    Anyone else running a WiSP and using pfSense?
    45 Posts 8 Posters 23.4k Views
      dhatz
      What about MAC addr 08:10:74:75:98:9e which seems to appear in two rule pairs?
      00186        0           0 pipe 20187 ip from any to any MAC 08:10:74:75:98:9e any
      00187      458       24248 pipe 20186 ip from any to any MAC any 08:10:74:75:98:9e
      00198        0           0 pipe 20199 ip from any to any MAC 08:10:74:75:98:9e any
      00199        0           0 pipe 20198 ip from any to any MAC any 08:10:74:75:98:9e
      What is the result of
      fgrep 08:10:74:75:98:9e /cf/conf/config.xml
        dhatz
        luke -or anyone else who is regularly adding/removing MACs from CP's MAC-passthrough page-, could you please check your router's ipfw show output for:
        • MACs that appear in more than one rule pair (as shown in the excerpt above)
        • multiple lines with the same rule number (as shown in issue #1958 )
        TIA
        • L Offline
          luke240778
          Just a quick reply to let you know i am traveling at the moment and will check this out and post back as soon as i am back home
            cmb
            If you're using MAC passthrough and deleting entries, it will delete the one you specify but it also deletes part of others that will break their access. ticket here: http://redmine.pfsense.org/issues/1976
            work around, hit Save under Status>Captive Portal to correctly reload.
            • L Offline
              luke240778
              dhatz, could you tell me how i do this?  ther isalot more data than i can see on screen when i run ipfw show.. can u pipe it through more to see a screen at a time?
              I hope we can sort this out, i am getting to a point where this is causing problems.  My network is open replying on the Captive Portal catching people who connect. Currently, ever new connection is getting online without being authenticated via CP.. they are somehow just passing by.  This is only happening on the outdoor clients connecting through my outdoor AP (which is on LAN interface) but prople connecting through my office AP (connected on OPT1 interface) arr getting stopped by the CP login page.
              We are currently adding more and more clients, but i am having to hide my SSID currently to try and stop unwanted peopl eusing the network.. what i really need is that SSID broadcasting cause it is a good way for us to get more clients when people see it and phone us up.
              • L Offline
                luke240778
                Any more ideas here?
                  wallabybob
                  I suspect CP on LAN might be a fairly uncommon configuration and consequently not well tested.
                  You do have CP enabled on BOTH LAN and OPT1? If so, can you move the offending AP to (say) OPT2.
                  • L Offline
                    luke240778
                    It was all working until i did the upgrade to 2.0-RELEASE.
                    I dont have an Opt2 interface. Only WAN, LAN and OPT1.  I will try swapping the AP from LAN to OPT1 and see if it works, just to see if the issue is the AP or the Captive Portal.. cause as i said before, on OPT1 currently i have just a small indoor WAP, and the Captive portal works.. but for my outdoor Ruckus AP it isn't anymore.
                      wallabybob
                      @luke240778:
                      Upgrades can sometimes change the configuration file. Do you have CP enabled on LAN?
                      • L Offline
                        luke240778
                        Yes, it is as it was before the upgrade. I have CP enabled on both LAN and OPT1
                          cmb
                          CP works fine on LAN and is extensively used and tested there. Probably want to gitsync to RELENG_2_0, or wait for 2.0.1 that will be coming this week, if you're using a lot of MAC passthroughs and editing them frequently since we fixed an issue there.
                          • L Offline
                            luke240778
                            And i am guessing not go the upgrade route?  do a clean install?  I dont mind if i have to do that, just alot more work and i have the problem that i want to keep all cache and lightsquid logs..
                              dhatz
                              luke, if you're in a hurry, you could also manually apply the bugfix, it's this one:
                              https://github.com/bsdperimeter/pfsense/commit/e3db5627224a0293f74e0d032a9b230f98f85952
                              I haven't noticed any issues with MAC passthrough since.
                              • L Offline
                                luke240778
                                dhatz thanks for that.. a hurry i definately am in.  Ill give this a try and see what happens and report back.  Thanks
                                just to be clear, i am just to add this line:
                                +  $ruleno = captiveportal_get_next_ipfw_ruleno(2000, 49899, true);
                                (do i add the "+" at the start also?)
