    PPPoE WAN does not restart correctly after reconfiguring interfaces.
    67 Posts 6 Posters 7.7k Views 7 Watching
    • RobbieTTR Offline
      RobbieTT @stephenw10
      Hi Steve, I didn't particularly want to add additional noise to this thread but I also have the occasional hiccup when taking the PPPoE WAN down and back up again.
      Since the changes in 24.03 these are of a lower order of magnitude than previously they do still happen. Whilst I could not grab a log and point at it is my sense that this only happens when bringing the PPPoE WAN up now (since the changes) rather than both down and up.
      I've not been doing any true controlled testing (due to the cloud hanging over those of us willing to test betas but likely to be billed for it in the near future) but the changes have made a considerable difference to both my Netgate and non-Netgate hardware.
      However, they do still happen and when they do they can be oddly successive when they do happen, which causes considerable frustration. Other times I can go through multiple WAN down/up commands and have no issue at all.
      Regards
        Hmm, well if you can grab any logs to compare that may help here.
          pFence
          Here's a log including both the successful interface reset as well as the one with failing PPPoE (pfsense 24.03).
          PPPoE not failing and failing v24.03.txt
            Hmm, are you sure you didn't label those the wrong way around? The first log looks like a failure and the second a success.
              pFence
              Yes, of course the labels should be swapped.
                pFence @pFence
                Have you been able to dig into this?
                It seems one of the changes made to version 24.03 was Revision 30d46b63. Since the behaviour changed with 24.03, the fault might be related to one of the files touched in that change.
                  pFence @pFence
                  Have you passed this on to the developers or do I need to somehow open a bug on Redmine?
                    Mmm, checking what happened here...
                      Malec
                      After Update to 24.03 i have the same issue. Every night my ISP forces a reset and every night my PPPOE (Netgate 4100) will not reconnect. This is really frustrating:
                      °PPPOE Log°(Sep 15 03:20:01 ppp 48609 Multi-link PPP daemon for FreeBSD
                      Sep 15 03:20:01 ppp 48609 process 48609 started, version 5.9
                      Sep 15 03:20:01 ppp 4389 caught fatal signal TERM
                      Sep 15 03:20:01 ppp 4389 [wan] IFACE: Close event
                      Sep 15 03:20:01 ppp 4389 [wan] IPCP: Close event
                      Sep 15 03:20:01 ppp 4389 [wan] IPCP: state change Opened --> Closing
                      Sep 15 03:20:01 ppp 4389 [wan] IPCP: SendTerminateReq #4
                      Sep 15 03:20:01 ppp 4389 [wan] IPCP: LayerDown
                      Sep 15 03:20:01 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:01 ppp 4389 [wan] IFACE: Removing IPv4 address from pppoe0 failed(IGNORING for now. This should be only for PPPoE friendly!): Can't assign requested address
                      Sep 15 03:20:01 ppp 4389 [wan] IPV6CP: Close event
                      Sep 15 03:20:01 ppp 4389 [wan] IPV6CP: state change Opened --> Closing
                      Sep 15 03:20:01 ppp 4389 [wan] IPV6CP: SendTerminateReq #2
                      Sep 15 03:20:01 ppp 4389 [wan] IPV6CP: LayerDown
                      Sep 15 03:20:02 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:03 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:04 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:05 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:06 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:07 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:08 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:09 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:10 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:11 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:12 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:13 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:14 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:15 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:16 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:17 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:18 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:19 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:20 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:21 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:22 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:23 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:24 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:25 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:26 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:27 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:28 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:29 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:30 ppp 48609 waiting for process 4389 to die...
                      Sep 15 03:20:31 ppp 48609 can't lock /var/run/pppoe_wan.pid after 30 attempts
                      Sep 15 03:20:52 ppp 4389 [wan] IFACE: Down event
                      Sep 15 03:20:52 ppp 4389 [wan] IFACE: Rename interface pppoe0 to pppoe0
                      Sep 15 03:20:52 ppp 4389 [wan] IFACE: Set description "WAN"
                      Sep 15 03:20:52 ppp 4389 [wan] IPV6CP: SendTerminateReq #3
                      Sep 15 03:20:52 ppp 4389 [wan] IPCP: SendTerminateReq #5
                      Sep 15 03:20:52 ppp 4389 [wan] IPCP: rec'd Terminate Ack #4 (Closing)
                      Sep 15 03:20:52 ppp 4389 [wan] IPCP: state change Closing --> Closed
                      Sep 15 03:20:52 ppp 4389 [wan] IPCP: LayerFinish
                      Sep 15 03:20:52 ppp 4389 [wan] IPV6CP: rec'd Terminate Ack #2 (Closing)
                      Sep 15 03:20:52 ppp 4389 [wan] IPV6CP: state change Closing --> Closed
                      Sep 15 03:20:52 ppp 4389 [wan] IPV6CP: LayerFinish
                      Sep 15 03:20:52 ppp 4389 [wan] Bundle: No NCPs left. Closing links...
