    Setting up fibre internet connection does not work
    13 Posts 5 Posters 1.9k Views 4 Watching
      Art Mooney
      I just changed internet service providers (DSL to fibre). The provider sent me a FritzBox that I can connect to a Genexis FiberTwist-P2411. If I do that, the internet connection works. Now, I want to remove the FritzBox and establish the connection using pfsense. I received user name and password from the service provider and configured the WAN interface PPPoe-connection using these credentials. Unfortunately, there is no connection.
      I am uncertain, where the error is. I managed to decrypt the FritzBox configuration file, which appears to suggest that no particular VLAN tag is needed (VLAN tag 0 means no VLAN, correct?). I looked into the PPP log file, which is shown below.
      I read that some ISPs use MAC filters. Thus, I changed the MAC address of the corresponding LAN interface to the one of the LAN1 NIC of the FritzBox. Did not change anything.
      As I do not want to fill this post with useless data, I am not adding the decrypted FritzBox configuration file, but can do so, if helpful. I hope that someone can already give me a hint based on the PPP log below.
      Many thanks!
      PPP-log:
      Jun 25 15:14:08 	ppp 	95334 	[wan_link0] AUTHPROTO CHAP MD5
      Jun 25 15:14:08 	ppp 	95334 	[wan_link0] MAGICNUM 0x5d65ab2f
      Jun 25 15:14:08 	ppp 	95334 	[wan_link0] LCP: SendConfigAck #227
      Jun 25 15:14:08 	ppp 	95334 	[wan_link0] MRU 1492
      Jun 25 15:14:08 	ppp 	95334 	[wan_link0] LCP: state change Req-Sent --> Ack-Sent
      Jun 25 15:14:08 	ppp 	95334 	[wan_link0] LCP: rec'd Configure Ack #19 (Ack-Sent)
      Jun 25 15:14:08 	ppp 	95334 	[wan_link0] PROTOCOMP
      Jun 25 15:14:08 	ppp 	95334 	[wan_link0] MAGICNUM 0xafb99310
      Jun 25 15:14:08 	ppp 	95334 	[wan_link0] LCP: state change Ack-Sent --> Opened
      Jun 25 15:14:08 	ppp 	95334 	[wan_link0] LCP: auth: peer wants CHAP, I want nothing
      Jun 25 15:14:08 	ppp 	95334 	[wan_link0] LCP: LayerUp
      Jun 25 15:14:08 	ppp 	95334 	[wan_link0] CHAP: rec'd CHALLENGE #205 len: 28
      Jun 25 15:14:08 	ppp 	95334 	[wan_link0] Name: "JUNOS"
      Jun 25 15:14:08 	ppp 	95334 	[wan_link0] CHAP: Using authname ""
      Jun 25 15:14:08 	ppp 	95334 	[wan_link0] CHAP: sending RESPONSE #205 len: 31
      Jun 25 15:14:09 	ppp 	95334 	[wan_link0] CHAP: rec'd FAILURE #205 len: 4
      Jun 25 15:14:09 	ppp 	95334 	[wan_link0] LCP: authorization failed
      Jun 25 15:14:09 	ppp 	95334 	[wan_link0] LCP: parameter negotiation failed
      Jun 25 15:14:09 	ppp 	95334 	[wan_link0] LCP: state change Opened --> Stopping
      Jun 25 15:14:09 	ppp 	95334 	[wan_link0] LCP: SendTerminateReq #20
      Jun 25 15:14:09 	ppp 	95334 	[wan_link0] LCP: LayerDown
      Jun 25 15:14:09 	ppp 	95334 	[wan_link0] LCP: rec'd Terminate Request #228 (Stopping)
      Jun 25 15:14:09 	ppp 	95334 	[wan_link0] LCP: SendTerminateAck #21
      Jun 25 15:14:09 	ppp 	95334 	[wan_link0] PPPoE: connection closed
      Jun 25 15:14:09 	ppp 	95334 	[wan_link0] Link: DOWN event
      Jun 25 15:14:09 	ppp 	95334 	[wan_link0] LCP: Down event
      Jun 25 15:14:09 	ppp 	95334 	[wan_link0] LCP: state change Stopping --> Starting
      Jun 25 15:14:09 	ppp 	95334 	[wan_link0] Link: reconnection attempt 7 in 2 seconds
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] Link: reconnection attempt 7
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] PPPoE: Connecting to ''
      Jun 25 15:14:11 	ppp 	95334 	PPPoE: rec'd ACNAME "mx3.ham"
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] PPPoE: connection successful
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] Link: UP event
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] LCP: Up event
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] LCP: state change Starting --> Req-Sent
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] LCP: SendConfigReq #22
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] PROTOCOMP
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] MRU 1492
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] MAGICNUM 0xbecdc336
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] LCP: rec'd Configure Request #101 (Req-Sent)
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] AUTHPROTO CHAP MD5
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] MAGICNUM 0x4a81c5df
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] LCP: SendConfigAck #101
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] LCP: state change Req-Sent --> Ack-Sent
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] LCP: rec'd Configure Ack #22 (Ack-Sent)
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] LCP: state change Ack-Sent --> Opened
