    Enhanced Intel SpeedStep / Speed Shift - Are they fully supported?
    74 Posts 8 Posters 18.9k Views 9 Watching
      tman222 @stephenw10
      @stephenw10 said in Enhanced Intel SpeedStep / Speed Shift - Are they fully supported?:
      The driver only configures the parameters for the hardware to use it doesn't actually set P-states directly. So.... unclear!
      Tried "Out of Band Mode" and the hwpstate_intel driver no longer loaded / attached during boot and Speed Shift settings were also gone in pfSense. Looks like it needs to be set to Native Mode to work properly.
      Q 1 Reply Last reply Reply Quote 1
      • Q Offline
        q54e3w @tman222
        @tman222 mine is set to native and seems to be functioning. I have a few days worth of 23.09 SNMP data illustrating the delta between 2.7 hiadaptive and 23.09 ‘80’ I’ll share when I get back to my desk.
        T 1 Reply Last reply Reply Quote 2
          tman222 @q54e3w
          @q54e3w said in Enhanced Intel SpeedStep / Speed Shift - Are they fully supported?:
          Thanks @q54e3w - I look forward to seeing those statistics. I currently have mine set to 60 and the CPU is already running 2-3 degrees C cooler than before (when it was using EIST).
          RobbieTTR Q 2 Replies Last reply Reply Quote 0
          • RobbieTTR Offline
            RobbieTT @tman222
            @tman222
            Set mine this evening and set the GUI slider to 80 for now and the recommended 'per core' although it defaulted to 'package'. Not sure if you needed to un-tick the PowerD box but did so anyway:
            Noticed a couple of other changes on the Dashboard. The max frequency now shows as 2700 MHz (vice 2701) and the minimum freq displays 799 MHz (vice 800):
            20231110-Router-7-BIOS to Intel Speed Shift-80-No turbo 2700 MHz question.png
            (The above shows 8-cores as I don't have HT enabled)
            Turbo still seems to work though:
            load  31%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
            load  30%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
            load  39%, current freq  799 MHz ( 0), wanted freq 5400 MHz
            load  65%, current freq  799 MHz ( 0), wanted freq 5400 MHz
            Shame I don't get any power data from this Supermicro PSU:
            According to my UPS my system may have reduced by a few watts but too early to tell if that is really the case.
              tman222
              On a related topic, have any of you made adjustments to the C-States on your firewalls? From what I can tell FreeBSD / pfSense show C1 and C2 as supported on the Xeon D-1718T CPU in my system:
               dev.cpu.0.cx_supported: C1/1/1 C2/2/41
              Looking at the BIOS, I see that a C3 state is also supported and can be enabled. Unfortunately, even after enabling the additional C-State the OS still only seeds C1 and C2. Does anyone have any idea how to get the OS to recognize C3 as well?
              Moving on, I saw that the hw.acpi.cpu.cx_lowest sysctl tunable was set to C1 but allowed me to switch it over to C2.
              After ~24 hours of run time, I checked C state usage and it looks like that the system is very lightly utilized overall, i.e. spends the majority of time in the C2 state:
               dev.cpu.7.cx_usage: 0.25% 99.74% last 98us
               dev.cpu.5.cx_usage: 0.29% 99.70% last 994us
               dev.cpu.3.cx_usage: 0.26% 99.73% last 618us
               dev.cpu.1.cx_usage: 0.29% 99.70% last 495us
               dev.cpu.6.cx_usage: 0.20% 99.79% last 25us
               dev.cpu.4.cx_usage: 0.19% 99.80% last 284us
               dev.cpu.2.cx_usage: 0.59% 99.40% last 131us
               dev.cpu.0.cx_usage: 0.32% 99.67% last 81us
              I'm not quite sure yet how much incremental power savings there are allowing C2 over just C1, but the impact to performance appears to be negligible (if any impact at all). Having said that, exit latency on C-States is definitely something to keep mind, especially when dealing with networking equipment. Thankfully in this case the exit latency on the C2 state on my system is quite low - only 41 microseconds.
              • RobbieTTR Offline
                RobbieTT @tman222
                @tman222 said in Enhanced Intel SpeedStep / Speed Shift - Are they fully supported?:
                cx_supported
                I keep mine in the default C1 as C2 seemed unusual for a router firewall and I didn't change the BIOS setting and I think only C1 & C2 are supported by pfSense.
