    Speed issue running 2.0-BETA5 (i386)
    3 Posts 2 Posters 1.5k Views
      jag2000
      I apologize if this is a duplicate post but i couldnt find anything directly related to this. have a cable modem currently configured for 15mb down 2 mb up.
      If i bypass the pf sense box and plug into my router directly (natted) I get around 14.8 down and 1.7 up. when connected to PF Sense via switch it lags and then bursts to around 95mb down and 5 up. (i wish right ) i am unsure if this is HAVP antivirus scanning the "download" before it actually does the test or if this is a glitch. when i was running 1.23 the speed tests were fine. same box same setup at home. Please let me know if you need more data .
        Cino
        Have you tried the speed test without HAVP enabled? If not, try that. Being that 2.0 is in beta, packages can break quickly as they are not updated right away.
        I have a 50/5 cable modem and below are my results from a my ISP speedtest site. Mind you this speedtest website is only a couple of hops away from the UBRs that control the cable modem. I'm running 2.0-BETA5 (i386) built on Fri Jan 28 05:30:15 EST 2011. As far as packages, i'm running snort and a couple of others but they wouldn't effect the speed.
        Last Result:
        Download Speed: 48810 kbps (6101.3 KB/sec transfer rate)
        Upload Speed: 5045 kbps (630.6 KB/sec transfer rate)
          jag2000
          50x5 damm.
          yes i did disable hvap and actually it completely killed my internet connection. interesting…