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] LCP: auth: peer wants CHAP, I want nothing
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] LCP: LayerUp
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] CHAP: rec'd CHALLENGE #172 len: 26
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] Name: "JUNOS"
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] CHAP: Using authname ""
      Jun 25 15:14:11 	ppp 	95334 	[wan_link0] CHAP: sending RESPONSE #172 len: 31
      Jun 25 15:14:12 	ppp 	95334 	[wan_link0] CHAP: rec'd FAILURE #172 len: 4
      Jun 25 15:14:12 	ppp 	95334 	[wan_link0] LCP: authorization failed
      Jun 25 15:14:12 	ppp 	95334 	[wan_link0] LCP: parameter negotiation failed
      Jun 25 15:14:12 	ppp 	95334 	[wan_link0] LCP: state change Opened --> Stopping
      Jun 25 15:14:12 	ppp 	95334 	[wan_link0] LCP: SendTerminateReq #23
      Jun 25 15:14:12 	ppp 	95334 	[wan_link0] LCP: LayerDown
      Jun 25 15:14:12 	ppp 	95334 	[wan_link0] LCP: rec'd Terminate Request #102 (Stopping)
      Jun 25 15:14:12 	ppp 	95334 	[wan_link0] LCP: SendTerminateAck #24
      Jun 25 15:14:12 	ppp 	95334 	[wan_link0] PPPoE: connection closed
      Jun 25 15:14:12 	ppp 	95334 	[wan_link0] Link: DOWN event
      Jun 25 15:14:12 	ppp 	95334 	[wan_link0] LCP: Down event
      Jun 25 15:14:12 	ppp 	95334 	[wan_link0] LCP: state change Stopping --> Starting
      Jun 25 15:14:12 	ppp 	95334 	[wan_link0] Link: reconnection attempt 8 in 3 seconds
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] Link: reconnection attempt 8
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] PPPoE: Connecting to ''
      Jun 25 15:14:16 	ppp 	95334 	PPPoE: rec'd ACNAME "mx3.ham"
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] PPPoE: connection successful
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] Link: UP event
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] LCP: Up event
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] LCP: state change Starting --> Req-Sent
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] LCP: SendConfigReq #25
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] PROTOCOMP
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] MRU 1492
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] MAGICNUM 0xc2df295a
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] LCP: rec'd Configure Request #226 (Req-Sent)
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] AUTHPROTO CHAP MD5
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] MAGICNUM 0x1d83f5be
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] LCP: SendConfigAck #226
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] LCP: state change Req-Sent --> Ack-Sent
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] LCP: rec'd Configure Ack #25 (Ack-Sent)
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] LCP: state change Ack-Sent --> Opened
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] LCP: auth: peer wants CHAP, I want nothing
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] LCP: LayerUp
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] CHAP: rec'd CHALLENGE #60 len: 39
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] Name: "JUNOS"
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] CHAP: Using authname ""
      Jun 25 15:14:16 	ppp 	95334 	[wan_link0] CHAP: sending RESPONSE #60 len: 31
      Jun 25 15:14:17 	ppp 	95334 	[wan_link0] CHAP: rec'd FAILURE #60 len: 4
      Jun 25 15:14:17 	ppp 	95334 	[wan_link0] LCP: authorization failed
      Jun 25 15:14:17 	ppp 	95334 	[wan_link0] LCP: parameter negotiation failed
      Jun 25 15:14:17 	ppp 	95334 	[wan_link0] LCP: state change Opened --> Stopping
      Jun 25 15:14:17 	ppp 	95334 	[wan_link0] LCP: SendTerminateReq #26
      Jun 25 15:14:17 	ppp 	95334 	[wan_link0] LCP: LayerDown
      Jun 25 15:14:17 	ppp 	95334 	[wan_link0] LCP: rec'd Terminate Request #227 (Stopping)
      Jun 25 15:14:17 	ppp 	95334 	[wan_link0] LCP: SendTerminateAck #27
      Jun 25 15:14:17 	ppp 	95334 	[wan_link0] PPPoE: connection closed
      Jun 25 15:14:17 	ppp 	95334 	[wan_link0] Link: DOWN event
      Jun 25 15:14:17 	ppp 	95334 	[wan_link0] LCP: Down event
      Jun 25 15:14:17 	ppp 	95334 	[wan_link0] LCP: state change Stopping --> Starting
      Jun 25 15:14:17 	ppp 	95334 	[wan_link0] Link: reconnection attempt 9 in 1 seconds
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] Link: reconnection attempt 9
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] PPPoE: Connecting to ''
      Jun 25 15:14:18 	ppp 	95334 	PPPoE: rec'd ACNAME "mx3.ham"
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] PPPoE: connection successful
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] Link: UP event
