    DNS not starting after power cycle
    3 Posts 2 Posters 337 Views 2 Watching
      thomasvoxtra
      Hi All,
      Strange behavior on one device (Netgate 4200 ; software version 24.03-RELEASE amd64).
      When powering up, the DNS (forward) service does not start automatically..
      LAN users cannot resolve external domains.
      When restarting the DNS service via the Web GUI, everything works.
      Backup and restored the config to another Netgate device => no problem
      Full factory reset => no problem
      Restore of the config => not working
      Any ideas where I can continue searching ?
      Can this be hardware related ?
      Thanks for your feedback!
      Best Regards
      Thomas
        Gertjan @thomasvoxtra
        @thomasvoxtra said in DNS not starting after power cycle:
        I'll change the phrasing :
        Netgate's default setup : it works.
        The setup modified by you : doesn't work.
        When you use the default Netgate setup, note down every DNS related setting.
        Then get your settings back in, and change every DNS settings to default.
        Ah, some chip or resistor or cap broke and only DNS stops working ?
        Euh ...... noop, good news, don't worry, your hardware is fine.
          thomasvoxtra @Gertjan
          @Gertjan Thank you for your feedback, Gertjan!
          I'll continue with that info :)
          Have a great day