                There is constant background traffic on my network so I never imagined the C2 would be anything but an encumbrance. Hopefully Speed Shift does the clever stuff by core but perhaps I am mistaken for the wider system? Here are my stats for the D-1736NT:
                dev.cpu.7.cx_usage: 100.00% 0.00% last 32us
                dev.cpu.6.cx_usage: 100.00% 0.00% last 557us
                dev.cpu.5.cx_usage: 100.00% 0.00% last 33us
                dev.cpu.4.cx_usage: 100.00% 0.00% last 70us
                dev.cpu.3.cx_usage: 100.00% 0.00% last 1290us
                dev.cpu.2.cx_usage: 100.00% 0.00% last 317us
                dev.cpu.1.cx_usage: 100.00% 0.00% last 1033us
                dev.cpu.0.cx_usage: 100.00% 0.00% last 756us
                dev.cpu.7.cx_supported: C1/1/1 C2/2/41
                dev.cpu.6.cx_supported: C1/1/1 C2/2/41
                dev.cpu.5.cx_supported: C1/1/1 C2/2/41
                dev.cpu.4.cx_supported: C1/1/1 C2/2/41
                dev.cpu.3.cx_supported: C1/1/1 C2/2/41
                dev.cpu.2.cx_supported: C1/1/1 C2/2/41
                dev.cpu.1.cx_supported: C1/1/1 C2/2/41
                Having already disabled HT and setting Speed Shift to 80 I think the only extra power measures I could take is disabling unused interfaces. Perhaps I should allow the SSD to sleep but that may not make any real difference to power/heat.
                  pfSense supports higher (lower?) C states if the BIOS passes them:
                  dev.cpu.0.cx_method: C1/mwait/hwc C2/mwait/hwc C3/mwait/hwc
                  dev.cpu.0.cx_usage_counters: 9066 5086 8391
                  dev.cpu.0.cx_usage: 40.21% 22.56% 37.22% last 2204us
                  dev.cpu.0.cx_lowest: C8
                  dev.cpu.0.cx_supported: C1/1/1 C2/2/127 C3/3/1048
                  • RobbieTTR Offline
                    RobbieTT @stephenw10
                    That's good to know. Typically, how deep down into the C-states would you expect for a router/firewall, without overly impacting performance?
                      For best performance I would disable C states deeper than C1. I have enabled a deep as it could go on some boxes that mostly sit idle and it makes no significant difference to either performance or power consumption beyond C3 as far as I could tell.
                      • Q Offline
                        q54e3w @tman222
                        @tman222 Note vertical scale only goes to 30%, its an overpowered system
                        ~24 hours pre/post upgrade
                        Pre/current
                        Edit: I took the opportunity to upgrade the motherboard firmware at the same time as update pfSense too which may have some impact.
                        RobbieTTR 1 Reply Last reply Reply Quote 2
                        • RobbieTTR Offline
                          RobbieTT @q54e3w
                          @q54e3w
                          Am I reading this correctly - that Speed Shift seems to work the CPU harder?
                          I have noticed that the CPU tends to run at a higher load and frequency but drops pretty quickly, at least on my own system.
                          Q 1 Reply Last reply Reply Quote 0
                          • Q Offline
                            q54e3w @RobbieTT
                            @RobbieTT Yup, it looks like it although how the operating system and pfSense has changed will also impact. Its not an apples to apples comparison exactly because its not on the same operating system and use of IPSec-MB etc. I also upgraded the BIOS at the same time given the box was out of service anyway.
                            I'm currently trying '60' to see if it makes a noticeable difference to temps, power consumption or performance.
                              Speedshift reacts much faster so you will the CPU at higher frequencies more often. Quite how that translates into apparent loading though.... unclear!
                              • RobbieTTR Offline
                                I think we may miss stuff with the reporting rate vs actual rate of change. With different frequencies on different cores the values we see may not be truly representative.
