    Netgate Device ID changing on power loss
    25 Posts 5 Posters 3.5k Views 4 Watching
      n1ck31
      I'm having this issue where the NDI is constantly changing on a bare metal install. Does anyone else have this issue?
      It seems to be reproducible whenever I lose power & the APC NUT utility shuts it down, the NDI changes when it comes back online. Pulling out the power doesn't seem to reliably reproduce this.
      This makes it a nightmare for buying a plus license...
        What hardware is it? What NICs do you have?
        The usual reason for seeing this is using a USB NIC that doesn't report a MAC address to the driver. The driver then generates a random address at boot.
          n1ck31 @stephenw10
          https://www.asrockrack.com/general/productdetail.asp?Model=X470D4U2-2T
          Using the onboard X550-AT2
          I've attempted a bios update, still happens every hard power loss.
            What does ifconfig -vma show at the CLI?
            Does it have a USB IPMI NIC maybe? Or a cellular modem?
              Also check the boot logs for any errors from the NIC drivers.
                n1ck31 @stephenw10
                @stephenw10 said in Netgate Device ID changing on power loss:
                I've made the NDI change, checking the mac addresses of the interfaces before and after, they haven't changed.
                Looking through the IPMI i don't see any mention of a NIC being added via it (nor does ifconfig -vma show it)
                One thing I did notice just now is that network bonding is turned on in the IPMI. Maybe that has something to do with it? I'll disable it and test again.
                I forgot I have an I226 in there as well for my backup WAN.
                Here's the output of the ifconfig:
                /root: ifconfig -vma
                igc0: flags=1008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,LOWER_UP> metric 0 mtu 1500
                        description: LSWAN
                        options=4e020bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,WOL_MAGIC,RXCSUM_IPV6,TXCSUM_IPV6,HWSTATS,MEXTPG>
                        capabilities=4f43fbb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_UCAST,WOL_MCAST,WOL_MAGIC,VLAN_HWTSO,NETMAP,RXCSUM_IPV6,TXCSUM_IPV6,HWSTATS,MEXTPG>
                        ether 88:c9:b3:bf:75:60
                        inet [IP_REMOVED] netmask 0xffffffc0 broadcast 255.255.255.255
                        inet6 [IP_REMOVED]%igc0 prefixlen 64 scopeid 0x1
                        media: Ethernet autoselect (2500Base-T <full-duplex>)
                        status: active
                        supported media:
                                media autoselect
                                media 2500Base-T
                                media 1000baseT
                                media 1000baseT mediaopt full-duplex
                                media 100baseTX mediaopt full-duplex
                                media 100baseTX
                                media 10baseT/UTP mediaopt full-duplex
                                media 10baseT/UTP
                        drivername: igc0
                ix0: flags=1008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,LOWER_UP> metric 0 mtu 1500
                        description: WAN
                        options=4e138bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,WOL_UCAST,WOL_MCAST,WOL_MAGIC,VLAN_HWFILTER,RXCSUM_IPV6,TXCSUM_IPV6,HWSTATS,MEXTPG>
                        capabilities=4f53fbb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_UCAST,WOL_MCAST,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,NETMAP,RXCSUM_IPV6,TXCSUM_IPV6,HWSTATS,MEXTPG>
                        ether d0:50:99:de:c1:1b
                        inet [IP_REMOVED] netmask 0xffffff00 broadcast [IP_REMOVED]
                        inet6 [IP_REMOVED]%ix0 prefixlen 64 scopeid 0x2
                        media: Ethernet autoselect (10Gbase-T <full-duplex>)
                        status: active
                        supported media:
                                media autoselect
                                media 5000Base-T
                                media 2500Base-T
                                media 100baseTX
                                media 1000baseT
                                media 10Gbase-T
                        drivername: ix0
                ix1: flags=1008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,LOWER_UP> metric 0 mtu 1500
                        description: LAN
                        ether d0:50:99:de:c1:1c
                        inet6 [IP_REMOVED]%ix1 prefixlen 64 scopeid 0x3
                        status: active
                        supported media:
                                media autoselect
                                media 5000Base-T
                                media 2500Base-T
                                media 100baseTX
                                media 1000baseT
                                media 10Gbase-T
                        drivername: ix1
                enc0: flags=0 metric 0 mtu 1536
                        options=0
                        capabilities=0
                        groups: enc
                        drivername: enc0
