    295 Posts 25 Posters 135.0k Views 25 Watching
      NRgia @bmeeks
      My pull request containing the anticipated fix for this Hyperscan error has been merged. An updated Suricata package has built and should appear as an available update for 2.7.2 CE and 23.09.1 Plus users.
      Look for an update to version 7.0.2_2 for the Suricata package. When installed, the new package should pull in version 7.0.2_5 of the Suricata binary.
      For 23.09.1 I can confirm that it is available.
      After the update I can see these packages
      pfSense-pkg-suricata-7.0.2_2   pfSense package suricata
      suricata-7.0.2_5               High Performance Network IDS, IPS and Security Monitoring engine
      Thank you
      • kiokomanK Offline
        kiokoman LAYER 8 @bmeeks
        @bmeeks
        tested
        and .....
        not working.. 😀
        [340341 - RX#01-vmx2] 2023-12-11 22:42:50 Info: checksum: No packets with invalid checksum, assuming checksum offloading is NOT used
        [340346 - W#05] 2023-12-11 22:42:53 Error: spm-hs: Hyperscan returned fatal error -1.
        [340347 - W#06] 2023-12-11 22:42:53 Error: spm-hs: Hyperscan returned fatal error -1.
        • bmeeksB Offline
          bmeeks @kiokoman
          @kiokoman said in Suricata process dying due to hyperscan problem:
          @bmeeks
          tested
          and .....
          not working.. 😀
          Well, crap! I had high hopes.
          Does it still work if you disable blocking mode?
          • kiokomanK Offline
            @bmeeks
            yes, it's running on an interface i have without blocking mode
            • bmeeksB Offline
              bmeeks @kiokoman
              @bmeeks
              Please share the output of this command run from a shell prompt:
              pkg info | grep suricata
              Let's make sure you have the latest binary. It should show suricata-7.0.2_5.
              • kiokomanK Offline
                @bmeeks
                Shell Output - pkg info | grep suricata
                this is pfsense 2.7.2
                the strange part is that i have another pfsense 23.09.1-RELEASE that it's running on vmware with the same packages and more vlans but it have no trouble ....
                the only difference is that 23.09.1 is running with 4 cpu and 2.7.2 with 8 cpu
                tomorrow i can try to lower the cpu and see if there is any difference
                • NeganN Offline
                  Negan
                  Still broken here also..... :-(
                  [177766 - RX#01-ix0] 2023-12-12 06:48:02 Info: checksum: More than 1/10th of packets have an invalid checksum, assuming checksum offloading is used (193/1000)
                  [177768 - W#02] 2023-12-12 07:17:29 Error: spm-hs: Hyperscan returned fatal error -1.
                    paulp
                    After upgrade, the problem with the hyperscan error still occurs for me as well.
                    • bmeeksB Offline
                      bmeeks
                      Well, sorry but I'm fresh out of ideas at this point. I have no clue what it could be. That fix was my last best hope.
                      Since I cannot reproduce the problem, it makes it practically impossible to troubleshoot and debug.
                        Maltz @bmeeks
                        @bmeeks I think I mentioned it somewhere else, too, but the problem only occurs for me (Netgate 2100) when I have DNSBL (pfBlocker) running also. Have you tried that combo to reproduce? (Or at least occurs much faster - I've only run it for a few days in a row with DNSBL disabled, but when both are running, Suricata dies within 5-15 minutes.)
                        • NeganN Offline
                          Negan
                          I should have also mentioned I'm running a Netgate 8200,..
                            paulp
                            I also have pfBlockerBG active. I will uninstall it to see if the problem still occurs.
                            @bmeeks: On one of my pfsense servers the problem manifests itself relatively quickly - a few hours.
                            I would be happy if I could somehow help to identify the problem.
                              sgnoc
                              Not sure why, but I haven't had a single segfault kill my suricata interfaces running auto on my netgate 7100 for the last few hours, after the upgrade. It would have normally long since had the hyperscan error and core dumped the process. I'm keeping an eye on it, but so far so good.
                              • BismarckB Offline
                                Bismarck
                                Same here with pattern match auto or blocking enabled, suricata still won't start.
                                • NeganN Offline
                                  Negan
                                  Output from my 8200
                                    paulp
                                    I uninstalled pfBlockerNG, but the error persists on the wan interface.
