    295 Posts 25 Posters 134.8k Views 25 Watching
      chrysmon @asdjklfjkdslfdsaklj
      @asdjklfjkdslfdsaklj More than 1 day running without crash. With AC-BS Pattern Matcher Algorithm.
      • jowe78J Offline
        jowe78
        I Installed Snort to test, and there i get another error. Memory usage is at 57% out of 8GB with all snort interfaces running. So might be a little high.
        I tried to change the "Stream Memory Cap" on Suricata interface (before changing to Snort) from 256MB to 384MB with no luck, Also changed some other memory settings without any luck.
        Is it using using a lot of RAM when reloading? It doesn't show on main page atleast.
        Last log entries before crash, but it's not every time that i have disabled a rule that it has crashed, especially not for Suricata.
        Nov 28 12:57:01 kernel ix0: promiscuous mode disabled
        Nov 28 12:57:01 kernel pid 79776 (snort), jid 0, uid 0, was killed: failed to reclaim memory
        Nov 28 12:56:59 kernel pid 79699 (snort), jid 0, uid 0, was killed: failed to reclaim memory
        Nov 28 12:56:44 kernel pid 88772 (php-fpm), jid 0, uid 0, was killed: failed to reclaim memory
        Nov 28 12:56:25 php-fpm 88772 [Snort] Snort RELOAD CONFIG for WAN(ix0)...
        Nov 28 12:56:25 php-fpm 88772 [Snort] Building new sid-msg.map file for WAN...
        Nov 28 12:56:25 php-fpm 88772 [Snort] Enabling any flowbit-required rules for: WAN...
        Nov 28 12:56:24 php-fpm 88772 [Snort] Enabling any flowbit-required rules for: WAN...
        Nov 28 12:56:23 php-fpm 88772 [Snort] Updating rules configuration for: WAN ...
        Nov 28 12:56:23 check_reload_status 438 Syncing firewall
        Nov 28 12:56:23 php-fpm 88772 /snort/snort_alerts.php: Configuration Change: admin@1.2.3.4 (Local Database): Snort pkg: User-forced rule state override applied for rule XXX:X on ALERTS tab for interface wan.
        • bmeeksB Offline
          bmeeks @jowe78
          @jowe78 said in Suricata process dying due to hyperscan problem:
          These log entries are very interesting ... 🤔.
          I've been doing some research this morning on memory management in modern operating systems and FreeBSD in particular. Still not an expert in this area by any measure, but I've learned some things that make me suspect a memory allocation/reclamation bug may exist in the recent FreeBSD releases.
          Memory management in a modern operating system such as FreeBSD is quite complex. There are several memory area classifications explained here.
          The operating system can experience something known as "memory pressure". This is a condition where some process needs additional memory but there is currently no Free memory available (refer to the link a couple of sentences prior in this paragraph for the definition of Free). In this state, the kernel memory management algorithm goes on the hunt for memory it can reclaim and then give to the requesting process. The kernel does its best to find memory to give a requesting process instead of just simply returning an OOM (out-of-memory) error to the requester. It first looks for a process that is sleeping, and if it finds a suitable one, it will either reclaim that memory space temporarily or swap that process' memory out to the swap partition. But if there is no sleeping process and the kernel can't otherwise find memory for the process currently requesting it, it will go on the hunt for something to kill in order to obtain memory. It is possible in that scenario for it to choose one of the largest memory consumption processes to kill.
          So, back to the log entries. Snort will be using a lot of extra memory during the rules update process. And it will be using a good chunk of that memory through the PHP interpreter. Look at the log entries I quoted above and notice what processes were killed: snort and the php-fpm engine. These would have been the biggest current memory users. But curiously, it was these processes that were likely asking for additional memory.
          I've seen a number of posts since the recent pfSense Plus release and the 2.7.1 CE release with similar log errors. Commonly impacted programs are unbound and snort. But sometimes a few others. The use of ZFS and its ARC (Adaptive Replacement Cache) might play a role here, too.