                lo0: flags=1008049<UP,LOOPBACK,RUNNING,MULTICAST,LOWER_UP> metric 0 mtu 16384
                        options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
                        capabilities=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
                        inet 127.0.0.1 netmask 0x0
                        inet6 ::1 prefixlen 128
                        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5
                        groups: lo
                        drivername: lo0
                pflog0: flags=100<PROMISC> metric 0 mtu 33152
                        options=0
                        capabilities=0
                        groups: pflog
                        drivername: pflog0
                pfsync0: flags=0 metric 0 mtu 1500
                        options=0
                        capabilities=0
                        maxupd: 128 defer: off version: 1400
                        syncok: 1
                        groups: pfsync
                        drivername: pfsync0
                ue0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
                        options=0
                        capabilities=0
                        ether 9a:95:62:30:fa:d5
                        drivername: ue0
                ix1.99: flags=1008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,LOWER_UP> metric 0 mtu 1500
                        description: TransitVLAN
                        options=4600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6,MEXTPG>
                        capabilities=4600703<RXCSUM,TXCSUM,TSO4,TSO6,LRO,RXCSUM_IPV6,TXCSUM_IPV6,MEXTPG>
                        inet [IP_REMOVED] netmask 0xfffffff8 broadcast [IP_REMOVED]
                        inet6 [IP_REMOVED]%ix1.99 prefixlen 64 scopeid 0xc
                        groups: vlan
                        vlan: 99 vlanproto: 802.1q vlanpcp: 0 parent interface: ix1
                        status: active
                        supported media:
                                media autoselect
                        drivername: vlan0
                ix1.25: flags=1008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,LOWER_UP> metric 0 mtu 1500
                        description: DMZ
                        inet6 [IP_REMOVED]%ix1.25 prefixlen 64 scopeid 0xd
                        groups: vlan
                        vlan: 25 vlanproto: 802.1q vlanpcp: 0 parent interface: ix1
                        status: active
                        supported media:
                                media autoselect
                        drivername: vlan1
                ovpns1: flags=1008043<UP,BROADCAST,RUNNING,MULTICAST,LOWER_UP> metric 0 mtu 1500
                        options=80000<LINKSTATE>
                        capabilities=80000<LINKSTATE>
                        inet6 [IP_REMOVED]%ovpns1 prefixlen 64 scopeid 0xe
                        groups: tun openvpn
                        Opened by PID 72330
                        drivername: tun1
                tun_wg0: flags=10080c1<UP,RUNNING,NOARP,MULTICAST,LOWER_UP> metric 0 mtu 1500
                        description: VPN
                        inet [IP_REMOVED] netmask 0xffffffff
                        groups: wg WireGuard
                        nd6 options=101<PERFORMNUD,NO_DAD>
                        drivername: wg0
                tun_wg1: flags=10080c1<UP,RUNNING,NOARP,MULTICAST,LOWER_UP> metric 0 mtu 1500
                        description: WSVPN
                        drivername: wg1
                tun_wg2: flags=10080c1<UP,RUNNING,NOARP,MULTICAST,LOWER_UP> metric 0 mtu 1500
                        description: TUNNEL
                        drivername: wg2
                tailscale0: flags=1008003<UP,BROADCAST,MULTICAST,LOWER_UP> metric 0 mtu 1280
                        groups: tun Tailscale
                        Opened by PID 44535
                        drivername: tun0
                  Ok it's almost certainly this:
                          options=0
                          capabilities=0
                          drivername: ue0
                  I'd bet that MAC changes between boots. Check the boot log for errors about the MAC there.
                  Do you know what that is?
                  If you don't need it you can probably disable it with a loader hint.
                    n1ck31 @stephenw10
                    @stephenw10 So from what I can gather, this Asrockrack board can share the ix0 port (which happens to be my wan) in addition to the dedicated IPMI port.
                    Posting the thread that I found this info on in case someone else has this issue in the future:
                    https://www.reddit.com/r/homelab/comments/ph9wgx/help_with_restricting_asrock_rack_x570d4u2l2t/
                    Running the following disables that sharing (which also happened to remove the ipmi from broadcasting on my WAN yikes)
                     ipmitool raw 0x32 0x71 0x00 0x01 0x00
                    As for that ue0 interface:
                            options=0
                            capabilities=0
                            ether 42:29:ea:ff:8a:1a
                            drivername: ue0
                    I don't know what that interface is, so it must be this "virtual" ipmi interface thingy, but it 100% changed after the hard power reset.
