    SG-2100-MAX System crashes with Compex use and 1gbps fiber
    reboots
    35 Posts 2 Posters 5.9k Views 2 Watching
    • JonathanLeeJ Offline
      JonathanLee @stephenw10
      @stephenw10 The second reboot gave me a good report it looks to be the same what part do you need to see from it?
      Filename: /var/crash/info.0
      Dump header from device: /dev/ada0s3b
        Architecture: aarch64
        Architecture Version: 4
        Dump Length: 154624
        Blocksize: 512
        Compression: none
        Dumptime: 2024-05-07 15:05:11 -0700
        Hostname: Lee_Family.home.arpa
        Magic: FreeBSD Text Dump
        Version String: FreeBSD 14.0-CURRENT #1 plus-RELENG_23_05_1-n256108-459fc493a87: Wed Jun 28 04:25:15 UTC 2023
          root@freebsd:/var/jenkins/workspace/pfSense-Plus-snapshots-23_05_1-main/obj/aarch64/0P4W6joa
        Panic String: Unhandled EL1 external data abort
        Dump Parity: 3539364660
        Bounds: 0
        Dump Status: good
      >  run pfs
      db:1:pfs> bt
      Tracing pid 12 tid 100070 td 0xffff00009c22c600
      db_trace_self() at db_trace_self
      db_stack_trace() at db_stack_trace+0x11c
      db_command() at db_command+0x358
      db_script_exec() at db_script_exec+0x1a4
      db_script_kdbenter() at db_script_kdbenter+0x58
      db_trap() at db_trap+0xf4
      kdb_trap() at kdb_trap+0x284
      handle_el1h_sync() at handle_el1h_sync+0x10
      --- exception, esr 0
      $d.6() at 0xffff000097000a63
      db:1:pfs>  show registers
      spsr                0x600000c5
      x0                        0x12
      x1                         0xa
      x2                         0x4
      x3                         0xa
      x4          0xffff000000ad0244  generic_bs_w_4
      x5                        0x50
      x6          0xffff00000067adec  kvprintf+0x470
      x7                        0xd5
      x8                         0x1
      x9          0x36c353fc715cf827
      x10         0xffff0000023d9000  nfsheur+0x5480
      x11         0xfefefefefefefeff
      x12         0xffff000097000a63
      x13             0xfeff00ff0100
      x14                          0
      x15                          0
      x16                          0
      x17                          0
      x18         0xffff000097280590
      x19         0xffff000002433000  epoch_array+0x1280
      x20         0xffff000002401eb0  vpanic.buf
      x21         0xffff00009c22c600
      x22                          0
      x23         0xffff000002401000  proc_id_reapmap+0x2870
      x24         0xffffa000019efc80
      x25         0xffff000002191000  version+0x130
      x26                          0
      x27         0xffff000002192e98  Giant+0x18
      x28         0xffffa000019efc80
      x29         0xffff000097280590
      lr          0xffff000000673a68  kdb_enter+0x40
      elr         0xffff000000673a6c  kdb_enter+0x44
      sp          0xffff000097280590
      kdb_enter+0x44: undefined       f907c27f
      db:1:pfs>  show pcpu
      cpuid        = 1
      dynamic pcpu = 0x3eb20180
      curthread    = 0xffff00009c22c600: pid 12 tid 100070 critnest 1 "pcib0,0: ath0"
      curpcb       = 0xffff000097280b40
      fpcurthread  = 0xffff0000e2539000: pid 98459 "snort"
      idlethread   = 0xffff000040ebb800: tid 100004 "idle: cpu1"
      curvnet      = 0
      db:1:pfs>  run lockinfo
      db:2:lockinfo> show locks
      No such command; use "help" to list available commands
      db:2:lockinfo>  show alllocks
      db:2:lockinfo>  show lockedvnods
      Locked vnodes
      db:1:pfs>  acttrace
      Tracing command intr pid 12 tid 100031 td 0xffff000096fb5000 (CPU 0)
      ipi_stop() at ipi_stop+0x30
      arm_gic_v3_intr() at arm_gic_v3_intr+0xe8
      intr_irq_handler() at intr_irq_handler+0x7c
      handle_el1h_irq() at handle_el1h_irq+0xc
      --- interrupt
      Tracing command intr pid 12 tid 100070 td 0xffff00009c22c600 (CPU 1)
      _db_stack_trace_all() at _db_stack_trace_all+0xe8
      db:1:pfs>  ps
      Make sure to upvote
        JonathanLee
        <118> Starting /usr/local/etc/rc.d/sqp_monitor.sh...done.