          This post I found does a decent job of explaining how memory management in FreeBSD works: https://unix.stackexchange.com/questions/234446/how-does-freebsd-allocate-memory.
            chrysmon @bmeeks
            Let me share my experience about memory. The same configuration running on three different physical systems:
            1. With 16GB RAM: uses the swap partition, the performance is unacceptable
            2. With 32GB RAM uses about 50% (peaks at 54%), no swap
            3. With 64GB RAM uses about 7%, no swap
            The values are from System Information - Memory usage
            • S SteveITS referenced this topic on
            • kiokomanK Offline
              kiokoman LAYER 8 @chrysmon
              LAN is cloned from WAN, there is no difference but wan is stable ...
              S bmeeksB 2 Replies Last reply Reply Quote 0
                SteveITS Galactic Empire @kiokoman
                @kiokoman Weird, some difference in the private subnet or related pass list maybe?
                @chrysmon said in Suricata process dying due to hyperscan problem:
                Have you found https://docs.netgate.com/pfsense/en/latest/hardware/tune-zfs.html?
                "The default maximum ARC size (vfs.zfs.arc.max) is automatic (0) and uses 1/2 RAM or the total RAM minus 1GB, whichever is greater."
                (but also it's supposed to give it up on its own)
                Upvote 👍 helpful posts!
                • bmeeksB Offline
                  bmeeks @kiokoman
                  @kiokoman said in Suricata process dying due to hyperscan problem:
                  Does turning Blocking Mode off completely make any difference on the LAN interface?
                  kiokomanK A 2 Replies Last reply Reply Quote 0
                    chrysmon @SteveITS
                    @SteveITS said in Suricata process dying due to hyperscan problem:
                    No I haven't. The strange (for me) is the low usage when the machine has 64GB. It's not consistent with the other two cases.
                    Sorry to continue here a discussion not relevant to the topic.
                    • jowe78J Offline
                      jowe78
                      I seem to have solved my problems by going from 8GB to 16GB RAM. Topped out at 65% or something with 16GB, But wasn't much higher with 8GB in %. (Going back to Suricata, memory usage is around 30% again)
                      Before there were some strange hanged apps like ovpn and adguard.
                      I just replaced the hardware, and looked at the usage on my old system eith 16GB RAM, and that was using like 30% so i thought that 8GB would be fine. But apparently not.
                      Thanks!
                        chrysmon @jowe78
                        @jowe78 Just to be clear: in my case suricata stopped crashing after setting the Pattern Matcher to AC-BS. Still may be early to conclude, but before (with any other Algorithm) it had crashes. I will let it one more day and then set to Hyperscan again.
                        jowe78J 1 Reply Last reply Reply Quote 0
                        • jowe78J Offline
                          jowe78 @chrysmon
                          I changed back so still using hyperscan (or auto), just more RAM.
                          • kiokomanK Offline
                            kiokoman LAYER 8 @bmeeks
                            @bmeeks
                            turning Blocking mode to off make it stable
                            • bmeeksB Offline
                              bmeeks @kiokoman
                              @bmeeks
                              Just to be clear. I am trying to determine if there is any link between Blocking being enabled and the Hyperscan crash.
                              You said your WAN was stable with blocking enabled, but your LAN (with the same rules cloned from the WAN interface and blocking enabled) would not even start. So, I want you to disable blocking mode on the LAN interface only and see if Suricata then starts on your LAN.
                              Then, if you LAN interface starts up with no other changes besides disabling blocking mode, then enable blocking mode again and see if the startup crash returns.
                              Perhaps I misunderstood your statement, though. Do you mean your LAN interfaces starts but then randomly crashes later, or does it fail to even start? Either way, removing Blocking Mode as a variable will be helpful.
                              The idea is to see if blocking mode is in any way related to the Hyperscan crash. I don't really believe it is, but since I have not been able to reproduce this crash I must depend on the users having the issue to help me understand where it's coming from.
                              • kiokomanK Offline
                                @bmeeks
                                WAN is stable with blocking enabled
                                LAN interfaces starts but then randomly crashes after a few minutes (max 5 min)
                                LAN interface stay up and running if i disable blocking mode
                                another BT running in autofp mode
                                (gdb) b exit
                                Breakpoint 1 at 0x82f969454
                                (gdb) continue
                                Continuing.