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] LCP: Up event
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] LCP: state change Starting --> Req-Sent
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] LCP: SendConfigReq #28
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] PROTOCOMP
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] MRU 1492
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] MAGICNUM 0x43503e74
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] LCP: rec'd Configure Request #201 (Req-Sent)
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] AUTHPROTO CHAP MD5
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] MAGICNUM 0x2b22e60a
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] LCP: SendConfigAck #201
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] LCP: state change Req-Sent --> Ack-Sent
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] LCP: rec'd Configure Ack #28 (Ack-Sent)
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] LCP: state change Ack-Sent --> Opened
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] LCP: auth: peer wants CHAP, I want nothing
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] LCP: LayerUp
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] CHAP: rec'd CHALLENGE #148 len: 39
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] Name: "JUNOS"
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] CHAP: Using authname ""
      Jun 25 15:14:18 	ppp 	95334 	[wan_link0] CHAP: sending RESPONSE #148 len: 31
      Jun 25 15:14:19 	ppp 	95334 	[wan_link0] CHAP: rec'd FAILURE #148 len: 4
      Jun 25 15:14:19 	ppp 	95334 	[wan_link0] LCP: authorization failed
      Jun 25 15:14:19 	ppp 	95334 	[wan_link0] LCP: parameter negotiation failed
      Jun 25 15:14:19 	ppp 	95334 	[wan_link0] LCP: state change Opened --> Stopping
      Jun 25 15:14:19 	ppp 	95334 	[wan_link0] LCP: SendTerminateReq #29
      Jun 25 15:14:19 	ppp 	95334 	[wan_link0] LCP: LayerDown
      Jun 25 15:14:19 	ppp 	95334 	[wan_link0] LCP: rec'd Terminate Request #202 (Stopping)
      Jun 25 15:14:19 	ppp 	95334 	[wan_link0] LCP: SendTerminateAck #30
      Jun 25 15:14:19 	ppp 	95334 	[wan_link0] PPPoE: connection closed
      Jun 25 15:14:19 	ppp 	95334 	[wan_link0] Link: DOWN event
      Jun 25 15:14:19 	ppp 	95334 	[wan_link0] LCP: Down event
      Jun 25 15:14:19 	ppp 	95334 	[wan_link0] LCP: state change Stopping --> Starting
      Jun 25 15:14:19 	ppp 	95334 	[wan_link0] Link: reconnection attempt 10 in 1 seconds
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] Link: reconnection attempt 10
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] PPPoE: Connecting to ''
      Jun 25 15:14:20 	ppp 	95334 	PPPoE: rec'd ACNAME "mx3.ham"
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] PPPoE: connection successful
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] Link: UP event
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] LCP: Up event
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] LCP: state change Starting --> Req-Sent
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] LCP: SendConfigReq #31
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] PROTOCOMP
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] MRU 1492
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] MAGICNUM 0xac7b2e34
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] LCP: rec'd Configure Request #118 (Req-Sent)
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] AUTHPROTO CHAP MD5
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] MAGICNUM 0x2ea44c07
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] LCP: SendConfigAck #118
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] LCP: state change Req-Sent --> Ack-Sent
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] LCP: rec'd Configure Ack #31 (Ack-Sent)
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] LCP: state change Ack-Sent --> Opened
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] LCP: auth: peer wants CHAP, I want nothing
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] LCP: LayerUp
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] CHAP: rec'd CHALLENGE #85 len: 40
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] Name: "JUNOS"
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] CHAP: Using authname ""
      Jun 25 15:14:20 	ppp 	95334 	[wan_link0] CHAP: sending RESPONSE #85 len: 31
      Jun 25 15:14:21 	ppp 	95334 	[wan_link0] CHAP: rec'd FAILURE #85 len: 4
      Jun 25 15:14:21 	ppp 	95334 	[wan_link0] LCP: authorization failed
      Jun 25 15:14:21 	ppp 	95334 	[wan_link0] LCP: parameter negotiation failed