        <118>Netgate pfSense Plus 23.05.1-RELEASE arm64 Wed Jun 28 03:57:42 UTC 2023
        <118>Bootup complete
        <6>mvneta0: promiscuous mode enabled
        ath0: ath_rx_pkt: rs_antenna > 7 (8542452)
        ath0: ath_rx_proc: kickpcu; handled 413 packets
          x0:                0
          x1: ffff00009c600000 ($d.6 + 999bb068)
          x2:             4038
          x3:                4
          x4:                1
          x5: ffff000097280840 ($d.6 + 9463b8a8)
          x6:                0
          x7:              200
          x8: ffff000000ad0114 (generic_bs_r_4 + 0)
          x9: ffff000000acff6c (generic_bs_barrier + 0)
         x10:                0
         x11:                0
         x12:                1
         x13:                1
         x14:             286b
         x15:             2af8
         x16:             2711
         x17:                0
         x18: ffff000097280880 ($d.6 + 9463b8e8)
         x19: ffff000096feb000 ($d.6 + 943a6068)
         x20: ffff00009c600000 ($d.6 + 999bb068)
         x21:             4038
         x22: ffff00000213aa80 (memmap_bus + 0)
         x23: ffff00009c236a74 ($d.6 + 995f1adc)
         x24: ffffa000019efc80
         x25: ffff000002191000 (version + 130)
         x26:                0
         x27: ffff000002192e98 (Giant + 18)
         x28: ffffa000019efc80
         x29: ffff000097280880 ($d.6 + 9463b8e8)
          sp: ffff000097280880
          lr: ffff000000167114 (ath_hal_reg_read + cc)
         elr: ffff000000ad0118 (generic_bs_r_4 + 4)
        spsr:         20000045
         far: ffff00009c604038 ($d.6 + 999bf0a0)
        panic: Unhandled EL1 external data abort
        cpuid = 1
        time = 1715119511
        KDB: enter: panic
        Make sure to upvote
          Yeah that looks pretty much the same. More is useful though just to be sure.
          You have a bunch of ath tunables if I recall? Have you tested without those?
          JonathanLeeJ 3 Replies Last reply Reply Quote 0
            @stephenw10 I removed all of them a while ago once it started working normally before the GB fiber
            The only one I have left is
            vfs.read_max Cluster read-ahead max block count = 128 for Squid
            Make sure to upvote
              @stephenw10 I even installed a brand new out of the box card to see if that resolves it same thing happens with the new card too
              Make sure to upvote
                @stephenw10 Do you want the whole crash report it is huge
                Make sure to upvote
                  That's not ath specific though, should be fine
                  JonathanLeeJ 2 Replies Last reply Reply Quote 0
                    @stephenw10 I wonder if I set channels wrong or something on the config side I have it set to 802.11a/n channel 151 or something and I think 11 for FCC with anywhere set and 60second for rekey and 3600 for group that was default values I have BSSintra communication set to no I just don't understand why it worked perfectly with the DSL and won't work now, I also use a traffic shaper for limiters CODEL with it set to 1000mbps to match my fiber line with 5000 for the length same thing reboots when I use that card
                    Make sure to upvote
                      @stephenw10 TAC asked me to submit a Redmine because they said it is a bug in that Ath driver
                      Make sure to upvote
                        Yup, it probably is. And it could well be specific to aarch64. There can't be many people using that combination.
                        Do you have several full crash reports yet?
                          @stephenw10 They wanted it submitted with the chipset info so they have what they need I guess.. I am confused as why it worked with 6mbs but not with the full speed that one report we got to them worked for finding the issue
                          Make sure to upvote
                            You opened a bug? A ticket?
                              https://redmine.pfsense.org/issues/15472
                              Make sure to upvote
                                Ok cool. It's specifically the Compex WLE200NX right? You should add that info to the bug.
                                  @stephenw10 said in SG-2100-MAX System crashes with Compex use and 1gbps fiber:
                                  Compex WLE200NX
                                  Done added
                                  Make sure to upvote