                      Sep 15 03:20:52 ppp 4389 [wan] Bundle: closing link "wan_link0"...
                      Sep 15 03:20:52 ppp 4389 [wan_link0] LCP: rec'd Terminate Request #3 (Opened)
                      Sep 15 03:20:52 ppp 4389 [wan_link0] LCP: state change Opened --> Stopping
                      Sep 15 03:20:52 ppp 4389 [wan_link0] Link: Leave bundle "wan"
                      Sep 15 03:20:52 ppp 4389 [wan] Bundle: Status update: up 0 links, total bandwidth 9600 bps
                      Sep 15 03:20:52 ppp 4389 [wan] IPCP: Close event
                      Sep 15 03:20:52 ppp 4389 [wan] IPV6CP: Close event
                      Sep 15 03:20:52 ppp 4389 [wan] IPCP: Down event
                      Sep 15 03:20:52 ppp 4389 [wan] IPCP: state change Closed --> Initial
                      Sep 15 03:20:52 ppp 4389 [wan] IPV6CP: Down event
                      Sep 15 03:20:52 ppp 4389 [wan] IPV6CP: state change Closed --> Initial
                      Sep 15 03:20:52 ppp 4389 [wan_link0] LCP: SendTerminateAck #4
                      Sep 15 03:20:52 ppp 4389 [wan_link0] LCP: LayerDown
                      Sep 15 03:20:52 ppp 4389 [wan_link0] PPPoE: connection closed
                      Sep 15 03:20:52 ppp 4389 [wan_link0] Link: DOWN event
                      Sep 15 03:20:52 ppp 4389 [wan_link0] Link: giving up after 0 reconnection attempts
                      Sep 15 03:20:52 ppp 4389 [wan_link0] LCP: Close event
                      Sep 15 03:20:52 ppp 4389 [wan_link0] LCP: state change Stopping --> Closing
                      Sep 15 03:20:52 ppp 4389 [wan_link0] LCP: Down event
                      Sep 15 03:20:52 ppp 4389 [wan_link0] LCP: LayerFinish
                      Sep 15 03:20:52 ppp 4389 [wan_link0] LCP: state change Closing --> Initial
                      Sep 15 03:20:52 ppp 4389 [wan_link0] Link: CLOSE event
                      Sep 15 03:20:54 ppp 4389 [wan] Bundle: Shutdown
                      Sep 15 03:20:54 ppp 4389 [wan_link0] Link: Shutdown
                      Sep 15 03:20:54 ppp 4389 process 4389 terminated)
                      I have to downgrade to an older Version of Pfsense as i only have this problem with 24.03.
                      w0wW 1 Reply Last reply Reply Quote 1
                      • w0wW Away
                        w0w @Malec
                        @Malec
                        Same for me.
                        I still encounter a race condition that causes mpd to start twice and get stuck, but I wrote my own script as a workaround. Not sure what the real status of the problem is. Still waiting for development snapshots available to re-test.
                          @w0w Were you able to test with the older 24.08 public snapshot?
                          w0wW 1 Reply Last reply Reply Quote 0
                          • w0wW Away
                            w0w @stephenw10
                            Yes, it is my current snapshot, so the problem remains the same.
                            However, I should point out that my configuration is far from standard. I also use CARP for failover, VIP addresses on a PPPoE parent interface, and much more, which is why I don’t want to file a bug report prematurely. Additionally, there is hope that something may have changed in the newer code.
                              Hmm, OK. Well with any luck we should have a new Plus dev snapshot very soon so hopefully you can test that and at least confirm if the issue still exists. Though there is a lot of new stuff so I anticipate some issues initially. 🤞
                              • w0wW Away
                                w0w @stephenw10
                                Unfortunately, yes, the issue still exists.
                                I am using an unsupported CARP configuration to maintain PPPoE links automatically. There are two firewalls, and the parent PPPoE interfaces on both are configured with static local IP addresses like 10.0.111.2 and 10.0.111.3, with a VIP in CARP mode set to 10.0.111.1. The primary idea is that the master firewall automatically establishes the PPPoE link when it becomes the master. This part works fine. The problem occurs when I unplug the power cable from the ISP’s dumb switch, and it always results in two mpd daemons running simultaneously.
                                pppoe.txt
                                  Urgh, that's in the new 24.08 snapshot?
                                  • w0wW Away
                                    w0w @stephenw10
                                    Yes.
                                    24.08-DEVELOPMENT (amd64)
                                    built on Wed Sep 25 9:00:00 EEST 2024
                                    FreeBSD 15.0-CURRENT
                                      Hmm, let me try to replicate that...
                                      • w0wW Away
                                        w0w @stephenw10
                                        Any luck?
                                          Not yet. I'll try to get the config back in place today.
                                            pFence
                                            In April/May I gave a pretty precise problem description including a hint on which files probably contained the error. Was this really just for the bin? Is there any better way to address bugs in the paid product than this forum?