                    Can you let me know what the loader hint would be to just entirely disable it?
                    After running that IPMI tool cmd, here's the latest
                            description: LSWAN
                            inet [IP ADDRESS REMOVED] netmask 0xffffffc0 broadcast 255.255.255.255
                            inet6 fe80::8ac9:b3ff:febf:7560%igc0 prefixlen 64 scopeid 0x1
                            status: active
                            supported media:
                                    media autoselect
                                    media 2500Base-T
                                    media 1000baseT
                                    media 100baseTX
                                    media 10baseT/UTP
                            drivername: igc0
                            description: WAN
                            inet [IP ADDRESS REMOVED] netmask 0xffffff00 broadcast [IP ADDRESS REMOVED]
                            inet6 fe80::d250:99ff:fede:c11b%ix0 prefixlen 64 scopeid 0x2
                            status: active
                            supported media:
                                    media autoselect
                                    media 5000Base-T
                                    media 2500Base-T
                                    media 100baseTX
                                    media 1000baseT
                                    media 10Gbase-T
                            drivername: ix0
                            description: LAN
                            inet6 fe80::d250:99ff:fede:c11c%ix1 prefixlen 64 scopeid 0x3
                            status: active
                            supported media:
                                    media autoselect
                                    media 5000Base-T
                                    media 2500Base-T
                                    media 100baseTX
                                    media 1000baseT
                                    media 10Gbase-T
                            drivername: ix1
                            options=0
                            capabilities=0
                            groups: enc
                            drivername: enc0
                            inet [IP ADDRESS REMOVED] netmask 0x0
                            groups: lo
                            drivername: lo0
                            options=0
                            capabilities=0
                            groups: pflog
                            drivername: pflog0
                            options=0
                            capabilities=0
                            syncok: 1
                            groups: pfsync
                            drivername: pfsync0
                            options=0
                            capabilities=0
                            drivername: ue0
                            inet [IP ADDRESS REMOVED] netmask 0xfffffff8 broadcast [IP ADDRESS REMOVED]
                            inet6 fe80::d250:99ff:fede:c11c%ix1.99 prefixlen 64 scopeid 0xc
                            groups: vlan
                            status: active
                            supported media:
                                    media autoselect
                            drivername: vlan0
                            description: DMZ
                            inet6 fe80::d250:99ff:fede:c11c%ix1.25 prefixlen 64 scopeid 0xd
                            groups: vlan
                            status: active
                            supported media:
                                    media autoselect
                            drivername: vlan1
                            inet6 fe80::8ac9:b3ff:febf:7560%ovpns1 prefixlen 64 scopeid 0xe
                            groups: tun openvpn
                            Opened by PID 67240
                            drivername: tun1
                            description: VPN
                            inet [IP ADDRESS REMOVED] netmask 0xffffffff
                            drivername: wg0
                            description: WSVPN
                            drivername: wg1
                            description: TUNNEL
                            drivername: wg2
                            Opened by PID 7833
                            drivername: tun0
                      Run at the command line: echo 'hint.ue.0.disabled="1"' >> /boot/loader.conf.local
                      That should prevent the device attaching.
                      You may be able to disable it in the BIOS which would probably be a better solution as it would survive a reinstall. And would not affect any USB devices added in the future.
                        n1ck31 @stephenw10
                        @stephenw10 Thanks for that, unfortunately the NDI still changed again after a hard reset. (I double checked, its gone in the ifconfig command now)
                        Although that interface was probably part of the problem, it wasn't the only problem.
                        Do you have any other ideas? For now I've downgraded back to CE until I can get this solved.
                          n1ck31 @n1ck31
                          @n1ck31 said in Netgate Device ID changing on power loss:
                          Never mind, after another reboot, it's back. (ue0)
                          I've checked BIOS, nowhere to disable this that I can see.
                          • provelsP Offline
                            provels
                            Are you bridging interfaces? If not, never mind.
                            Peder
                            MAIN - pfSense+ 25.07.1-RELEASE - Adlink MXE-5401, i7, 16 GB RAM, 64 GB SSD. 500 GB HDD for SyslogNG
                            BACKUP - pfSense+ 23.01-RELEASE - Hyper-V Virtual Machine, Gen 1, 2 v-CPUs, 3 GB RAM, 8GB VHDX (Dynamic)
                              Hmm, it didn't disable it?