                                Or am is supposed to delete these lines also:
                                -  if ($enBwup && $enBwdown)
                                945
                                -    $ruleno = captiveportal_get_next_ipfw_ruleno(2000, 49899, true);
                                946
                                -  else
                                947
                                -    $ruleno = captiveportal_get_next_ipfw_ruleno(2000, 49899, false);
                                • pttP Offline
                                  ptt Rebel Alliance
                                  You must delete the lines marked with "-" and add the line marked with "+"
                                  Or you can do as indicated by cmb
                                  edit:
                                  you have attached the "captiveportal.inc.png" from a pfsense 2.0.1 amd 64
                                  remove the .png and upload to  /etc/inc/
                                  • L Offline
                                    luke240778
                                    Ok, so here is my problem that i have absolutely no idea how to fix.  I just applied that patch thanks to dhatz, i dont know what that will fix but we will see.  I have rebooted since applying.
                                    So i have 1 client. His MAC is not even in the Captive Portal MAC passthrough list, he is on the DHCP Leases list and also on the ARP Table. Lightsquid logs shows his usage.  I currently see him onlne and see the Lightsquid logs for this user changing so i assume he is browsing, however.. i just did a ipfw show and his MAC is not in there at all…
                                    What is going on here??
                                      wallabybob
                                      Your clients need to have an IP address before they can talk with the captive portal. Hence they could well have ARP entries and DHCP leases and still not be able to communicate with the web.
                                      I don't know about Lightsquid - perhaps it captures a web access BEFORE it gets to Captive Portal.
                                      • L Offline
                                        luke240778
                                        @wallabybob:
                                        Wallabybob i think you are missing the point i have been making here.. this is the issue, clients ARE getting on the web, and passed teh Captive Portal but i have no idea why? They should be getting stopped at the Captive Portal logon screen but no longer are.  This particular MAC isnt showing in the ipfw show but i know for certain that the client is browsing the web no problems..
                                          wallabybob
                                          @luke240778:
                                          Please run a packet capture on that particular client's IP address and interface. The capture may give some clues as to how they are bypassing CP.
                                          @luke240778:
                                          Sorry, when you said @luke240778:
                                          I thought you were offering "having a DHCP lease and an ARP entry" as part of the evidence of being able to bypass CP.
                                          Now that I have thought about things a bit more, I wonder if the issue is that the client is getting into SQUID rather than CP and the squid accesses on behalf of that client are able to bypass CP because they are sourced "locally". I don't know enough about squid, CP and their interactions to be able to suggest how you might explore that theory.
                                          • L Offline
                                            luke240778
                                            @wallabybob:
                                            @luke240778:
                                            @luke240778:
                                            IP address of the MAC i know is bypassing the CP is 192.168.10.241, here is a packet capture i just ran:
                                            00:59:28.164510 IP 192.168.10.241.1534 > 204.236.234.74.80: tcp 588
                                            00:59:28.164549 IP 204.236.234.74.80 > 192.168.10.241.1534: tcp 0
                                            00:59:28.465596 IP 204.236.234.74.80 > 192.168.10.241.1534: tcp 313
                                            00:59:28.465816 IP 204.236.234.74.80 > 192.168.10.241.1534: tcp 43
                                            00:59:28.531317 IP 192.168.10.241.1534 > 204.236.234.74.80: tcp 0
                                            00:59:36.671760 IP 192.168.10.241.2717 > 65.54.49.80.1863: tcp 5
                                            00:59:36.814082 IP 65.54.49.80.1863 > 192.168.10.241.2717: tcp 8
                                            00:59:36.987721 IP 192.168.10.241.2717 > 65.54.49.80.1863: tcp 0
                                            01:00:18.851057 IP 192.168.10.241.2717 > 65.54.49.80.1863: tcp 5
                                            01:00:19.000373 IP 65.54.49.80.1863 > 192.168.10.241.2717: tcp 8
                                            01:00:19.137851 IP 192.168.10.241.2717 > 65.54.49.80.1863: tcp 0
                                            01:00:50.510226 IP 192.168.10.241.1534 > 204.236.234.74.80: tcp 612
