    Squidguard installation problem
    29 Posts 3 Posters 15.4k Views
    • F Offline
      fr3drik
      thanks for reply .
      2.0.1-RELEASE (i386)  on a box with intel Pentium 4 CPU 1.80GHz & 256 ram mem .
      can u please give me a download link since it may happen cause of bad iso i've downloaded ?
      • marcellocM Offline
        marcelloc
        Try this one http://pfsense.ufms.br/downloads/pfSense-2.0.1-RELEASE-i386.iso.gz
        • F Offline
          fr3drik
          thanks marcelloc .
          ok
          i'd download pfsense iso once again and write it on cd and then install but nothing changes .
          i'd try to install packages when i was connected to 3 difrence isp each time .
          in my network there's nothing like proxy server or something else .
          strange thing is that other packages installed completlly but squidguard doesn't.
          p.s : sorry for my bad english
            marcelloc
            you did a clean install with no other packages before squid and squidguard?
            • F Offline
              fr3drik
              yeah . i did .
              i did everything u say .
                marcelloc
                I'm done with ideas to help you.  :(
                the last I have for now is quite unusual but your problem is unusual too.
                Try creating a local repo on your network and try installing squidguard from it
                http://doc.pfsense.org/index.php/Creating_Your_Own_Package_Repository
                • F Offline
                  fr3drik
                  @marcelloc:
                  one thing .. i'd try to install lightsquad and it stops on Loading package instructions… too !! funny ;D
                  thank u so much .
                    Nachtfalke
                    First I thought it could be the small amount of RAM….just 256MB...
                    Or perhaps there is to less HDD space left for squidguard and the dependencies !?
                    Could you first install squid then lower HDD cache in squid to 1MB, then reboot and try with installation of squidguard ?
                    But that's really uncommon....I tried with a VM and 256MB RAM, too, and it worked.
                    • F Offline
                      fr3drik
                      @Nachtfalke:
                      forget it . thanks man .
                      i'm on slackware now . hard to config but it works like a charm