                                    (It is a hyper-v machine with Pfsense 23.09.1-RELEASE with suricata-7.0.2_5)
                                    • bmeeksB Offline
                                      bmeeks @Bismarck
                                      @Bismarck said in Suricata process dying due to hyperscan problem:
                                      What error do you get on startup if you leave the Pattern Matcher set to AC-KS but enable only blocking? In other words, enable blocking but do not change the Pattern Matcher setting.
                                      Show the output of the suricata.log file for the impacted interface (located under the LOGS VIEW tab) and also post anything relevant during the same time from the pfSense system log (under STATUS > SYSTEM LOGS).
                                      BismarckB 1 Reply Last reply Reply Quote 0
                                      • BismarckB Offline
                                        Bismarck @bmeeks
                                        @bmeeks no error, "pattern match auto" or "blocking enabled" kills suricata. AC-KS or "disabling blocking" is fine.
                                        • bmeeksB Offline
                                          bmeeks @Bismarck
                                          Help me understand this better...
                                          I've gotten a lot of seemingly conflicting information from the posters in this long thread. My confusion is leading to frustration 😧.
                                          1. So if you leave Pattern Matching at AC-KS and enable blocking, Suricata starts and runs with no issue. Is that correct?
                                          2. The only way to make it crash is to set Pattern Matcher to Auto with blocking enabled? Is that correct?
                                          3. And just to close the loop- if you set Pattern Matcher to Auto but disable blocking Suricata starts without error. Is that correct?
                                          For the crash configurations, what is the output of the suricata.log file? Is it always the "Hyperscan returned fatal error -1" message?
                                          • BismarckB Offline
                                            Bismarck @bmeeks
                                            @bmeeks
                                            1. yes
                                            2. yes
                                            3. yes
                                            suricata.log stops at this line
                                            [118101 - Suricata-Main] 2023-12-12 15:10:30 Error: detect: error parsing signature "alert tcp any any -> any $HTTP_PORTS (msg:"SERVER-WEBAPP Microsoft SharePoint OAuth authentication bypass attempt"; flow:to_server,established; content:"access_token="; fast_pattern; nocase; http_client_body; base64_decode:bytes 100,relative; base64_data; content:"|22|alg|22|"; nocase; content:"|22|none|22|"; within:50; nocase; content:"/_api/"; nocase; http_uri; pcre:"/\x2f_api\x2f(web\x2f|lists\x2f|Microsoft|SP\x2e|_vti_bin|_layouts|apps\x2f|search\x2f)/Ui"; metadata:policy balanced-ips drop, policy max-detect-ips drop, policy security-ips drop, service http; reference:cve,2023-29357; reference:url,portal.msrc.microsoft.com/en-us/security-guidance/advisory/CVE-2023-29357; classtype:attempted-admin; sid:62467; rev:1;)" from file /usr/local/etc/suricata/suricata_10547_igc2/rules/suricata.rules at line 33984
                                            [118101 - Suricata-Main] 2023-12-12 15:10:30 Error: detect-parse: "http_uri" keyword seen with a sticky buffer still set.  Reset sticky buffer with pkt_data before using the modifier.
                                            [118101 - Suricata-Main] 2023-12-12 15:10:30 Error: detect: error parsing signature "alert tcp any any -> any $HTTP_PORTS (msg:"SERVER-WEBAPP Microsoft SharePoint OAuth authentication bypass attempt"; flow:to_server,established; content:"access_token="; nocase; http_client_body; base64_decode:bytes 100,relative; base64_data; content:"|22|alg|22|"; nocase; content:"|22|none|22|"; within:50; nocase; content:"/_layouts/15/"; fast_pattern:only; http_uri; metadata:policy balanced-ips drop, policy max-detect-ips drop, policy security-ips drop, service http; reference:cve,2023-29357; reference:url,portal.msrc.microsoft.com/en-us/security-guidance/advisory/CVE-2023-29357; classtype:attempted-admin; sid:62465; rev:1;)" from file /usr/local/etc/suricata/suricata_10547_igc2/rules/suricata.rules at line 33986
                                            [118101 - Suricata-Main] 2023-12-12 15:10:30 Info: detect: 2 rule files processed. 34422 rules successfully loaded, 61 rules failed
                                            [118101 - Suricata-Main] 2023-12-12 15:10:30 Warning: threshold-config: can't suppress sid 2210063, gid 1: unknown rule
                                            [118101 - Suricata-Main] 2023-12-12 15:10:30 Info: threshold-config: Threshold config parsed: 1 rule(s) found
                                            system log gives:
                                            kernel pid 72109 (suricata), jid 0, uid 0: exited on signal 11 (core dumped)
                                            /edit for suricata.log