                              Do you see the line as expected in /boot/loader.conf.local?
                              Try running: usbconfig dump_device_desc
                              That might show you what that device actually is.
                                n1ck31 @provels
                                @provels Not intentionally, asrock has no options for it other than this network bond config which isn't the same thing.
                                @stephenw10 Yep, I can see it there in the file, and nope it didn't disable it.
                                This is the output of that command:
                                I don't see it there... (yet its still in the system)
                                /root: usbconfig dump_device_desc
                                ugen1.1: <AMD XHCI root HUB> at usbus1, cfg=0 md=HOST spd=SUPER (5.0Gbps) pwr=SA        VE (0mA)
                                  bLength = 0x0012
                                  bDescriptorType = 0x0001
                                  bcdUSB = 0x0300
                                  bDeviceClass = 0x0009  <HUB>
                                  bDeviceSubClass = 0x0000
                                  bDeviceProtocol = 0x0003
                                  bMaxPacketSize0 = 0x0009
                                  idVendor = 0x0000
                                  idProduct = 0x0000
                                  bcdDevice = 0x0100
                                  iManufacturer = 0x0001  <AMD>
                                  iProduct = 0x0002  <XHCI root HUB>
                                  iSerialNumber = 0x0000  <no string>
                                  bNumConfigurations = 0x0001
                                ugen0.1: <AMD XHCI root HUB> at usbus0, cfg=0 md=HOST spd=SUPER (5.0Gbps) pwr=SA        VE (0mA)
                                  bLength = 0x0012
                                  bcdUSB = 0x0300
                                  idVendor = 0x0000
                                  idProduct = 0x0000
                                  bcdDevice = 0x0100
                                ugen2.1: <AMD XHCI root HUB> at usbus2, cfg=0 md=HOST spd=SUPER (5.0Gbps) pwr=SA        VE (0mA)
                                  bLength = 0x0012
                                  bcdUSB = 0x0300
                                  idVendor = 0x0000
                                  idProduct = 0x0000
                                  bcdDevice = 0x0100
                                ugen0.2: <American Megatrends Inc. Virtual Hub> at usbus0, cfg=0 md=HOST spd=HIG        H (480Mbps) pwr=SAVE (100mA)
                                  bLength = 0x0012
                                  bcdUSB = 0x0200
                                  bDeviceProtocol = 0x0001
                                  bMaxPacketSize0 = 0x0040
                                  idVendor = 0x046b
                                  idProduct = 0xff01
                                  bcdDevice = 0x0100
                                  iManufacturer = 0x0001  <American Megatrends Inc.>
                                  iProduct = 0x0002  <Virtual Hub>
                                  iSerialNumber = 0x0003  <serial>
                                ugen0.3: <American Megatrends Inc. Virtual Ethernet> at usbus0, cfg=0 md=HOST sp        d=HIGH (480Mbps) pwr=ON (0mA)
                                  bLength = 0x0012
                                  bcdUSB = 0x0200
                                  bDeviceClass = 0x0002  <Communication device>
                                  bDeviceProtocol = 0x0000
                                  idVendor = 0x046b
                                  idProduct = 0xffb0
                                  bcdDevice = 0x0100
                                  iProduct = 0x0002  <Virtual Ethernet>
                                  iSerialNumber = 0x0003  <1234567890>
                                  bNumConfigurations = 0x0002
                                ugen0.4: <American Megatrends Inc. Virtual Keyboard and Mouse> at usbus0, cfg=0        md=HOST spd=LOW (1.5Mbps) pwr=ON (0mA)
                                  bLength = 0x0012
                                  bcdUSB = 0x0110
                                  bDeviceClass = 0x0000  <Probed by interface class>
                                  bMaxPacketSize0 = 0x0008
                                  idVendor = 0x046b
                                  idProduct = 0xff10
                                  bcdDevice = 0x0100
                                  iProduct = 0x0002  <Virtual Keyboard and Mouse>
                                ugen0.5: <American Megatrends Inc. Virtual Cdrom Device> at usbus0, cfg=0 md=HOS        T spd=HIGH (480Mbps) pwr=ON (0mA)
                                  bLength = 0x0012
                                  bcdUSB = 0x0200
                                  idVendor = 0x046b
                                  idProduct = 0xff20
                                  bcdDevice = 0x0100
                                  iProduct = 0x0002  <Virtual Cdrom Device>
                                  iSerialNumber = 0x0003  <AAAABBBBCCCC1>
                                ugen0.6: <American Megatrends Inc. Virtual HardDisk Device> at usbus0, cfg=0 md=        HOST spd=HIGH (480Mbps) pwr=ON (0mA)
                                  bLength = 0x0012
                                  bcdUSB = 0x0200
                                  idVendor = 0x046b
                                  idProduct = 0xff31
                                  bcdDevice = 0x0100
                                  iProduct = 0x0002  <Virtual HardDisk Device>
                                  iSerialNumber = 0x0003  <AAAABBBBCCCC3>
                                EDIT: Nevermind, here it is:
                                  Yup so it's a virtual device. If there's nothing in the BIOS then maybe something in the IPMI setup?
