <network, ethernet> at device 0.3 (no driver attached)
                t4nex0: <Chelsio T422-CR> mem 0xdf080000-0xdf0bffff,0xde800000-0xdeffffff,0xdf344000-0xdf345fff irq 16 at device 0.4 on pci1
                cxgbe0: <port 0> on t4nex0
                cxgbe0: Ethernet address: 98:be:94:5a:23:80
                cxgbe0: 16 txq, 16 rxq (NIC); 8 txq (ETHOFLD)
                cxgbe1: <port 1> on t4nex0
                cxgbe1: Ethernet address: 98:be:94:5a:23:88
                cxgbe1: 16 txq, 16 rxq (NIC); 8 txq (ETHOFLD)
                cxgbe2: <port 2> on t4nex0
                cxgbe2: Ethernet address: 98:be:94:5a:23:90
                cxgbe2: 16 txq, 16 rxq (NIC); 8 txq (ETHOFLD)
                cxgbe3: <port 3> on t4nex0
                cxgbe3: Ethernet address: 98:be:94:5a:23:98
                cxgbe3: 16 txq, 16 rxq (NIC); 8 txq (ETHOFLD)
                t4nex0: PCIe gen2 x8, 4 ports, 66 MSI-X interrupts, 164 eq, 65 iq
                pci1: <mass storage, SCSI> at device 0.5 (no driver attached)
                pci1: <serial bus, Fibre Channel> at device 0.6 (no driver attached)
                pci1: <network, ethernet> at device 0.7 (no driver attached)
                  Do you see that set in the sysctl output after adding it to the loader file?
                    I can't see them set in System/Advanced/System Tunables - is this where I should be checking?
                      Run at the CLI: sysctl hw.cxgbe
                        @stephenw10 This is my output:
                        hw.cxgbe.tx_coalesce_gap: 5
                        hw.cxgbe.tx_coalesce_pkts: 32
                        hw.cxgbe.tx_coalesce: 1
                        hw.cxgbe.defrags: 0
                        hw.cxgbe.pullups: 12
                        hw.cxgbe.lro_mbufs: 0
                        hw.cxgbe.lro_entries: 8
                        hw.cxgbe.tscale: 1
                        hw.cxgbe.eo_max_backlog: 1048576
                        hw.cxgbe.tsclk: -1
                        hw.cxgbe.safest_rx_cluster: 4096
                        hw.cxgbe.largest_rx_cluster: 16384
                        hw.cxgbe.fl_pack: -1
                        hw.cxgbe.buffer_packing: -1
                        hw.cxgbe.ofld_cong_drop: 0
                        hw.cxgbe.cong_drop: 0
                        hw.cxgbe.spg_len: 64
                        hw.cxgbe.fl_pad: -1
                        hw.cxgbe.fl_pktshift: 0
                        hw.cxgbe.nm_txcsum: 0
                        hw.cxgbe.nm_split_rss: 0
                        hw.cxgbe.lazy_tx_credit_flush: 1
                        hw.cxgbe.starve_fl: 0
                        hw.cxgbe.nm_cong_drop: 1
                        hw.cxgbe.nm_holdoff_tmr_idx: 2
                        hw.cxgbe.nm_rx_nframes: 64
                        hw.cxgbe.nm_rx_ndesc: 256
                        hw.cxgbe.nm_black_hole: 0
                        hw.cxgbe.tls.combo_wrs: 0
                        hw.cxgbe.tls.inline_keys: 0
                        hw.cxgbe.kern_tls: 0
                        hw.cxgbe.cop_managed_offloading: 0
                        hw.cxgbe.drop_pkts_with_l4_errors: 0
                        hw.cxgbe.drop_pkts_with_l3_errors: 0
                        hw.cxgbe.drop_pkts_with_l2_errors: 1
                        hw.cxgbe.drop_ip_fragments: 0
                        hw.cxgbe.attack_filter: 0
                        hw.cxgbe.tx_vm_wr: 0
                        hw.cxgbe.clock_gate_on_suspend: 0
                        hw.cxgbe.reset_on_fatal_err: 0
                        hw.cxgbe.panic_on_fatal_err: 0
                        hw.cxgbe.pcie_relaxed_ordering: 0
                        hw.cxgbe.num_vis: 1
                        hw.cxgbe.fcoecaps_allowed: 0
                        hw.cxgbe.iscsicaps_allowed: 0
                        hw.cxgbe.cryptocaps_allowed: -1
                        hw.cxgbe.rdmacaps_allowed: 0
                        hw.cxgbe.toecaps_allowed: 0
                        hw.cxgbe.niccaps_allowed: 97
                        hw.cxgbe.switchcaps_allowed: 3
                        hw.cxgbe.linkcaps_allowed: 0
                        hw.cxgbe.nbmcaps_allowed: 0
                        hw.cxgbe.fw_install: 1
                        hw.cxgbe.autoneg: -1
                        hw.cxgbe.force_fec: -1
                        hw.cxgbe.fec: -1
                        hw.cxgbe.pause_settings: 7
                        hw.cxgbe.config_file: default
                        hw.cxgbe.interrupt_types: 7
                        hw.cxgbe.qsize_rxq: 1024
                        hw.cxgbe.qsize_txq: 1024
                        hw.cxgbe.holdoff_pktc_idx: -1
                        hw.cxgbe.holdoff_timer_idx: 1
                        hw.cxgbe.nnmrxq_vi: 2
                        hw.cxgbe.nnmtxq_vi: 2
                        hw.cxgbe.nnmrxq: 8
                        hw.cxgbe.nnmtxq: 8
                        hw.cxgbe.native_netmap: 2
                        hw.cxgbe.holdoff_pktc_idx_ofld: -1
                        hw.cxgbe.holdoff_timer_idx_ofld: 1
                        hw.cxgbe.nofldrxq_vi: 1
                        hw.cxgbe.nofldtxq_vi: 1
                        hw.cxgbe.nofldrxq: 2
                        hw.cxgbe.nofldtxq: 8
                        hw.cxgbe.rsrv_noflowq: 0
                        hw.cxgbe.nrxq_vi: 1
                        hw.cxgbe.ntxq_vi: 1
                        hw.cxgbe.nrxq: 16
                        hw.cxgbe.ntxq: 16
                        hw.cxgbe.toe.rexmt_backoff.15: -1
                        hw.cxgbe.toe.rexmt_backoff.14: -1
