    How to read RTTsd and why is it not the same everywhere in pfSense
    29 Posts 4 Posters 5.4k Views 6 Watching
    • dennypageD Offline
      dennypage @stephenw10
      @stephenw10 FWIW, the math for a standard deviation is actually simple. What is difficult, and why it looks a bit complicated in dpinger.c, is doing it using integer math. Floating point math is much simpler.
      • L Offline
        Leon Straathof @dennypage
        @dennypage ah that makes sense, i am used to converting math to FP as it is a more 1:1 approach and easier to see the original formula in it.
        • RobbieTTR Offline
          RobbieTT @Leon Straathof
          @leon-straathof said in How to read RTTsd and why is it not the same everywhere in pfSense:
          I am really happy with my connection, no real complaints. But i use Geforce Now for gaming and i want to get as little delay/hicups as possible. On occasion i have a little stutter so i wanted to make sure nothing was not optimal at my end. You don't need gbit connection most of the time speed is just a nice to have, a rock solid stable connection is much more important to me.
          Ok, sounds like you need to setup a QoS such as FQ_CoDel. I'm envious of your upload bandwidth but without FQ_CoDel running my buffer-bloat grade would be the same as yours, or worse.
          I have to run my connection pretty hard at times and I have some propriety things going on that are latency and jitter sensitive. As such, QoS management is vital to me. If you always have bandwidth to spare then, other than during speedtests or major file transfers, you are unlikely to see a QoS or buffer-bloat issues in real-world usage, given your 1 GbE symmetrical service.
          • L Offline
            @dennypage Not sure what to look for in the traceroutes but here they are. Also i monitor 1.1.1.1 now with 64 byte payload and it looks better then before but still lots of spikes as can be seen in the screenshot. And this is without any mayor traffic, most of the time less then 1Mbit.
            traceroute 1.1.1.1
            traceroute to 1.1.1.1 (1.1.1.1), 64 hops max, 40 byte packets
            1 1-170-212-87.ftth.glasoperator.nl (87.212.170.1) 2.631 ms 2.082 ms 1.891 ms
            2 10.10.17.41 (10.10.17.41) 5.152 ms 5.066 ms 5.208 ms
            3 10.10.12.61 (10.10.12.61) 5.213 ms 4.924 ms 5.251 ms
            4 172.70.44.4 (172.70.44.4) 37.996 ms
            141.101.65.14 (141.101.65.14) 34.639 ms
            172.71.180.2 (172.71.180.2) 6.427 ms
            5 80.249.210.118 (80.249.210.118) 6.045 ms
            ams-ix.as13335.net (80.249.211.140) 5.848 ms
            80.249.210.118 (80.249.210.118) 6.032 ms
            6 172.71.92.2 (172.71.92.2) 13.773 ms
            172.71.96.4 (172.71.96.4) 5.373 ms
            172.71.180.4 (172.71.180.4) 5.379 ms
            7 one.one.one.one (1.1.1.1) 5.292 ms 5.346 ms *
            traceroute -I 1.1.1.1
            traceroute to 1.1.1.1 (1.1.1.1), 64 hops max, 48 byte packets
            1 1-170-212-87.ftth.glasoperator.nl (87.212.170.1) 2.488 ms 1.947 ms 1.255 ms
            2 10.10.17.41 (10.10.17.41) 5.132 ms 4.891 ms 5.207 ms
            3 10.10.12.61 (10.10.12.61) 5.163 ms 5.500 ms 4.335 ms
            4 172.71.92.4 (172.71.92.4) 5.914 ms 18.543 ms 6.637 ms
            5 80.249.210.118 (80.249.210.118) 5.862 ms 5.289 ms 5.616 ms
            6 172.71.92.4 (172.71.92.4) 5.499 ms 5.163 ms 5.578 ms
            7 one.one.one.one (1.1.1.1) 5.189 ms 5.204 ms 5.325 ms
            • L Offline
              Leon Straathof @RobbieTT
              @robbiett Thanks for the advice of setting up QoS, i will sure do that after i am convinced that i have no other problems. I have learned when troubleshooting not to change multiple settings in one go so it's very clear if a setting did or did not do anything. However thats why i looked manually that when i posted stuff here that the traffic was very low (less then 10% of what i have should do the trick, but most of the time it was even a lot less) i should not experience bufferbloat if there is hardly any traffic.
              • RobbieTTR Offline
                @leon-straathof Yep, all sensible. Later down the line you will find that FQ_CoDel can help advance smaller packets through the stack, ahead of larger ones.
                The previous advice from @dennypage still stands though, as pinging the first link with your ISP will take a great deal of the internet variables & noise out of the collect. Remember, the return of IGMP packets is pretty much at the bottom of a downstream router's priority list.
                  dennypage @Leon Straathof
                  traceroute 1.1.1.1
                  I didn't realize that you were in Amsterdam. Small distances. Your time to 1.1.1.1 makes sense.
                  Notice the high variance in the responses? Hop #1 (87.212.170.1) shows particularly high, which is what I believe you were initially monitoring. I'm guessing that is a neighborhood splitter.
                  Couple of opinions I would offer based on these results: First, the first real DC hop in that list is #2 (10.10.17.41) which is a little under 5ms away. And second, I believe that the local Cloud Flare instance is very, very near to your ISP's datacenter, if not actually in the same location.
                  I would not recommend the nearby splitter for monitoring. Not only will this have higher variance, but more importantly it will likely continue to respond to to ICMP even if the splitter looses connection with the DC. In other words, your internet will be down but pfSense will not know.
                  Other than that, I wouldn't worry too much about the stddev. I would see to the buffer bloat issue though.
                  L 1 Reply Last reply Reply Quote 2
                  • L Offline
                    @dennypage Thanks for all the help, now you explain it yes the 87.212.170.1 i was monitoring must be a neighborhood splitter. And since the difference between 10.10.17.41 and 1.1.1.1 is so small i think i keep it pointing to 1.1.1.1. This way even a complete outage of my ISP is visible. And yes i live in the Netherlands although not next to Amsterdam (i live in the south of our country). Our country is not that big so even though the Belgium border is very close, it's only 75km (47 miles) in a straight line to Amsterdam.
                    I agree the bufferbloat is a more severe problem, although only visible when there is a lot of traffic, which i do not have often and if only for short periodes.
                    I found this: https://docs.netgate.com/pfsense/en/latest/hardware/tune.html it states to modify something when you have vmx network cards and more then 1 core assigned to the VM. Since i am coming from much slower DSL i always used just 1 core for pfSense. I increased it to 2 now i have fiber. But i guess the traffic is still handeled by 1 core this way without this tuning.
                      Yeah if you don't disable the blacklist you will only get one queue for Rx and Tx on a vmx NIC. As you say for a PPP connection that won't make any difference but for anything else it will.
