    PPPoE WAN does not restart correctly after reconfiguring interfaces.
    67 Posts 6 Posters 6.7k Views 7 Watching
      You'd have to use the internal interface name there so possibly:
      /usr/local/sbin/pfSctl -c 'interface reload opt1'
      Check the config or console menu to see those like:
       WAN (wan)   -> ix3  -> v4/DHCP4: 172.21.16.23/24
       LAN (lan)   -> igc0 -> v4: 192.168.23.1/24
       WAN2 (opt1) -> ix2  ->
       WAN3 (opt2) -> ix0  ->
       WAN4 (opt3) -> ix1  ->
       LAN2 (opt4) -> igc1 ->
        pFence
        It is indeed opt1. And no, issuing
        does not break PPPoE on interface WAN1. Only
        /usr/local/sbin/pfSctl -c 'interface reload wan'
        does.
          We're probably going to need to see some logs.
          How do you have the periodic reset configured?
            pFence
            It is configured as "Custom" periodic reset within the PPPoE configuration of interface WAN1.
              OK, that should work.
              If the second WAN is disabled does the dhcpv6 on WAN reconnect correctly?
                pFence
                Yes, both PPPoE (IPv4) and DHCP6 connect correctly.
                  Ok I thing we're going to need to see some logs of the reconnection to see what's happening there.
                    pFence
                    Here's the PPP log when it failed.
                    PPPoE failing.txt
                      That reads like there was other stuff happening before that log except starts?
                      When was the reset?
                      What does the system log show over that period?
                        pFence
                        The reset is at 5:55. Here is the system log starting at 4:00:
                        log.txt
                          Hmm, so it appears that something prevents the old mpd process closing for an excessively long time!
                          It doesn't actually close out until here:
                          Apr 17 05:57:30 gate1 check_reload_status[457]: updating dyndns opt8
                          Apr 17 05:57:30 gate1 check_reload_status[457]: Rewriting resolv.conf
                          Apr 17 05:57:30 gate1 ppp[47767]: [wan] IFACE: Down event
                          By which time the new mpd5 has given up.
                          Unclear why that would delay it. Or why a second dhcpv6 instance would make any difference.
                          With the other WAN disabled for v6 does the mpd process finish without that min wait?
                            Konstanti @pFence
                            hi
                            , the main problem I see is that when a new mpd process is started, the previously started processes are checked (whether the file /var/run/pppoe_wan.pid exists) if the file exists, a command is sent to terminate the process.
                            Apr 17 05:55:01 gate1 ppp[90881]: process 90881 started, version 5.9
                            Apr 17 05:55:01 gate1 ppp[90881]: waiting for process 47767 to die...
                            Then, within 30 seconds (30 attempts), the closing of the previous mpd process is checked again. If this does not happen, then the program terminates (your case)
                            Apr 17 05:55:31 gate1 ppp[90881]: waiting for process 47767 to die...
                            Apr 17 05:55:32 gate1 ppp[90881]: can't lock /var/run/pppoe_wan.pid after 30 attempts
                            . In your case, the previous process, for some unknown reason, was completed not within 30 seconds, but after 2 minutes and 30 seconds .
                            Apr 17 05:57:32 gate1 ppp[47767]: process 47767 terminated
                            • w0wW Offline
                              w0w
                              BTW on the latest 24.03 RC builds I can't replicate this by issuing /usr/local/sbin/pfSctl -c 'interface reload wan' as before.
                              EDIT:
                              Got something, after switching to secondary firewall
                              2024-04-20 13:19:36.596539+03:00 	ppp 	98029 	process 98029 terminated
                              2024-04-20 13:19:36.595640+03:00 	ppp 	98029 	[wan_link0] Link: Shutdown
                              2024-04-20 13:19:36.498909+03:00 	ppp 	98029 	[wan] Bundle: Shutdown
                              2024-04-20 13:19:35.807384+03:00 	ppp 	92838 	waiting for process 98029 to die...
                              2024-04-20 13:19:34.804613+03:00 	ppp 	92838 	waiting for process 98029 to die...
                              2024-04-20 13:19:34.496426+03:00 	ppp 	98029 	[wan_link0] LCP: state change Closed --> Initial
                              2024-04-20 13:19:34.496379+03:00 	ppp 	98029 	[wan_link0] LCP: Down event
                              2024-04-20 13:19:34.496330+03:00 	ppp 	98029 	[wan_link0] LCP: Close event
                              2024-04-20 13:19:34.496281+03:00 	ppp 	98029 	[wan_link0] Link: giving up after 0 reconnection attempts
                              2024-04-20 13:19:34.496227+03:00 	ppp 	98029 	[wan_link0] Link: DOWN event
                              2024-04-20 13:19:34.495982+03:00 	ppp 	98029 	[wan_link0] LCP: LayerFinish
                              2024-04-20 13:19:34.495923+03:00 	ppp 	98029 	[wan_link0] LCP: state change Closing --> Closed
                              2024-04-20 13:19:34.495866+03:00 	ppp 	98029 	[wan_link0] LCP: rec'd Terminate Ack #3 (Closing)
                              2024-04-20 13:19:34.495045+03:00 	ppp 	98029 	[wan_link0] LCP: LayerDown
                              2024-04-20 13:19:34.494921+03:00 	ppp 	98029 	[wan_link0] LCP: SendTerminateReq #3
                              2024-04-20 13:19:34.494857+03:00 	ppp 	98029 	[wan] IPCP: state change Closed --> Initial
                              2024-04-20 13:19:34.494806+03:00 	ppp 	98029 	[wan] IPCP: Down event
                              2024-04-20 13:19:34.494749+03:00 	ppp 	98029 	[wan] IPCP: Close event
                              2024-04-20 13:19:34.494668+03:00 	ppp 	98029 	[wan] Bundle: Status update: up 0 links, total bandwidth 9600 bps
                              2024-04-20 13:19:34.494075+03:00 	ppp 	98029 	[wan_link0] Link: Leave bundle "wan"
                              2024-04-20 13:19:34.494024+03:00 	ppp 	98029 	[wan_link0] LCP: state change Opened --> Closing
                              2024-04-20 13:19:34.493975+03:00 	ppp 	98029 	[wan_link0] LCP: Close event
                              2024-04-20 13:19:34.493916+03:00 	ppp 	98029 	[wan_link0] Link: CLOSE event
                              2024-04-20 13:19:34.493714+03:00 	ppp 	98029 	[wan] IPCP: rec'd Terminate Ack #5 (Closed)
                              2024-04-20 13:19:34.493498+03:00 	ppp 	98029 	[wan] Bundle: closing link "wan_link0"...