                                  How does it appear in the boot log when it attaches? You might need to try disabling cdce0 instead. If that's how it appears.
                                    n1ck31 @stephenw10
                                    @stephenw10 Nothing in both places. Only things I can disable are the virtual media devices & KBM emulation. No mention of any virtual network adapters at all.
                                    This is all thats mentioned of it in the boot log:
                                    uhub2: 6 ports with 6 removable, self powered
                                    uhub1: 6 ports with 6 removable, self powered
                                    uhub0: 22 ports with 22 removable, self powered
                                    Root mount waiting for: usbus0
                                    uhub3 on uhub0
                                    uhub3: <7-port Hub> on usbus0
                                    uhub3: 5 ports with 5 removable, self powered
                                    ukbd0 on uhub3
                                    ukbd0: <Keyboard Interface> on usbus0
                                    kbd2 at ukbd0
                                    • Bob.DigB Offline
                                      Bob.Dig LAYER 8 @n1ck31
                                      @n1ck31 Maybe try disabling the BMC with a jumper and see if this helps.
                                        It must list the device and the driver attaching to it in the boot log. Something like:
                                        ugen0.3: <Realtek USB 10/100/1G/2.5G LAN> at usbus0
                                        cdce0 on uhub0
                                        cdce0: <CDC Communications Control> on usbus0
                                        ue0: <USB Ethernet> on cdce0
                                        ue0: Ethernet address: 00:e0:81:21:78:ea
                                        And if it does appear like that try adding to loader.conf.local: hint.cdce.0.disabled="1"
                                          n1ck31 @Bob.Dig
                                          @Bob-Dig said in Netgate Device ID changing on power loss:
                                          Although that probably will solve the issue, that negates the scalped price I paid for this board originally - if i were to go this route I'd just buy a regular consumer board and swap it out.
                                            n1ck31 @stephenw10
                                            cdce0 on uhub0
                                            Here's the full log file
                                            It seems that it's usbus0 on xhci0, so maybe disabling xhci0?
                                            Copyright (c) 1992-2023 The FreeBSD Project.
                                            Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
                                            The Regents of the University of California. All rights reserved.
                                            FreeBSD is a registered trademark of The FreeBSD Foundation.
                                            FreeBSD 14.0-CURRENT amd64 1400094 #1 RELENG_2_7_2-n255948-8d2b56da39c: Wed Dec 6 20:45:47 UTC 2023
                                            root@freebsd:/var/jenkins/workspace/pfSense-CE-snapshots-2_7_2-main/obj/amd64/StdASW5b/var/jenkins/workspace/pfSense-CE-snapshots-2_7_2-main/sources/FreeBSD-src-RELENG_2_7_2/amd64.amd64/sys/pfSense amd64
                                            FreeBSD clang version 16.0.6 (https://github.com/llvm/llvm-project.git llvmorg-16.0.6-0-g7cbf1a259152)
                                            VT(efifb): resolution 1024x768
                                            CPU: AMD Ryzen 5 5600G with Radeon Graphics (3900.23-MHz K8-class CPU)
                                            Origin="AuthenticAMD" Id=0xa50f00 Family=0x19 Model=0x50 Stepping=0
                                            Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
                                            Features2=0x7ef8320b<SSE3,PCLMULQDQ,MON,SSSE3,FMA,CX16,SSE4.1,SSE4.2,x2APIC,MOVBE,POPCNT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
                                            AMD Features=0x2e500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM>
                                            AMD Features2=0x75c237ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT,TCE,Topology,PCXC,PNXC,DBE,PL2I,MWAITX,ADMSKX>
                                            Structured Extended Features=0x219c97a9<FSGSBASE,BMI1,AVX2,SMEP,BMI2,ERMS,INVPCID,PQM,PQE,RDSEED,ADX,SMAP,CLFLUSHOPT,CLWB,SHA>
                                            Structured Extended Features2=0x40069c<UMIP,PKU,OSPKE,VAES,VPCLMULQDQ,RDPID>
                                            Structured Extended Features3=0x10<FSRM>
                                            XSAVE Features=0xf<XSAVEOPT,XSAVEC,XINUSE,XSAVES>
