    Anyone else running a WiSP and using pfSense?
    45 Posts 8 Posters 23.4k Views
      cmb
      Transparent proxying bypasses captive portal.
      • L Offline
        luke240778
        @cmb:
        Ok, but thats obviously not my problem here right? seeing that his exact same setup worked perfectly fine for over 8 months..
        I always had transparent proxy and CP running and all my clients used to get the CP login screen.. now all of a sudden they are getting past it.  If i stop the Squid service and try and login a client that is currently bypassing the CP this should prove this?
        • L Offline
          luke240778
          Ok all, i am seriously needing help here.
          I was thinking my captive portal issue may have been my Ruckus AP letting connected clients bypass the CP, but i have just tested with another AP made by Ubiquiti and it also lets people connected bypass the CP.. However, with that same Ubiquiti AP connected to my other NIC (OPT1 and not LAN) the CP kicks in and works like it should.  What can possible making 1 interface work and not the other?  I have Captive Portal enabled on both LAN and OPT1.
          All help is appreciated here, this is starting to be a big issue now as we are expanding a little.
          • pttP Offline
            ptt Rebel Alliance
            @luke240778:
            Have you considered the Commercial Support ?
            https://portal.pfsense.org/
            • L Offline
              luke240778
              @ptt:
              @luke240778:
              Have considered it yes. Was hoping that some one on the forum would have been able to assist first, but if i can't get anywhere i guess thats what i'll have to do.