                                [New LWP 561670 of process 86533]
                                [New LWP 561671 of process 86533]
                                [New LWP 561672 of process 86533]
                                [New LWP 561673 of process 86533]
                                [New LWP 561674 of process 86533]
                                [New LWP 561675 of process 86533]
                                [New LWP 561676 of process 86533]
                                [New LWP 561677 of process 86533]
                                [New LWP 561678 of process 86533]
                                [New LWP 561679 of process 86533]
                                [New LWP 561680 of process 86533]
                                [Switching to LWP 561677 of process 86533]
                                Thread 10 "W#07" hit Breakpoint 1, 0x000000082f969454 in exit () from /lib/libc.so.7
                                (gdb) bt
                                #0 0x000000082f969454 in exit () from /lib/libc.so.7
                                #1 0x00000000006de629 in ?? ()
                                #2 0x000000000061d9ac in ?? ()
                                #3 0x000000000061ac4e in AppLayerProtoDetectGetProto ()
                                #4 0x00000000006197c9 in ?? ()
                                #5 0x0000000000619439 in AppLayerHandleTCPData ()
                                #6 0x00000000005aee4a in StreamTcpReassembleAppLayer ()
                                #7 0x00000000005af9e2 in StreamTcpReassembleHandleSegment ()
                                #8 0x00000000005b2b9f in ?? ()
                                #9 0x00000000005b15e2 in StreamTcpPacket ()
                                #10 0x00000000005b7817 in StreamTcp ()
                                #11 0x00000000006731c1 in ?? ()
                                #12 0x0000000000672a1a in ?? ()
                                #13 0x00000000006a7fe7 in ?? ()
                                #14 0x000000082b0b3d25 in ?? () from /lib/libthr.so.3
                                #15 0x0000000000000000 in ?? ()
                                Backtrace stopped: Cannot access memory at address 0x839de8000
                                (gdb) bt full
                                No symbol table info available.
                                (gdb) info threads
                                Id Target Id Frame
                                1 LWP 100234 of process 86533 0x000000082f9456ea in _nanosleep () from /lib/libc.so.7
                                2 LWP 561146 of process 86533 "IM#01" 0x000000082f9457ea in _read () from /lib/libc.so.7
                                3 LWP 561670 of process 86533 "RX#01-vmx2" 0x000000082f9446aa in _umtx_op () from /lib/libc.so.7
                                4 LWP 561671 of process 86533 "W#01" 0x000000082b0b0fdc in ?? () from /lib/libthr.so.3
                                5 LWP 561672 of process 86533 "W#02" 0x000000082b0b0fdc in ?? () from /lib/libthr.so.3
                                6 LWP 561673 of process 86533 "W#03" 0x0000000000672490 in ?? ()
                                7 LWP 561674 of process 86533 "W#04" 0x0000000000671127 in ?? ()
                                8 LWP 561675 of process 86533 "W#05" 0x000000082b0b0fdc in ?? () from /lib/libthr.so.3
                                9 LWP 561676 of process 86533 "W#06" 0x000000082ddb9d48 in ?? () from /usr/local/lib/libhs.so.5
                                • 10 LWP 561677 of process 86533 "W#07" 0x000000082f969454 in exit () from /lib/libc.so.7
                                  11 LWP 561678 of process 86533 "W#08" 0x00000000005a44d1 in DetectEnginePktInspectionRun ()
                                  12 LWP 561679 of process 86533 "FM#01" 0x000000082b0b0fdc in ?? () from /lib/libthr.so.3
                                  13 LWP 561680 of process 86533 "FR#01" 0x000000082b0b0fdc in ?? () from /lib/libthr.so.3
                                  (gdb) thread apply all bt
                                Thread 13 (LWP 561680 of process 86533 "FR#01"):
                                #0 0x000000082b0b0fdc in ?? () from /lib/libthr.so.3
                                #1 0x000000082b0c1022 in ?? () from /lib/libthr.so.3
                                #2 0x000000082b0b2b9d in ?? () from /lib/libthr.so.3
                                #3 0x00000000005ecb12 in ?? ()
                                #4 0x00000000006a87a8 in ?? ()
                                #5 0x000000082b0b3d25 in ?? () from /lib/libthr.so.3
                                #6 0x0000000000000000 in ?? ()
                                Backtrace stopped: Cannot access memory at address 0x83c301000
                                Thread 12 (LWP 561679 of process 86533 "FM#01"):
                                #3 0x00000000005ec633 in ?? ()
                                Backtrace stopped: Cannot access memory at address 0x83b685000
                                Thread 11 (LWP 561678 of process 86533 "W#08"):