                                            AMD Extended Feature Extensions ID EBX=0x191ef657<CLZERO,IRPerf,XSaveErPtr,RDPRU,WBNOINVD,IBPB,IBRS,STIBP,STIBP_ALWAYSON,PREFER_IBRS,SSBD>
                                            SVM: NP,NRIP,VClean,AFlush,DAssist,NAsids=32768
                                            TSC: P-state invariant, performance statistics
                                            real memory = 17179869184 (16384 MB)
                                            avail memory = 15924834304 (15187 MB)
                                            Event timer "LAPIC" quality 600
                                            ACPI APIC Table: <ALASKA A M I >
                                            FreeBSD/SMP: Multiprocessor System Detected: 12 CPUs
                                            FreeBSD/SMP: 1 package(s) x 6 core(s) x 2 hardware threads
                                            random: registering fast source Intel Secure Key RNG
                                            random: fast provider: "Intel Secure Key RNG"
                                            random: unblocking device.
                                            ioapic0 <Version 2.1> irqs 0-23
                                            ioapic1 <Version 2.1> irqs 24-55
                                            Launching APs: 1 3 2 10 7 11 6 8 9 4 5
                                            TCP_ratelimit: Is now initialized
                                            wlan: mac acl policy registered
                                            random: entropy device external interface
                                            kbd1 at kbdmux0
                                            WARNING: Device "spkr" is Giant locked and may be deleted before FreeBSD 14.0.
                                            netgate0: <unknown hardware>
                                            efirtc0: <EFI Realtime Clock>
                                            efirtc0: registered as a time-of-day clock, resolution 1.000000s
                                            smbios0: <System Management BIOS> at iomem 0xbcd72000-0xbcd7201e
                                            smbios0: Version: 3.3, BCD Revision: 3.3
                                            acpi0: <ALASKA A M I >
                                            acpi0: Power Button (fixed)
                                            cpu0: <ACPI CPU> on acpi0
                                            attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
                                            Timecounter "i8254" frequency 1193182 Hz quality 0
                                            Event timer "i8254" frequency 1193182 Hz quality 100
                                            atrtc0: <AT realtime clock> port 0x70-0x71 on acpi0
                                            atrtc0: registered as a time-of-day clock, resolution 1.000000s
                                            Event timer "RTC" frequency 32768 Hz quality 0
                                            hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff irq 0,8 on acpi0
                                            Timecounter "HPET" frequency 14318180 Hz quality 950
                                            Event timer "HPET" frequency 14318180 Hz quality 350
                                            Event timer "HPET1" frequency 14318180 Hz quality 350
                                            Event timer "HPET2" frequency 14318180 Hz quality 350
                                            Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
                                            acpi_timer0: <32-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
                                            pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
                                            pci0: <ACPI PCI bus> on pcib0
                                            pci0: <base peripheral, IOMMU> at device 0.2 (no driver attached)
                                            pcib1: <ACPI PCI-PCI bridge> at device 2.1 on pci0
                                            pci1: <ACPI PCI bus> on pcib1
                                            xhci0: <XHCI (generic) USB 3.0 controller> mem 0xfc6a0000-0xfc6a7fff irq 36 at device 0.0 on pci1
                                            xhci0: 32 bytes context size, 64-bit DMA
                                            usbus0 on xhci0
                                            usbus0: 5.0Gbps Super Speed USB v3.0
                                            ahci0: <AHCI SATA controller> mem 0xfc680000-0xfc69ffff irq 37 at device 0.1 on pci1
                                            ahci0: AHCI v1.31 with 8 6Gbps ports, Port Multiplier supported
                                            ahcich0: <AHCI channel> at channel 0 on ahci0
                                            ahcich1: <AHCI channel> at channel 1 on ahci0
                                            ahcich2: <AHCI channel> at channel 2 on ahci0
                                            ahcich3: <AHCI channel> at channel 3 on ahci0