      Jun 25 15:14:21 	ppp 	95334 	[wan_link0] LCP: state change Opened --> Stopping
      Jun 25 15:14:21 	ppp 	95334 	[wan_link0] LCP: SendTerminateReq #32
      Jun 25 15:14:21 	ppp 	95334 	[wan_link0] LCP: LayerDown
      Jun 25 15:14:21 	ppp 	95334 	[wan_link0] LCP: rec'd Terminate Request #119 (Stopping)
      Jun 25 15:14:21 	ppp 	95334 	[wan_link0] LCP: SendTerminateAck #33
      Jun 25 15:14:21 	ppp 	95334 	[wan_link0] PPPoE: connection closed
      Jun 25 15:14:21 	ppp 	95334 	[wan_link0] Link: DOWN event
      Jun 25 15:14:21 	ppp 	95334 	[wan_link0] LCP: Down event
      N P GertjanG 3 Replies Last reply Reply Quote 0
        netblues @Art Mooney
        @Art-Mooney said in Setting up fibre internet connection does not work:
        Vlan is ok, if it wasn't you would never reached this far into negotiation
        looks like there is no authname provided
        Have you assgined an interface to pppoe? What do you have at pppoe configuration?
          pst @Art Mooney
          looks like an authentication failure to me. I did the same last week, removed my Fritz!box and all I had to do was configure the WAN as PPPoE and insert the correct credentials. Double-check you username and password. Did you remove the user name from the log? I seems to be sent as an empry string. Also what is "JUNOS"?
            Art Mooney @pst
            Yes, I removed the authname from the post. The credentials should be correct. They were provided by the ISP and are the same in the FritzBox configuration file. I also double checked for typos.
            I have no idea what JUNOS is.
            I will post the PPPoe configuration and interface shortly.
              @Art-Mooney When removing credentials replace them with something, deleting them leads to wrong assumptions.
              In any case looks like wrong credentials are provided.
                Art Mooney
                @netblues said in Setting up fibre internet connection does not work:
                That makes sense.
                As you know, there are various pages where PPPoe elements are configured. I included them in this post below. I also added the firewall rules just in case they could have anything to do with the problem.
                firewall rules lan.jpg firewall rules.jpg interface assignments.jpg interface ppps.jpg interfaces.jpg lan interface.jpg PPP interfaces.jpg wan interface.jpg
                  pst @Art Mooney
                  not really, it is all in Interfaces / WAN
                  To progress I would start by disabling IPv6. Just a try to ensure you can set up a basic IPv4 connection. The only difference to my configuration that I can see is I have the option "PPP Configuration / Configure NULL service name" set.
                  If IPv4 works then the problem must be related to IPv6.
                    Art Mooney @pst
                    @pst
                    I disabled IPv6. No changes. The log looks the same.
                      Art Mooney @Art Mooney
                        @Art-Mooney Why igb0 and igb1 have the same mac?
                        This is bad practice.
                        If you need to spoof mac address do it just on igb1, NOT on the lan interface.
                        I doubt you need to spoof mac though.
                        Since everything looks ok, and assuming there are no errors in copying credentials, try vlan 7 on the pppoe interface, as a last resort.
                        FYI JUNOS is probably the os name of the (juniper) bras responding to pppoe connection requests.
                        The easy way to find relevant part in fritz config is searching for the (redacted) ppp user name.
                        Still, from the logs, looks like an authentication issue.
                          Gertjan @Art Mooney
                          Do you mean : You've copied the MAC of the Fritsbox WAN port to the WAN port of pfSense ?
                          I'm not sure why you used 'LAN' here.
                          • NogBadTheBadN Offline
                            NogBadTheBad @Gertjan
                            Is it tagging the WAN with VLAN ID 0 ?
                                hsi_use_wan_vlan = yes;
                                hsi_vlancfg {
                                        vlanencap = vlanencap_none;
                                        tagtype = vlantagtype_customer;
                                        vlanid = 0;
                                        vlanprio = 0;
                            Andy
                              Art Mooney @netblues
                              This was the solution. Unfortunately, this was not evident from the FritzBox config file. Now it works.
                              Thank you all for your suggestions!