                        hw.cxgbe.toe.rexmt_backoff.13: -1
                        hw.cxgbe.toe.rexmt_backoff.12: -1
                        hw.cxgbe.toe.rexmt_backoff.11: -1
                        hw.cxgbe.toe.rexmt_backoff.10: -1
                        hw.cxgbe.toe.rexmt_backoff.9: -1
                        hw.cxgbe.toe.rexmt_backoff.8: -1
                        hw.cxgbe.toe.rexmt_backoff.7: -1
                        hw.cxgbe.toe.rexmt_backoff.6: -1
                        hw.cxgbe.toe.rexmt_backoff.5: -1
                        hw.cxgbe.toe.rexmt_backoff.4: -1
                        hw.cxgbe.toe.rexmt_backoff.3: -1
                        hw.cxgbe.toe.rexmt_backoff.2: -1
                        hw.cxgbe.toe.rexmt_backoff.1: -1
                        hw.cxgbe.toe.rexmt_backoff.0: -1
                        hw.cxgbe.toe.rexmt_count: 0
                        hw.cxgbe.toe.rexmt_max: 0
                        hw.cxgbe.toe.rexmt_min: 0
                        hw.cxgbe.toe.keepalive_count: 0
                        hw.cxgbe.toe.keepalive_interval: 0
                        hw.cxgbe.toe.keepalive_idle: 0
                        hw.cxgbe.clip_db_auto: 1
                          bigtimmyc @bigtimmyc
                          @bigtimmyc said in Upgrade to 23.01 WAN speed halved:
                          97 doesn't seem right
                            Indeed it doesn't! Though I don't have one of those NICs to test it.
                            If you comment out those loader lines or remove the file does it change after rebooting?
                            B 2 Replies Last reply Reply Quote 0
                              @stephenw10 New output:
                              hw.cxgbe.defrags: 0
                              hw.cxgbe.pullups: 9
                              hw.cxgbe.tscale: 1
                              hw.cxgbe.tsclk: -1
                              hw.cxgbe.fl_pad: -1
                              hw.cxgbe.num_vis: 1
                              hw.cxgbe.iscsicaps_allowed: 67
                              hw.cxgbe.rdmacaps_allowed: 3
                              hw.cxgbe.toecaps_allowed: 1
                              hw.cxgbe.fec: -1
                              hw.cxgbe.nnmrxq: 8
                              hw.cxgbe.nnmtxq: 8
                              hw.cxgbe.nrxq_vi: 1
                              hw.cxgbe.ntxq_vi: 1
                              hw.cxgbe.nrxq: 16
                              hw.cxgbe.ntxq: 16
                              niccaps appears to be unchanged after commented out all lines in the conf file
                                @stephenw10 I have found the problem. I'm too trusting of copy-pasting directly from the Pfsense docs. I've been stitched up by non-standard quotation characters.
                                Incorrect quotations around "1"
                                Corrected:
                                And won't you look at that ๐Ÿ˜ :
                                bmeeksB S 2 Replies Last reply Reply Quote 0
                                • bmeeksB Offline
                                  bmeeks @bigtimmyc
                                  Corrected:
                                  I don't think it was the quotes. If you look, they are exactly the same. Its the "#" sign at the start of each line. That is the special code for "a comment follows", and so the system ignores everything after the pound sign (#) up until it sees the end of the current line. The # character is used to "comment out" a line.
                                  M S B 3 Replies Last reply Reply Quote 0
                                    Misterb @bmeeks
                                    @bmeeks said in Upgrade to 23.01 WAN speed halved:
                                    I don't think it was the quotes. If you look, they are exactly the same...
                                    No they aren't, if you look closely at the quotes around the "1", in the first pane they are sloping quotes and in the second the normal double quote character.
                                    bmeeksB 1 Reply Last reply Reply Quote 1
                                      SteveITS Galactic Empire @bmeeks
                                      @bmeeks he means the quote marks: โ€œ
                                      In the first image the โ€œ on the first line ane angled. Iโ€™ve been there once or twice in my computing time (not pfSense related), itโ€™s not fun to discover.
                                      Upvote ๐Ÿ‘ helpful posts!
                                        bigtimmyc @bmeeks
                                        @bmeeks sorry for the confusion, I just reposted my snip from the comment before yours, hence why the lines were still commented
                                        • bmeeksB Offline
                                          bmeeks @Misterb
                                          @Misterb said in Upgrade to 23.01 WAN speed halved:
                                          Okay, I do see a difference now, but the removal of the "#" character is also necessary unless that is supposed to be part of the console shell prompt. I thought you were posting the dump of a local file.
                                            SteveITS Galactic Empire @bigtimmyc
                                            @bigtimmyc Did the page get fixed already? It looks OK if I copy/paste to Word. If not there's a "Give Feedback" link the upper right of every doc page.