                                            ahcich4: <AHCI channel> at channel 4 on ahci0
                                            ahcich5: <AHCI channel> at channel 5 on ahci0
                                            ahcich6: <AHCI channel> at channel 6 on ahci0
                                            ahcich7: <AHCI channel> at channel 7 on ahci0
                                            pcib2: <ACPI PCI-PCI bridge> irq 38 at device 0.2 on pci1
                                            pci2: <ACPI PCI bus> on pcib2
                                            pcib3: <ACPI PCI-PCI bridge> irq 36 at device 0.0 on pci2
                                            pci3: <ACPI PCI bus> on pcib3
                                            pcib4: <ACPI PCI-PCI bridge> irq 36 at device 0.0 on pci3
                                            pci4: <ACPI PCI bus> on pcib4
                                            vgapci0: <VGA-compatible display> port 0xf000-0xf07f mem 0xfb000000-0xfbffffff,0xfc000000-0xfc01ffff irq 36 at device 0.0 on pci4
                                            vgapci0: Boot video device
                                            pcib5: <ACPI PCI-PCI bridge> irq 37 at device 1.0 on pci2
                                            pci5: <ACPI PCI bus> on pcib5
                                            pcib6: <ACPI PCI-PCI bridge> irq 38 at device 2.0 on pci2
                                            pci6: <ACPI PCI bus> on pcib6
                                            pcib7: <ACPI PCI-PCI bridge> irq 39 at device 3.0 on pci2
                                            pci7: <ACPI PCI bus> on pcib7
                                            igc0: <Intel(R) Ethernet Controller I225-V> mem 0xfc300000-0xfc3fffff,0xfc400000-0xfc403fff irq 39 at device 0.0 on pci7
                                            igc0: Using 1024 TX descriptors and 1024 RX descriptors
                                            igc0: Using 4 RX queues 4 TX queues
                                            igc0: Using MSI-X interrupts with 5 vectors
                                            igc0: Ethernet address: 88:c9:b3:bf:75:60
                                            igc0: netmap queues/slots: TX 4/1024, RX 4/1024
                                            pcib8: <ACPI PCI-PCI bridge> irq 36 at device 4.0 on pci2
                                            pci8: <ACPI PCI bus> on pcib8
                                            nvme0: <Generic NVMe Device> mem 0xfc500000-0xfc503fff,0xfc504000-0xfc5040ff irq 36 at device 0.0 on pci8
                                            pcib9: <ACPI PCI-PCI bridge> irq 36 at device 8.0 on pci2
                                            pci9: <ACPI PCI bus> on pcib9
                                            pcib10: <ACPI PCI-PCI bridge> at device 2.2 on pci0
                                            pci10: <ACPI PCI bus> on pcib10
                                            ix0: <Intel(R) X550-T2> mem 0xe0800000-0xe0bfffff,0xe0c04000-0xe0c07fff irq 40 at device 0.0 on pci10
                                            ix0: Using 2048 TX descriptors and 2048 RX descriptors
                                            ix0: Using 6 RX queues 6 TX queues
                                            ix0: Using MSI-X interrupts with 7 vectors
                                            ix0: allocated for 6 queues
                                            ix0: allocated for 6 rx queues
                                            ix0: Ethernet address: d0:50:99:de:c1:1b
                                            ix0: PCI Express Bus: Speed 8.0GT/s Width x1
                                            ix0: Option ROM V1-b1927-p0 eTrack 0x80000aee PHY FW V523
                                            ix0: netmap queues/slots: TX 6/2048, RX 6/2048
                                            ix1: <Intel(R) X550-T2> mem 0xe0400000-0xe07fffff,0xe0c00000-0xe0c03fff irq 41 at device 0.1 on pci10
                                            ix1: Using 2048 TX descriptors and 2048 RX descriptors
                                            ix1: Using 6 RX queues 6 TX queues
                                            ix1: Using MSI-X interrupts with 7 vectors
                                            ix1: allocated for 6 queues
                                            ix1: allocated for 6 rx queues
                                            ix1: Ethernet address: d0:50:99:de:c1:1c
                                            ix1: PCI Express Bus: Speed 8.0GT/s Width x1
                                            ix1: Option ROM V1-b1927-p0 eTrack 0x80000aee PHY FW V523
                                            ix1: netmap queues/slots: TX 6/2048, RX 6/2048
                                            pcib11: <ACPI PCI-PCI bridge> at device 8.1 on pci0
                                            pci11: <ACPI PCI bus> on pcib11
                                            vgapci1: <VGA-compatible display> port 0xe000-0xe0ff mem 0xd0000000-0xdfffffff,0xe0000000-0xe01fffff,0xfcb00000-0xfcb7ffff irq 38 at device 0.0 on pci11