                                            01:00:50.510265 IP 204.236.234.74.80 > 192.168.10.241.1534: tcp 0
                                            01:00:50.972113 IP 204.236.234.74.80 > 192.168.10.241.1534: tcp 313
                                            01:00:50.972267 IP 204.236.234.74.80 > 192.168.10.241.1534: tcp 43
                                            01:00:51.028514 IP 192.168.10.241.1534 > 204.236.234.74.80: tcp 0
                                            01:00:59.014654 IP 192.168.10.241.2717 > 65.54.49.80.1863: tcp 5
                                            01:00:59.157985 IP 65.54.49.80.1863 > 192.168.10.241.2717: tcp 8
                                            01:00:59.289235 IP 192.168.10.241.2717 > 65.54.49.80.1863: tcp 0
                                            01:01:15.188511 IP 74.125.234.91.80 > 192.168.10.241.1739: tcp 0
                                            01:01:15.208393 IP 192.168.10.241.1739 > 74.125.234.91.80: tcp 0
                                            01:01:16.187616 IP 195.28.181.138.80 > 192.168.10.241.1740: tcp 0
                                            01:01:16.199754 IP 192.168.10.241.1740 > 195.28.181.138.80: tcp 0
                                            01:01:17.186638 IP 184.173.254.59.80 > 192.168.10.241.1746: tcp 0
                                            01:01:17.195715 IP 192.168.10.241.1746 > 184.173.254.59.80: tcp 0
                                            01:01:18.185736 IP 213.8.137.51.80 > 192.168.10.241.1748: tcp 0
                                            01:01:18.196753 IP 192.168.10.241.1748 > 213.8.137.51.80: tcp 0
                                            01:01:46.015915 IP 192.168.5.28 > 192.168.10.241: ICMP echo request, id 1024, seq 37241, length 24
                                            01:01:46.017889 IP 192.168.5.28 > 192.168.10.241: ICMP echo request, id 1024, seq 42361, length 24
                                            01:01:46.018875 IP 192.168.5.28 > 192.168.10.241: ICMP echo request, id 1024, seq 47481, length 24
                                            01:01:46.101480 IP 192.168.10.241 > 192.168.5.28: ICMP echo reply, id 1024, seq 37241, length 24
                                            01:01:46.142832 IP 192.168.10.241 > 192.168.5.28: ICMP echo reply, id 1024, seq 42361, length 24
                                            01:01:46.144745 IP 192.168.10.241 > 192.168.5.28: ICMP echo reply, id 1024, seq 47481, length 24
                                            01:01:47.158082 IP 192.168.10.241.2717 > 65.54.49.80.1863: tcp 5
                                            01:01:47.302091 IP 65.54.49.80.1863 > 192.168.10.241.2717: tcp 8
                                            01:01:47.465471 IP 192.168.10.241.2717 > 65.54.49.80.1863: tcp 0
                                            01:01:59.586950 IP 192.168.10.241.1534 > 204.236.234.74.80: tcp 572
                                            01:01:59.586991 IP 204.236.234.74.80 > 192.168.10.241.1534: tcp 0
                                            01:01:59.967533 IP 204.236.234.74.80 > 192.168.10.241.1534: tcp 313
                                            01:01:59.967812 IP 204.236.234.74.80 > 192.168.10.241.1534: tcp 43
                                            01:01:59.978150 IP 192.168.10.241.1534 > 204.236.234.74.80: tcp 0
                                            01:02:31.315672 IP 192.168.10.241.2717 > 65.54.49.80.1863: tcp 5
                                            01:02:31.462128 IP 65.54.49.80.1863 > 192.168.10.241.2717: tcp 8
                                            01:02:31.614572 IP 192.168.10.241.2717 > 65.54.49.80.1863: tcp 0
                                            01:02:56.311476 IP 192.168.5.28.4193 > 192.168.10.241.137: UDP, length 50
                                            01:03:11.479934 IP 192.168.10.241.2717 > 65.54.49.80.1863: tcp 5
                                            01:03:11.624158 IP 65.54.49.80.1863 > 192.168.10.241.2717: tcp 8
                                            01:03:11.761804 IP 192.168.10.241.2717 > 65.54.49.80.1863: tcp 0
                                            01:03:16.497933 IP 192.168.5.28 > 192.168.10.241: ICMP echo request, id 1024, seq 46464, length 24
                                            01:03:16.501866 IP 192.168.5.28 > 192.168.10.241: ICMP echo request, id 1024, seq 50048, length 24
                                            01:03:16.501872 IP 192.168.5.28 > 192.168.10.241: ICMP echo request, id 1024, seq 53632, length 24
                                            01:03:16.565799 IP 192.168.10.241 > 192.168.5.28: ICMP echo reply, id 1024, seq 46464, length 24
                                            01:03:16.583443 IP 192.168.10.241 > 192.168.5.28: ICMP echo reply, id 1024, seq 50048, length 24
                                            01:03:16.585429 IP 192.168.10.241 > 192.168.5.28: ICMP echo reply, id 1024, seq 53632, length 24
                                            Sorry i wasnt meaning that the DHCP entry and the ARP entry were evidence of being able to bypass CP.. just that i can see that the MAC and IP of that client is online and not in the MAC passthough list, and is definately online and surfing, so it is somehow bypassing the CP.
                                            That thought about Squid is an interesting one.. i am just running Squid as a transparent proxy.. can someone with more knowledge of Squid possible give your two cents worth here?