                              2024-04-20 13:19:34.493448+03:00 	ppp 	98029 	[wan] Bundle: No NCPs left. Closing links...
                              2024-04-20 13:19:34.493399+03:00 	ppp 	98029 	[wan] IPCP: LayerFinish
                              2024-04-20 13:19:34.493340+03:00 	ppp 	98029 	[wan] IPCP: state change Closing --> Closed
                              2024-04-20 13:19:34.493281+03:00 	ppp 	98029 	[wan] IPCP: rec'd Terminate Ack #4 (Closing)
                              2024-04-20 13:19:34.492968+03:00 	ppp 	98029 	[wan] IPCP: SendTerminateReq #5
                              2024-04-20 13:19:34.492804+03:00 	ppp 	98029 	[wan] IFACE: Set description "WAN"
                              2024-04-20 13:19:34.492667+03:00 	ppp 	98029 	[wan] IFACE: Rename interface pppoe0 to pppoe0
                              2024-04-20 13:19:34.492452+03:00 	ppp 	98029 	[wan] IFACE: Down event
                              2024-04-20 13:19:34.492224+03:00 	ppp 	98029 	[wan] IFACE: Removing IPv4 address from pppoe0 failed(IGNORING for now. This should be only for PPPoE friendly!): Can't assign requested address
                              2024-04-20 13:19:33.789243+03:00 	ppp 	92838 	waiting for process 98029 to die...
                              2024-04-20 13:19:32.747960+03:00 	ppp 	92838 	waiting for process 98029 to die...
                              2024-04-20 13:19:31.746052+03:00 	ppp 	92838 	waiting for process 98029 to die...
                              2024-04-20 13:19:30.744279+03:00 	ppp 	92838 	waiting for process 98029 to die...
                              2024-04-20 13:19:29.742824+03:00 	ppp 	92838 	waiting for process 98029 to die...
                              2024-04-20 13:19:29.740665+03:00 	ppp 	92838 	process 92838 started, version 5.9
                              2024-04-20 13:19:29.742544+03:00 	ppp 	98029 	[wan] IPCP: LayerDown
                              2024-04-20 13:19:29.742278+03:00 	ppp 	98029 	[wan] IPCP: SendTerminateReq #4
                              2024-04-20 13:19:29.742176+03:00 	ppp 	98029 	[wan] IPCP: state change Opened --> Closing
                              2024-04-20 13:19:29.742077+03:00 	ppp 	98029 	[wan] IPCP: Close event
                              2024-04-20 13:19:29.741967+03:00 	ppp 	98029 	[wan] IFACE: Close event
                              2024-04-20 13:19:29.741737+03:00 	ppp 	98029 	caught fatal signal TERM
                              2024-04-20 13:19:29.738833+03:00 	ppp 	92838 	Multi-link PPP daemon for FreeBSD
                              It does appear different. It seems to be connected to the 'Multilink extensions over single link' option. I can't replicate the issue after unchecking this option and issuing
                              However, when it's checked, it consistently fails to reconnect. It doesn't seem to be a direct bug, but there's definitely something wrong when the multilink configuration is applied. The primary firewall has this option unchecked.
                              But I remember I have had exactly the same behaviour as posted here https://forum.netgate.com/post/1163644 can't find now when it's changed
                                Huh, that's interesting. That's not set by default, was there some reason you enabled it?
                                w0wW 1 Reply Last reply Reply Quote 0
                                • w0wW Offline
                                  w0w @stephenw10
                                  At some point, I was testing the capabilities of the provider and forgot to disable this option. However, it was definitely not related to the initially discussed issue, which is why I brought up this topic.
                                    pFence @stephenw10
                                    @stephenw10 said in PPPoE WAN does not restart correctly after reconfiguring interfaces.:
                                    Seems so. See attached log file:
                                    PPPoE not failing.txt
                                      Hmm, yeah 2.5s vs 2.5mins! Interestng.
                                      Can I assume you don't have Multilink extensions enabled?
                                        pFence
                                        "Multilink extensions over single link" is not enabled.
                                          pFence
                                          It seems that after upgrading to version 24.03 the PPPoE fails only exactly after every other periodic reset or manual interface reload while there is a DHCP6 configuration on the other WAN interface. This leads to the question whether the issue is related to one of the files changed for that upgrade. I am puzzled.
                                            Hmm, interesting. Unexpected!
                                            How does the logging differ between the two resets?
