    WAN speed to ISP
    26 Posts 5 Posters 2.7k Views 5 Watching
    • RobbieTTR Offline
      RobbieTT @timbaeten
      @timbaeten said in WAN speed to ISP:
      @stephenw10 Here is what the status page shows:
      WAN (ix3)
      Media 1000baseT <full-duplex,rxpause,txpause>
      Lan (igc0)
      Media 1000baseT <full-duplex>
      It probably does not matter in this case but I find it odd that a interface being used as a WAN port would default to having flow control set to "on" (although this seems to be an ix interface thing).
      I could just about stretch my mind to having flow control enabled on a LAN port, where you could match switch and other local settings; but really even that could be questionable.
      now I'm getting a couple hundred more bps, 700mbs vs the 500 I was getting on wan1. Curiouser and curiouser.
      Can you confirm again that your latest speed test was via a laptop directly plugged into igc0 and connected to an external speed test site on an ix port via either a RJ45 plug or a SFP module:
      • stephenw10S Online
        Yes, ix defaults to using flow-control if the other side supports it.
        Odd that using ix2 made any difference. Those ports should be identical.
        I would try assigning WAN to one of the igc ports as a test. If you see full rate there it's clearly a problem with the default settings on the ix ports.
          martys
          Something that I had to do to improve my download speed was to change the bandwidth settings for the interfaces in the Firewall > Traffic Shaper page.
          I was seeing a value of 209715.2 Kbits there so I changed each to 2 Gbit (I have a 5100 with 6x1 Gb interfaces). A setting of 1 Gbit gave a lower download speed than the 2 Gbit setting.
          I suppose I could have just disabled the Enabled checkboxes for each interface. I figured they were enabled for a reason…
          I went from a very consistent 200 Mb download before these changes to 600-700 Mb. Not the full 1 Gb from the ISP (and that I can see via speed tests directly on the modem), but much better for those rare times that I'm sucking down data by the bucket full.
            The first thing to try is just removing all the shaping and make sure it can pass the expected bandwidth. If you are using the shaper that is.
              timbaeten @SteveITS
              @SteveITS @stephenw10 @RobbieTT After a bunch more testing, it could just be that running speedtest from the command line on pfSense is really a problem and it's returning misleading results. Since moving to WAN2 (RJ45), I'm getting north of 800mps on anything I connect to LAN1; be it directly or through an external switch. We haven't explained why WAN2 is any different than WAN1 (RJ45).
              Thanks very much for the help! Tim
                Mmm, is that in line with what you get when connected directly?
                I agree WAN1 and WAN2 should be identical. I would still test using one of the igc NICs as WAN if you can. If there's some low level issue with the ix NIC/driver the igc NIC may not hit that.
