    Looking for PASSIVE + LOW POWER suggestions (no fans, no moving parts)
    30 Posts 12 Posters 11.2k Views
      Can you adapt your existing hardware at all?
      What if you just remove one of the cpus? From your figures it seems as though one Xeon should be sufficient for your needs, that should reduce power consumption. Having done that can you fit a fan speed controller?
      Much cheaper than replacing it all.  ;)
        pf123user
        yeah I'm looking into that. I did a major stress test today and could only get up to 14% CPU but I'm up to 42% memory usage - time to look at taking out a CPU and adding an extra 2GB of RAM (total of 4GB).
        The loudest thing is the memory cooling fans and there are a few ebay retrofits out there I may look at - or I may try and wrap the inside of the box with some sound deadening material. I've had good luck with that in the past as well.
        I think for starters I'll keep both CPUs in and shut off hyperthreading to see how that works.
        Does ACL and Hardware Prefetch have any impact whether they are on or off?
          pf123user
          Slight update…
          Turned off hyperthreading (HT) and the CPU usage more than doubled - which is strange but it is what it is.
          I think the easy answer is that I need to spend some money - these x5060 CPUs were awesome at one time... but not anymore. I have a dual Xeon W5580 (3.2ghz quad core with HT) box that I set up identical and when I test that (with 9GB ddr3 RAM) I can't even move the needle. I can pretty much push the limits on any Intel Pro 1000 MT, GT or PT NIC and push full gigabit through them and the CPU and memory needle stays at or under 1%.
          Looks like I need to either live with my power consuming machines or shell out the cash to upgrade to more modern hardware that's generally faster than what I have.
            ScottNJ
            You should look into the Soekris Net5501. Over the years I too was searching for the perfect low powered device to run
            pFsense on.
            http://soekris.com/products/net5501.html
            I've used it not only at home but in a production environment (commodities trading firm 50 users business cable).
            It's used as a backup to the Cisco ASA that runs on a 100mbit line.
            I see lots of people on here with setups that are overkill for their needs. From what you describe this should work nicely.
              pf123user
              @ScottNJ:
              pFsense on.
              I too have some of these setups in the equities space - and those are usually in the form of a 1U dell server or in the standard P490 workstation. I have a few schools and retail shops that are complaining about the noise. Unfortunatly the hardware is my cost to bear hence my need for something cheap/affordable. I'll look into this box - thanks. It looks like a very reasonable alternative to what I've been using. The PCI slot is perfect for a Cisco PCI wireless AP and the cost seems reasonable.
                @pf2.0nyc:
                Per box maybe 3-5 VPNs, bandwidth is variable - usually restricted to the remote user's ISP and usually well under 10mbps each way (20 combined).
                No way that Soekris box will support that unless you get encyption hardware.
                  Bai Shen
                  @stephenw10:
                  @pf2.0nyc:
                  I'm thinking about going to something in the i3 range or possibly going to an E8400 CPU - but not sure if that will lower the power consumption by anything substantial.
                  It will!
                  Have a look here: http://www.tomshardware.com/reviews/d510mo-intel-atom,2616-11.html
                  82W peak system power on the i3. They are using a 750W PSU for that test so it will be horribly inefficient at 82W. At that sort of power dissipation you're probably not going to be able to go passive (for sensible cost) but you can use a slow, quiet fan.
                  Edit:
                  Further to the above the i3 530 scores 2729 at Passmark compare that to a dual X5160 system at 3952.
                  Around 70% the processing power of your current system (a little less your cpus are 3.2GHz) but 260W vs 73W TDP.
                  Also the newer sandy bridge cores are lower power consumption and higher processing power.
                  Edit: Having read up on this further I realise that the 51XX Xeon is Core2 based where as the 50XX is older uses more power and would have significantly lower cpu score. All the more reason to get an i3.  ;)
                  My i3 idles at 40W.  Haven't really gotten it configured too much yet, so I'm not sure what it will get up to.  I am having a rogue process that's loading one of the cores, and that takes it up to 53W.  That's witha  380W 80+ Bronze power supply(smallest I could easily get).
                  The only fans are one case fan, the cpu fan, and the psu fan.  It's pretty quiet.
                    serialdie
                    I just replace my Alix 2D3 with a Dell GX520 Small Form Factor and its been awesome. It's silent, small enough to fit in my home/office rac, and efficient. Overkill? Nope. It runs 2Gigs of ram with a P4 3Ghz HPT and a 40GB hdd. It does the job perfect in my 100/50Mbps Line.. best of all they are dirt cheap.
                    • AhnHELA Offline
                      AhnHEL
                      P4 Prescotts are not known for being low power and your ALIX only uses about 5W compared to about 86W for your P4.  Also, Dell's BIOS only underclocks to 2.8Ghz from 3.0 during speedstep, not a noteworthy power savings while idle.
                      Considering your pipe is above what an ALIX can handle I would say it was quite necessary for you to upgrade.
                      AhnHEL (Angel)
                      • Z Offline
                        z3r0
                        http://forum.pfsense.org/index.php/topic,40399.0.html
                        this information might be relevent to you?
