    295 Posts 25 Posters 134.8k Views 25 Watching
    • kiokomanK Offline
      kiokoman LAYER 8 @bmeeks
      @bmeeks
      idk if iperf3 can generate enough alert to trigger the bug maybe it's more like how many alert there are more than how mutch data is in the wire
        sgnoc
        @bmeeks I was trying to use the AC-KS pattern matcher as an alternative to hyperscan, but they must be related in some manner. This is the log I receive after just a few minutes running AC-KS. Also, I'm getting the hyperscan errors on my WAN interface, which remains busy, but also on this interface that has little traffic and does not alert all that often, so it isn't just interfaces that are more active on my network.
        Here is the last few lines in suricata.log for the failed interface running with AC-KS:
        [186263 - RX#01-ix1.15] 2023-12-07 09:37:41 Info: pcap: ix1.15: running in 'auto' checksum mode. Detection of interface state will require 1000 packets
        [186263 - RX#01-ix1.15] 2023-12-07 09:37:41 Info: pcap: ix1.15: snaplen set to 1518
        [100242 - Suricata-Main] 2023-12-07 09:37:41 Notice: threads: Threads created -> RX: 1 W: 4 FM: 1 FR: 1   Engine started.
        [186263 - RX#01-ix1.15] 2023-12-07 09:41:10 Info: checksum: No packets with invalid checksum, assuming checksum offloading is NOT used
        [186267 - W#04] 2023-12-07 09:46:00 Error: spm-hs: Hyperscan returned fatal error -1.
        Here are the output from the core dump:
        (gdb) bt
        #0  0x0000000830c6834a in thr_kill () from /lib/libc.so.7
        #1  0x0000000830be8344 in raise () from /lib/libc.so.7
        #2  0x0000000830c8ca39 in abort () from /lib/libc.so.7
        #3  0x0000000830cdbf30 in ?? () from /lib/libc.so.7
        #4  0x0000000830ca8440 in ?? () from /lib/libc.so.7
        #5  0x0000000830ca142c in ?? () from /lib/libc.so.7
        #6  0x0000000830ca1159 in ?? () from /lib/libc.so.7
        #7  0x00000000005ac55a in ConfNodeFree ()
        #8  0x00000000005ac536 in ConfNodeFree ()
        #9  0x00000000005ac536 in ConfNodeFree ()
        #10 0x00000000005ad305 in ConfDeInit ()
        #11 0x000000000058fa61 in ?? ()
        #12 0x000000000058f03f in SuricataMain ()
        #13 0x0000000830bbf75a in __libc_start1 () from /lib/libc.so.7
        #14 0x000000000058bd40 in _start ()
        (gdb) bt full
        No symbol table info available.
        (gdb) info threads
          Id   Target Id         Frame
        * 1    LWP 102018        0x0000000830c6834a in thr_kill () from /lib/libc.so.7
        (gdb) thread apply all bt
        Thread 1 (LWP 102018):
        (gdb) thread apply all bt full
        I'll try and run this interface on auto (hyperscan) and catpure the core dump to post the debug details here. Again, this is on my smaller interface that has been failing with suricata. If that doesn't prove as beneficial, I'll work on getting my wan interface to produce the core dump with hyperscan to get you that debug info.
        • bmeeksB Offline
          bmeeks @sgnoc
          @sgnoc said in Suricata process dying due to hyperscan problem:
          (gdb) bt
          (gdb) bt full
          (gdb) info threads
            Id   Target Id         Frame
          Thank you for this info. Weird that it seems to be crashing in a section of code where Suricata is releasing memory and cleaning up after reading the configuration from the suricata.yaml file. Those calls to ConfNodeFree() and ConfNodeInit() are made when finishing and cleaning up from reading the YAML conf file parameters.
          Let's see if another crash happens in the same area of code. One thing I noticed before (but that might have been with the Kill States bug and not Hyperscan) was the crash happened in seemingly random and unrelated places.