                                #0 0x00000000005a44d1 in DetectEnginePktInspectionRun ()
                                #1 0x000000000067114b in ?? ()
                                #2 0x00000000006706db in Detect ()
                                #3 0x0000000000672ac9 in ?? ()
                                #4 0x00000000006a7fe7 in ?? ()
                                Backtrace stopped: Cannot access memory at address 0x83a717000
                                Thread 10 (LWP 561677 of process 86533 "W#07"):
                                --Type <RET> for more, q to quit, c to continue without paging--
                                Thread 9 (LWP 561676 of process 86533 "W#06"):
                                #0 0x000000082ddb9d48 in ?? () from /usr/local/lib/libhs.so.5
                                #1 0x000000082dde6ed3 in ?? () from /usr/local/lib/libhs.so.5
                                #2 0x000000082dd33a87 in hs_scan () from /usr/local/lib/libhs.so.5
                                #3 0x00000000006d4050 in SCHSSearch ()
                                #4 0x00000000005cc6fe in Prefilter ()
                                #5 0x0000000000670e15 in ?? ()
                                #6 0x00000000006706db in Detect ()
                                #7 0x0000000000672ac9 in ?? ()
                                #8 0x00000000006a7fe7 in ?? ()
                                #9 0x000000082b0b3d25 in ?? () from /lib/libthr.so.3
                                #10 0x0000000000000000 in ?? ()
                                Backtrace stopped: Cannot access memory at address 0x839723000
                                Thread 8 (LWP 561675 of process 86533 "W#05"):
                                #1 0x000000082b0b8f56 in pthread_mutex_unlock () from /lib/libthr.so.3
                                #2 0x000000082b0b2730 in __pthread_cleanup_pop_imp () from /lib/libthr.so.3
                                #3 0x000000082f929e2a in vfprintf_l () from /lib/libc.so.7
                                #4 0x000000082f9228df in fprintf () from /lib/libc.so.7
                                #5 0x00000000006b071e in SCLogMessage ()
                                #6 0x00000000006b13b6 in SCLogErr ()
                                #7 0x00000000006de61f in ?? ()
                                #8 0x000000000061d9ac in ?? ()
                                #9 0x000000000061ac4e in AppLayerProtoDetectGetProto ()
                                #10 0x00000000006197c9 in ?? ()
                                #11 0x0000000000619439 in AppLayerHandleTCPData ()
                                #12 0x00000000005aee4a in StreamTcpReassembleAppLayer ()
                                #13 0x00000000005af9e2 in StreamTcpReassembleHandleSegment ()
                                #14 0x00000000005b2b9f in ?? ()
                                #15 0x00000000005b15e2 in StreamTcpPacket ()
                                #16 0x00000000005b7817 in StreamTcp ()
                                #17 0x00000000006731c1 in ?? ()
                                #18 0x0000000000672a1a in ?? ()
                                #19 0x00000000006a7fe7 in ?? ()
                                #20 0x000000082b0b3d25 in ?? () from /lib/libthr.so.3
                                #21 0x0000000000000000 in ?? ()
                                Backtrace stopped: Cannot access memory at address 0x839405000
                                Thread 7 (LWP 561674 of process 86533 "W#04"):
                                #0 0x0000000000671127 in ?? ()
                                #1 0x00000000006706db in Detect ()
                                #2 0x0000000000672ac9 in ?? ()
                                #3 0x00000000006a7fe7 in ?? ()
                                #4 0x000000082b0b3d25 in ?? () from /lib/libthr.so.3
                                #5 0x0000000000000000 in ?? ()
                                Backtrace stopped: Cannot access memory at address 0x839183000
                                Thread 6 (LWP 561673 of process 86533 "W#03"):
                                #0 0x0000000000672490 in ?? ()
                                #1 0x0000000000671118 in ?? ()
                                Backtrace stopped: Cannot access memory at address 0x838061000
                                Thread 5 (LWP 561672 of process 86533 "W#02"):
                                #3 0x00000000006a3cc9 in TmqhInputFlow ()
                                #4 0x00000000006a7fb3 in ?? ()
                                Backtrace stopped: Cannot access memory at address 0x8371ba000
                                Thread 4 (LWP 561671 of process 86533 "W#01"):
                                Backtrace stopped: Cannot access memory at address 0x83620c000
                                Thread 3 (LWP 561670 of process 86533 "RX#01-vmx2"):
                                #0 0x000000082f9446aa in _umtx_op () from /lib/libc.so.7
