    Please need help for this problem.
    6 Posts 2 Posters 2.6k Views
    • L Offline
      ll_hellBoy_ll
      Hi. Please I need help to configure my dual wan setup. I am sure I did something wrong that’s why my load balance is not working. For example I am seeing my both wan is online but my only one connection is using. Cause when I speed test or either surfing its very slow.
      I have 2 adsl connection from same ISP. My primary wan speed is 8 mbps and second one 24 mbps. but my load balancer is not working.
      I have 26 workstation in my network. It’s a internet café.
      Even if my primary wan goes down my all internet goes down.. so it means failover also not working.
      My current setup like this.
      8 mbps primary Adsl modem setup.
      Bridge Mode.
      Modem Ip = 10.0.0.138
      DHCP = Disable
      Pfsense primary setup for 8 mbps primary Adsl modem
      Ppope – user name and password
      24 mbps second Adsl Modem Setup
      PPope,  user name and password
      DHCP = Enable
      Modem ip = 192.168.2.1
      Pfsense opt1 setup for 24 mbps second Adsl Modem
      DHCP
      Ip address – 192.168.2.2/24
      Gateway – 192.168.2.1
      . I attach all the picture what I did on configuration page.
      Please let me know what I did wrong. So that I can fix it. I will wait for the answer. Thank you. Please try to help me. Its very important …..God bless
      ![loadblance Pro.JPG](/public/imported_attachments/1/loadblance Pro.JPG)
      ![loadblance Pro.JPG_thumb](/public/imported_attachments/1/loadblance Pro.JPG_thumb)
      loadblance.JPG_thumb
      loadblace&failover.JPG_thumb
      • L Offline
        ll_hellBoy_ll
        please help me. why my load-balance and failover is not working.
        i can ping both my wan connection from pfsense.and i can see all my connection is green on load-blance status.
        i can access my both wan's modem also from my lan.
        my both modem setup as a ppope. my modem's getting public ip. and pfsense as a DHCP for both wan.
        I am uploading my all picture for help. Please help me
        inteface1.JPG_thumb
        inteface2.JPG_thumb
        • L Offline
          ll_hellBoy_ll
          my other picture.
          thse are my current setup. please help me. how can i fix this problem. thank you
          ![loadblance pool.JPG](/public/imported_attachments/1/loadblance pool.JPG)
          ![loadblance pool.JPG_thumb](/public/imported_attachments/1/loadblance pool.JPG_thumb)
          rules.JPG_thumb
          ![static route.JPG](/public/imported_attachments/1/static route.JPG)
          ![static route.JPG_thumb](/public/imported_attachments/1/static route.JPG_thumb)
          • L Offline
            ll_hellBoy_ll
            Really dont know why i am not getting any help. please help me. i cant fix it. my load balance and failover is not working. but i am seeing my both wan is online on pfsense. please what i have to do for this problem.
            I will wait for the help. thank you
            • L Offline
              ll_hellBoy_ll
              Thanks to God. That At last I able made it. I am very very happy now. Its working now like a charm.though i have little problem on delay. other wise everything is working. My load Balancer and fail-over all working. I will try to solve the delay when my second wan goes online. Thank you very very much Pfsense and the Developer that they made a such a great Product. I am glad that i am using it. Thank you all and God bless all. Ba bye
              • O Offline
                overand
                I see you're double-NATed (your 'routers'  that your pfSense box is plugged into are also NAT routers themselves) - this can cause some complications and confusion.
                I would suggest you make sure that under WAN you have disabled (no checkmark in) the "Block Private (RFC 1918) addresses" - that could cause a number of issues.