          Please continue posting the relevant sections of any future core dumps' backtrace as you did here.
            sgnoc
            @bmeeks I switched my WAN interface to auto. Here are the logs:
            (gdb) bt
            #0  0x000000082ff3f34a in thr_kill () from /lib/libc.so.7
            #1  0x000000082febf344 in raise () from /lib/libc.so.7
            #2  0x000000082ff63a39 in abort () from /lib/libc.so.7
            #3  0x000000082ffb2f30 in ?? () from /lib/libc.so.7
            #4  0x000000082ff7f440 in ?? () from /lib/libc.so.7
            #5  0x000000082ff7842c in ?? () from /lib/libc.so.7
            #6  0x000000082ff78159 in ?? () from /lib/libc.so.7
            #7  0x00000000005ac54c in ConfNodeFree ()
            #13 0x000000082fe9675a in __libc_start1 () from /lib/libc.so.7
            #14 0x000000000058bd40 in _start ()```
            (gdb) bt full
            (gdb) info threads
              Id   Target Id         Frame
            * 1    LWP 103117        0x000000082ff3f34a in thr_kill () from /lib/libc.so.7
            Thread 1 (LWP 103117):
            • bmeeksB Offline
              bmeeks @sgnoc
              (gdb) bt
              (gdb) bt full
              (gdb) info threads
                Id   Target Id         Frame
              So, it seems to be crashing in the same place. Struggling to tie this behavior back to Hyperscan and the custom Legacy Blocking Module, but perhaps there is some link there I'm missing. I'll dig around for a bit.
                sgnoc @bmeeks
                @bmeeks I can't help you with that side, but I know it keeps referencing hyperscan in the logs with the fatal error and it only occurs when I am using auto, which defaults to hyperscan, but also when I use AC-KS for the pattern matcher. It doesn't happen with AC only (I haven't tried AC-BS or specifically selecting hyperscan).
                [102876 - W#02] 2023-12-07 11:27:44 Error: spm-hs: Hyperscan returned fatal error -1.
                • tgm-itsT Offline
                  tgm-its
                  The strange thing.
                  Now after I set it to AC-BS it's been running for over 2 hours without failing.
                  So seems to be up now.
                  But does it work as it should?
                  I checked Alert and last entry there was for like 4 minute's ago.
                  Paal B.
                  • bmeeksB Offline
                    bmeeks
                    The Pattern Matcher Algorithm is not critical to whether detection works or not. It only matters in terms of speed versus memory consumption.
                    All fhe pattern matcher does is execute a regular expression (regex) search against packet data looking for whatever pattern the rule specified. The different algorithms all accomplish the exact same thing. It's just that some use less memory, but may run slower. Others may be lightning fast, but that speed comes from very high RAM consumption.
                    Hyperscan is a specialized regex library created by Intel to take advantage of certain complex math instruction op-codes present in their CPUs. Those specialized instructions that most Intel CPUs have allow for highly optimized regex searches. But because Hyperscan depends on instruction op-codes only present in Intel CPUs, the library does not work with ARM or any other non-Intel hardware.
                    The Auto setting for the Pattern Matcher algorithm in Suricata will default to the Hyperscan library if it is present. Otherwise it will choose AC (Aho-Corasick). When the Suricata binary is compiled on the Netgate package builder, it automatically senses which type of CPU is targeted (Intel or something else), and then includes the Hyperscan library only for Intel CPU targets. This means if you have a Netgate firewall appliance with an ARM chip, the Hyperscan library is not even present on your system.
                      gfeiner
                      FYI. 23.09.1 released with this memory allocation fix: https://www.freebsd.org/security/advisories/FreeBSD-EN-23:20.vm.asc
                        paulp @gfeiner
                        @gfeiner Unfortunately, in my case at least, Suricata still dies after this upgrade.
                        • kiokomanK Offline
                          kiokoman LAYER 8 @paulp
                          @paulp said in Suricata process dying due to hyperscan problem:
                          me too, still crashing
                          • tgm-itsT Offline
                            tgm-its
                            Hi all.
                            Just a question? Will the new update Version 2.7.2 of pFsense CE fix the Hyperscan error in Suricata?
                            If so I could update my Firewall if not I'll wait. 😌 😄
                            BR
                            Paal B.
                            • tylereversT Offline
                              tylerevers
                              Not sure what to make of this, but within 24 hours of updating to 23.09.1 one of my Interfaces in Suricata disappeared by itself. For reference, it was the only Interface I was having the Hyperscan issue with and it was running on AC-KS for weeks without an issue. It is the only one of three Interfaces that was using AC-KS instead of Auto.