                                With my previous 'adaptive' profile I didn't observe any turbo frequencies (does not mean it wasn't happening I guess) but with Speed Shift on 80 it sticks at 799 MHz under varying demand and then rapidly turbos when things get busy:
                                [23.09-RELEASE][admin@Router-7.redacted.me]/root: powerd -v
                                powerd: unable to determine AC line status
                                CPU frequency is below user-defined minimum; changing frequency to 2700 MHz
                                load   0%, current freq  799 MHz ( 0), wanted freq 4754 MHz
                                load   4%, current freq  799 MHz ( 0), wanted freq 4605 MHz
                                load  94%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 163%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 156%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 144%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 190%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 110%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 136%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 265%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 194%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 143%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 162%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 138%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 125%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 113%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 150%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 135%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load  98%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 179%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 169%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 108%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 149%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 165%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 234%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 159%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 156%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load  99%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load  80%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 176%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 116%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 107%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 141%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 177%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 101%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 146%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 166%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 105%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load  78%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 184%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 129%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 200%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 163%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load 175%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load   3%, current freq 3199 MHz ( 0), wanted freq 5231 MHz
                                load   0%, current freq 3199 MHz ( 0), wanted freq 5067 MHz
                                load   0%, current freq 3199 MHz ( 0), wanted freq 4908 MHz
                                load  54%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load  41%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load  39%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load  37%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load  89%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load  47%, current freq 3199 MHz ( 0), wanted freq 5400 MHz
                                load  75%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load  22%, current freq  799 MHz ( 0), wanted freq 5231 MHz
                                load  25%, current freq  799 MHz ( 0), wanted freq 5231 MHz
                                load  44%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 127%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 176%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 138%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load  36%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load  11%, current freq  799 MHz ( 0), wanted freq 5231 MHz
                                load  81%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 185%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 210%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 197%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load  38%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load  19%, current freq  799 MHz ( 0), wanted freq 5231 MHz
                                load  22%, current freq  799 MHz ( 0), wanted freq 5067 MHz
                                load  21%, current freq  799 MHz ( 0), wanted freq 4908 MHz
                                load  58%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load  34%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load  25%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load  52%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load 119%, current freq  799 MHz ( 0), wanted freq 5400 MHz
                                load  17%, current freq  799 MHz ( 0), wanted freq 5231 MHz
                                I presume the above is just the fastest core though.
                                  I agree. When I was first testing Speedshift I had a very hard time determining if my changes were actually doing anything. I came to the conclusion it's because simply running sysctl to read the cpu state causes it to bump the frequency. For example running sysctl dev.cpu.0.freq dev.cpu.1.freq dev.cpu.2.freq dev.cpu.3.freq gives the same result as running sysctl dev.cpu.3.freq dev.cpu.2.freq dev.cpu.1.freq dev.cpu.0.freq. I.e. whichever core you query first gives the lowest result and each subsequent core is running faster.
                                  • RobbieTTR Offline
                                    Thankfully I don't see that, at least on this cpu:
                                    [23.09-RELEASE]/root: sysctl dev.cpu.0.freq dev.cpu.1.freq dev.cpu.2.freq dev.cpu.3.freq dev.cpu.4.freq dev.cpu.5.freq dev.cpu.6.freq dev.cpu.7.freq
                                    dev.cpu.0.freq: 799
                                    dev.cpu.1.freq: 799
                                    dev.cpu.2.freq: 799
                                    dev.cpu.3.freq: 799
                                    dev.cpu.4.freq: 799
                                    dev.cpu.5.freq: 799
                                    dev.cpu.6.freq: 799
                                    dev.cpu.7.freq: 799
                                    Heisenberg defeated.
                                    Less luck with PPPoE handling though (920 Mbps download test):
                                    dev.cpu.0.freq: 3199
                                    dev.cpu.1.freq: 799
                                    dev.cpu.2.freq: 799
                                    dev.cpu.3.freq: 799
                                    dev.cpu.4.freq: 799
                                    dev.cpu.5.freq: 799
                                    dev.cpu.6.freq: 799
                                    dev.cpu.7.freq: 799
                                      Hmm, I guess as long as the load sysctl imposes doesn't push it over whatever the threshold is you wouldn't see that. You CPU is likely a lot more powerful than what I'm seeing that on.
                                        bigjohns97
                                        Per core working just fine here.
                                          bigjohns97
                                          BTW here is a great article showing why this is so important.
                                          https://pcper.com/2015/11/intel-speed-shift-tested-significant-user-experience-improvements/
                                          For those who weren't utilizing powerd it's no big deal while those of us who were welcome this update with open arms.
                                          In these examples you can see that it really only take a couple of milliseconds now to ramp clock speed.
                                          Essentially meaning there is no reason to not run this on a modern CPU that supports it when concerned about the best possible performance. HUGE for those of us with power hungry x86 CPU's that are running 24/7.
                                          • RobbieTTR Offline
                                            RobbieTT @bigjohns97
                                            @bigjohns97
                                            I appear to get higher (better) PPPoE throughput on my Xeon-D, which I didn't expect. I need to think a bit more as to why.
                                            Anyway, just Intel Speed Select Technology to come... 🐥
