Quectel EP06-E LTE Module changes pfSense+ NDI after cold start or hard reset
 You do have an alternate interface descriptor on interface 5. You could try setting it:
 usbconfig -d ugen0.2 -i 5 set_alt 1I don't really expect that to work TBH. It will probably just refuse as the interface is in use.
 Hi Everyone! Hello Steve!!Finally I got that Quectel EP06-E running in PPP-Mode WITHOUT having a dynamic MAC ueX Ethernet interface. Preamble: The cuaU Device which is held by the Modem-Card depends on your Hardware!! The named one here is only for Reference!! Steps: Connect (ssh) to the pfSense box, get a shell (option 8), and open the LTE cards AT-Interface via a serial link & cu cu -l /dev/cuaU0.3 -s 115200 -> serial connection to the Modem-Card w/ 115200 baud This "linespeed" is imho mandatory since other modes seem to "eat" typed or pasted characters, which was one of my faults here!
 Anyway: AVOID, if possible, to copy and paste AT Commands, the Card (imho) might missinterpret that command and responses w/ an error.Set the cards "usbnet" mode 2 and fix the "serial"-linespeed of that Card! AT+QCFG=“usbnet”,2 - Write the config to the Card
 AT&W - soft reboot the LTE-Card to activate the changes (no (hard-)reboot of the whole box necessary)
 AT+CFUN=1,1 "cu" will close and you are back on the shellprompt after a while. - Create  a PPP IF on the GUI.
 Parameters depend on your Cell-Provider-Plan to communicate w/ this Quectel device.
 BUT: pfSense here awaits a linespeed of 115200 (baud) to sqawk to the Modem-Card.
 This should be forced w/ the advanced settings at the ppp-IF page:
 Init String +IPR=115200 - Assign that newly build ppp-If to an OPT-Interface on your box
 That will do - I Hope ;-) - Its working for me, but maybe not perfectly described. Addendum:
 Possible "usbnet" Modes are:
 AT+QCFG=“usbnet”,0 < Default
 AT+QCFG=“usbnet”,1 < USB Ethernet IF,* w/ dhcp Server active on the Card. Typically w/ IP 192.168.225.xxx/24, GW 192.168.225.1
 AT+QCFG=“usbnet”,2 < PPP IF via /dev/cuaU0.3*W/ an auto generated MAC Address on ueX which changes the NID as in the Topic! Last but not least:
 Any suggestions, critic and so on are welcome!
 And also many Thanks to Steve for accompany, ideas and help w/ this topic!!
 Any typos and syntactic errors found here, can be kept by the finder ;-)
 Ah, nice. So it was just the console doing something funy at a different baud rate? Nice catch!
 @stephenw10 said in Quectel EP06-E LTE Module changes pfSense+ NID after cold start or hard reset: So it was just the console doing something funy at a different baud rate Seems to be that  and the pfSense software itself, because of the Baud-Rate while initiating the communication w/ the Card. and the pfSense software itself, because of the Baud-Rate while initiating the communication w/ the Card.
 Are there any options to change that to a lower or higher rate (i.E. to 921600 Baud -> AT+IPR=921600)? I would like to check that out and measure the troughput w/ different rates ...Anyway: One more USB/mPCIE Card which can be listed in the docs, I hope.
 The actual throughput is not limited by the ppp baud rate, you should see a lot more than 115kbps! I usually see ~30Mbps here on the Sierra modems. Pretty good signal area. I've seen reports of other getting ~60Mbps.
 OK. Guess I was too much in my "landline modem times" from the 80ties w/ the AT-Commands   The Gateway Monitoring ping-Times (public IP Address from within the Providers Network) and the RTT aren't really different from the other Mode.
 So its OK to me. I haven't measured the rates since my external Yagi-Antennas will move to a better place in a few weeks.
 Much more important for me was to prevent the change of the NDI.
 (BTW: Can someone change the Topic to the correct abbreviation...??)Even if the performance will not reach the old mode: I can only die one dead.
 @Famelazar said in Quectel EP06-E LTE Module changes pfSense+ NID after cold start or hard reset: Can someone change the Topic to the correct abbreviation...?? Done.
 Great!
 Many Thanks!
 @stephenw10 said in Quectel EP06-E LTE Module changes pfSense+ NID after cold start or hard reset: AT+QCFG=“usbnet After all, the Modem will respond to " AT+QCFG="usbnet",? "
