    Load Balance and Squid does not work runnig in the same server
    53 Posts 17 Posters 46.3k Views
      rubic
      @ermal:
      Only the nat rules are executed.
      There is one moment with NAT unclear to me. According to pf packet flow diagram (http://homepage.mac.com/quension/pf/flow.png) filtering happen after SNAT. That's why in the rule log we see: if:WAN src:WAN IP -> dst:remote host IP. But when packet rerouted by the policy routing rule reaches OPT-WAN outgoing chain (assuming WAN is down) it's source address appears magically restored to 127.0.0.1. Which block on the diagram do that?
        heper
        my "how-to" can be translated in any language … it's only purpose was to return the info i got from ermal to the community ;)
        • E Offline
          eri--
          rubic, its pfSense customized pf(4), by me. :)
          This functionality can not be done with standard pf(4), at least the version that is used on FreeBSD, without too much tinkering.
            rubic
            @ermal:
            Ok, now I see :) Thank you for your work!
            translated: http://forum.pfsense.org/index.php/topic,34810.0.html
            • L Offline
              lnaimi
              Ok the guide works with FailOver, but for LoadBalance???? Thanks
                juniorghr
                Please, where I am testing the sense pf 2.0 is required to enter some sites that require https and when I configure squid with loadbalance the gateway connection changes every time, how can I fix this?
                Please help.
                • F Offline
                  Frozen_Fire
                  Please help…Load balancing is ok...but squid is not functioning...please do some ups in the floating rule..
                  Thank you...
                    heper
                    @juniorghr
                    well you could create a dedicated gateway group with failover (different tiers) and add a seperate rule  for https traffic to use that gateway group …..
                    or you could enable 'sticky connections' in system  .... but i don't know if that would solve all issues
                    • O Offline
                      onkeldave83
                      Yes, BUT WITH THIS SOLUTION YOU CANT HAVP as parent for SQUID ;)
                      • F Offline
                        farrukhndm
                        I Follow the same above procedure but no success,My browser just working working and working without showing any results.
                        my configurations are.
                        My browser dosn't open any page after given settings ?????..Where I have take mistake. please guide me .
                        ![2011-04-29, 11_55_27.jpg](/public/imported_attachments/1/2011-04-29, 11_55_27.jpg)
                        ![2011-04-29, 11_55_27.jpg_thumb](/public/imported_attachments/1/2011-04-29, 11_55_27.jpg_thumb)
                        ![2011-04-29, 11_55_32.jpg](/public/imported_attachments/1/2011-04-29, 11_55_32.jpg)
                        ![2011-04-29, 11_55_32.jpg_thumb](/public/imported_attachments/1/2011-04-29, 11_55_32.jpg_thumb)
                        ![2011-04-29, 11_55_42.jpg](/public/imported_attachments/1/2011-04-29, 11_55_42.jpg)
                        ![2011-04-29, 11_55_42.jpg_thumb](/public/imported_attachments/1/2011-04-29, 11_55_42.jpg_thumb)
                        ![2011-04-29, 11_55_47.jpg](/public/imported_attachments/1/2011-04-29, 11_55_47.jpg)
                        ![2011-04-29, 11_55_47.jpg_thumb](/public/imported_attachments/1/2011-04-29, 11_55_47.jpg_thumb)
                        ![2011-04-29, 11_56_02.jpg](/public/imported_attachments/1/2011-04-29, 11_56_02.jpg)
                        ![2011-04-29, 11_56_02.jpg_thumb](/public/imported_attachments/1/2011-04-29, 11_56_02.jpg_thumb)
                        ![2011-04-29, 11_56_10.jpg](/public/imported_attachments/1/2011-04-29, 11_56_10.jpg)
                        ![2011-04-29, 11_56_10.jpg_thumb](/public/imported_attachments/1/2011-04-29, 11_56_10.jpg_thumb)
                        ![2011-04-29, 11_56_33.jpg](/public/imported_attachments/1/2011-04-29, 11_56_33.jpg)
                        ![2011-04-29, 11_56_33.jpg_thumb](/public/imported_attachments/1/2011-04-29, 11_56_33.jpg_thumb)
                        ![2011-04-29, 11_57_39.jpg](/public/imported_attachments/1/2011-04-29, 11_57_39.jpg)
                        ![2011-04-29, 11_57_39.jpg_thumb](/public/imported_attachments/1/2011-04-29, 11_57_39.jpg_thumb)
                        ![2011-04-29, 11_57_49.jpg](/public/imported_attachments/1/2011-04-29, 11_57_49.jpg)
                        ![2011-04-29, 11_57_49.jpg_thumb](/public/imported_attachments/1/2011-04-29, 11_57_49.jpg_thumb)
                        • F Offline
                          Frozen_Fire
                          @ far … your Nat ountbound should be set to "manual"
                          • E Offline
                            eri--
                            You need only loopback interface on squid selected.
                            Also on LAN the rule with a GatewayPool should not match the port 80/443 tcp which get handled by squid.
                              mjtbrady
                              Has anyone got failover working on 2.0RC3?  I have been trying to get this working for several days now and and have not been successful.