                                            hdac0: <ATI (0x1637) HDA Controller> mem 0xfcb88000-0xfcb8bfff irq 39 at device 0.1 on pci11
                                            pci11: <encrypt/decrypt> at device 0.2 (no driver attached)
                                            xhci1: <XHCI (generic) USB 3.0 controller> mem 0xfc900000-0xfc9fffff irq 37 at device 0.3 on pci11
                                            xhci1: 64 bytes context size, 64-bit DMA
                                            usbus1 on xhci1
                                            usbus1: 5.0Gbps Super Speed USB v3.0
                                            xhci2: <XHCI (generic) USB 3.0 controller> mem 0xfc800000-0xfc8fffff irq 38 at device 0.4 on pci11
                                            xhci2: 64 bytes context size, 64-bit DMA
                                            usbus2 on xhci2
                                            usbus2: 5.0Gbps Super Speed USB v3.0
                                            hdac1: <AMD Raven HDA Controller> mem 0xfcb80000-0xfcb87fff irq 36 at device 0.6 on pci11
                                            pcib12: <ACPI PCI-PCI bridge> at device 8.2 on pci0
                                            pci12: <ACPI PCI bus> on pcib12
                                            ahci1: <AMD KERNCZ AHCI SATA controller> mem 0xfcc01000-0xfcc017ff irq 34 at device 0.0 on pci12
                                            ahci1: AHCI v1.31 with 1 6Gbps ports, Port Multiplier supported with FBS
                                            ahcich8: <AHCI channel> at channel 0 on ahci1
                                            ahci2: <AMD KERNCZ AHCI SATA controller> mem 0xfcc00000-0xfcc007ff irq 35 at device 0.1 on pci12
                                            ahci2: AHCI v1.31 with 1 6Gbps ports, Port Multiplier supported with FBS
                                            ahcich9: <AHCI channel> at channel 0 on ahci2
                                            isab0: <PCI-ISA bridge> at device 20.3 on pci0
                                            isa0: <ISA bus> on isab0
                                            acpi_button0: <Power Button> on acpi0
                                            uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
                                            uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
                                            orm0: <ISA Option ROM> at iomem 0xc0000-0xc7fff pnpid ORM0000 on isa0
                                            hwpstate0: <Cool`n'Quiet 2.0> on cpu0
                                            Timecounter "TSC-low" frequency 1949999786 Hz quality 1000
                                            Timecounters tick every 1.000 msec
                                            ZFS filesystem version: 5
                                            ZFS storage pool version: features support (5000)
                                            nvme0: Allocated 200MB host memory buffer
                                            uhub0 on usbus1
                                            uhub0: <AMD XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus1
                                            uhub1 on usbus2
                                            uhub1: <AMD XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus2
                                            uhub2 on usbus0
                                            uhub2: <AMD XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
                                            hdacc0: <ATI R6xx HDA CODEC> at cad 0 on hdac0
                                            hdaa0: <ATI R6xx Audio Function Group> at nid 1 on hdacc0
                                            pcm0: <ATI R6xx (HDMI)> at nid 3 on hdaa0
                                            pcm1: <ATI R6xx (HDMI)> at nid 5 on hdaa0
                                            pcm2: <ATI R6xx (HDMI)> at nid 7 on hdaa0
                                            pcm3: <ATI R6xx (HDMI)> at nid 9 on hdaa0
                                            Trying to mount root from zfs:pfSense/ROOT/default []...
                                            nda0 at nvme0 bus 0 scbus10 target 0 lun 1
                                            nda0: <WD Blue SN570 250GB 234110WD 22395T804226>
                                            nda0: Serial Number 22395T804226
                                            nda0: nvme version 1.4
                                            nda0: 238475MB (488397168 512 byte sectors)
                                            uhub0: 6 ports with 6 removable, self powered
                                            uhub2: 22 ports with 22 removable, self powered
                                            uhub3 on uhub2
                                            ukbd0 on uhub3
                                            kbd2 at ukbd0
                                            CPU: AMD Ryzen 5 5600G with Radeon Graphics (3900.00-MHz K8-class CPU)