                              I'm not quite sure how this happened. I woke up today and was just looking at systems to discover that one specific Suricata Interface had deleted itself.
                              • bmeeksB Offline
                                bmeeks @tylerevers
                                @tylerevers said in Suricata process dying due to hyperscan problem:
                                There is no mechanism within the package code for that to happen autonomously.
                                I would check first the pfSense system log on the impacted system to see what may be logged there, then look in the configuration backup history of pfSense to see if someone took an action. The GUI code logs an appropriate message for all configuration changes saved to the config.xml fiile. You can find the configuration entire history under DIAGNOSTICS > BACKUP AND RESTORE.
                                tylereversT 1 Reply Last reply Reply Quote 1
                                • bmeeksB Offline
                                  bmeeks
                                  Fingers crossed, but I think I found the bug.
                                  I definitely found an errant double free() of memory when processing IPv4 addresses in a Pass List. When you execute a double free() of memory you will get random crashes.
                                  Since I have been unable to reproduce the problem, I can't say for sure what I found will fix the Hyperscan issue, but I am hopeful based on the fact several of you have stated that turning off Legacy Blocking Mode (in other words, running in plain IDS mode) allows Suricata to run with no issue. The double free() was in the custom Legacy Blocking Module, and it was located in new code that was added with the first 7.0.0 Suricata update back when 23.09 Plus was still in development mode and 2.8 CE snapshots were active. Disabling Legacy Blocking Mode means this buggy portion of the module's code is not executed.
                                  I will create a pull request and get this fix posted for Netgate to review and merge. That will not happen until the first of the coming week.
                                  Update: the fix is posted at https://github.com/pfsense/FreeBSD-ports/pull/1333 for review and merge by the Netgate developer team.
                                  kiokomanK 1 Reply Last reply Reply Quote 5
                                  • kiokomanK Offline
                                    @bmeeks
                                    just out of curiosity, what's the difference between "free" and "SCfree" ? i understand that free() it's to deallocates the memory but i can't find reference for scfree
                                    • bmeeksB Offline
                                      bmeeks @kiokoman
                                      @kiokoman said in Suricata process dying due to hyperscan problem:
                                      @bmeeks
                                      Not a thing currently. The upstream Suricata developers just wrap some common C functions with their own names in case they might ever want to customize them for some reason. Today the two are exactly the same. Here are the #define preprocessor definitions currently in use by upstream:
                                      #define SCMalloc malloc
                                      #define SCCalloc calloc
                                      #define SCRealloc realloc
                                      #define SCFree free
                                      I just fixed up my code to stay in sync. It was an overlooked typo thing that I noticed while scrutinizing the code for any possible bug.
                                      Line 718 in the GitHub link I posted is where the errant double free() call happened. Notice the new revision deletes that line.
                                      Line 676 was a misplaced continue statement that could result in a memory leak because it bypasses the free() call to dump the IPv4 address structure created and passed to us elsewhere in the code. Notice the continue statement was moved to be after the free() call.
                                      The other changes are just cosmetic.
                                      kiokomanK 1 Reply Last reply Reply Quote 1
                                      • kiokomanK Offline
                                        @bmeeks
                                        now i understand, thanks for the explanation
                                          tylerevers @bmeeks
                                          Thank you for your guidance. The configuration history indicated that my specific user made the change. My apologies for the red herring.
                                          • bmeeksB Offline
                                            bmeeks
                                            My pull request containing the anticipated fix for this Hyperscan error has been merged. An updated Suricata package has built and should appear as an available update for 2.7.2 CE and 23.09.1 Plus users.
                                            Look for an update to version 7.0.2_2 for the Suricata package. When installed, the new package should pull in version 7.0.2_5 of the Suricata binary.
                                            Fingers crossed this fixes the Hyperscan issue. But as I mentioned previously, since I could never reproduce the error in my small test environment, I can't say with 100% certainty the bug I found and fixed is the actual Hyperscan culprit.
                                            N kiokomanK tylereversT 3 Replies Last reply Reply Quote 2