                                #1 0x000000082b0b8f75 in pthread_mutex_unlock () from /lib/libthr.so.3
                                #2 0x00000000006740b1 in ?? ()
                                #3 0x000000082c1f4ff4 in ?? () from /usr/local/lib/libpcap.so.1
                                #4 0x00000000006737b7 in ?? ()
                                #5 0x00000000006a83aa in ?? ()
                                #6 0x000000082b0b3d25 in ?? () from /lib/libthr.so.3
                                #7 0x0000000000000000 in ?? ()
                                Backtrace stopped: Cannot access memory at address 0x835349000
                                Thread 2 (LWP 561146 of process 86533 "IM#01"):
                                #0 0x000000082f9457ea in _read () from /lib/libc.so.7
                                #1 0x000000082b0bfa13 in ?? () from /lib/libthr.so.3
                                #2 0x00000000006355ed in AlertPfMonitorIfaceChanges ()
                                #3 0x000000082b0b3d25 in ?? () from /lib/libthr.so.3
                                #4 0x0000000000000000 in ?? ()
                                Backtrace stopped: Cannot access memory at address 0x83423d000
                                Thread 1 (LWP 100234 of process 86533):
                                #0 0x000000082f9456ea in _nanosleep () from /lib/libc.so.7
                                #1 0x000000082b0bf82c in ?? () from /lib/libthr.so.3
                                #2 0x000000082f8c9c46 in usleep () from /lib/libc.so.7
                                #3 0x000000000059fa6a in ?? ()
                                #4 0x000000000059f3b4 in SuricataMain ()
                                #5 0x000000082f89b6fa in __libc_start1 () from /lib/libc.so.7
                                #6 0x000000000059bea0 in _start ()
                                (gdb) thread apply all bt full
                                • bmeeksB Offline
                                  bmeeks @kiokoman
                                  Hmm...okay, let's see how long the LAN stays up.
                                  Next question is "what is different in terms of VLANs and things like the Pass List for the two interfaces?"
                                  You said you cloned the LAN from the WAN, so I assume all the other settings are identical. The only changes would typically be the interface IP addresses and thus the composition of the resultant default Pass List.
                                  Are both WAN and LAN using the defaults for $HOME_NET, $EXTERNAL_NET, and Pass List?
                                  • kiokomanK Offline
                                    @bmeeks
                                    wan have no vlan
                                    lan have 2 vlan 100 and 110
                                    yup WAN and LAN are using the defaults for $HOME_NET, $EXTERNAL_NET, and Pass List
                                    • bmeeksB Offline
                                      bmeeks @kiokoman
                                      @bmeeks
                                      wan have no vlan
                                      Thank you for the info and test results.
                                      Maybe VLANs or no VLANs figures in ???
                                      Also a bit weird that Legacy Blocking Mode off seems to help (at least thus far in your individual testing).
                                      • kiokomanK Offline
                                        @bmeeks
                                        Delayed Detect Suricata will build list of signatures after packet capture threads have started. Default is Not Checked.
                                        if checked, suricata crash immediately with Hyperscan returned fatal error -1.
                                        now i'm trying without vlan and it's up and running for some times ....
                                        i can't stay without vlan for too long max 10 min before they find out and sends some ninja to kill me
                                        kiokomanK bmeeksB 2 Replies Last reply Reply Quote 0
                                        • kiokomanK Offline
                                          kiokoman LAYER 8 @kiokoman
                                          @bmeeks
                                          it crashed after 15 min but only after reactivating the vlan interfaces
                                          maybe it's vlan
                                          • bmeeksB Offline
                                            bmeeks @kiokoman
                                            @bmeeks
                                            Thank you for that additional info. The only way I can see the Delayed Detect playing into it is maybe increased memory usage (but just a guess).
                                            VLANs are one thing I did not test with in my small test environment. I run everything inside VMware Workstation and it does not support VLAN tagging.
