    Sky Fibre to the Cabinet Rollout - PfSense support?
    70 Posts 9 Posters 45.4k Views
      dLockers
      Hey Stephen,
      Unfortunately I am still without Sky fibre (roll on Friday!) however I may not attempt much messing about as it will cause the DLM (Sky line monitoring) to flag my connection as flapping and then get throttled.
      There is an awesome plugin here tho:
      http://forum.pfsense.org/index.php?topic=40194.0
      That seems to fit the bill exactly to what we need to do to accomplish this if your suggestion doesn't work.
      I will be trying to negotiate an MER connection tonight with my current unlimited broadband, however
        Yes that mod will definitely do it but it shouldn't be required at the moment. However if Sky subsequently decide to require option 60 as well you can easily do it with that. Nice.  :)
        DLM is done based on line disconnection i.e. actually unplugging the modem. There should be no need for you to that to test pfSense. You can leave the Openreach modem connected to the VDSL line and just replace Skys router with pfSense.
          dLockers
          Awesome Stephen, thanks very much for the help so far.
          May I ask what your day job is?
            Ha! Well it depends who you ask.
            Technically I'm an electrical/electronics engineer but I left my job a few years ago to do some travelling and have been decorating on and off while I think of something better to do.  ::)
            Hence plenty of free time for commenting!
              sandman06
              @dLockers:
              Hey Stephen,
              really cool. do let me know if you get it working without the patch. It makes sense it should work just with the existing dhcp hostname and mac cloning on wan.
              A guide written up would be really cool for anyone new to this once we getting it working.
                No need to spoof the MAC on WAN even.
                @http://www.billion.uk.com/forum/viewtopic.php?f=9&t=343&start=20#p1492:
                Sky MER authentication don't use Option 60, so mac spoofing is not needed.
                  dLockers
                  Is there a way to check if my exchange even supports MER?
                  I tried it last night, both spoofing MAC and not - using the PPPuser|PPPpass - no good, never got an IP.
                  Now my connection even on traditional PPPoA won't connect…
                    What modem are you using? It has to be set to MpoA to use MER.
                    As detailed: http://wiki.ph-mb.com/wiki/MER#WRT54G_.26_Similar_running_Tomato
                      dLockers
                      @stephenw10:
                      I set it to MER, still no go.
                      Unsure what's happened. Going to try my spare pfsense build and see if it's because I'm messed so much with the WAN settings its corrupt it.
                        sandman06
                        @dLockers:
                        please post dhcp log from systems log, so we can see what is happening
                          dLockers
                          @sandman06:
                          @dLockers:
                          Does it save after a reboot?
                            dLockers
                            Okay, small update to this.
                            I tried again last night with the correct modem settings, the DHCP log kept showing DISCOVER but no offer.
                            Maybe my exchange isn't MER enabled - I don't know how to confirm this.
                              Hmm, I don't think it's the exchange that has to be MER enabled. The authentication servers are not in the exchange.
                              They probably do have to support MPoA at the exchange though.
                              Edit: Nope probably just ticking a check box on some central server.
                              Unless you managed to get hold of a friendly sky engineer I don't know how you could find out. How likely is that!  ::)
                              Until you are sure you can connect via MER any results you get may just be more confusing than useful.
                              Only one more day to wait.
                                dLockers
                                May have been a modem issue (or firmware)
                                Fibre dropped today, will be attempting to get it up and running tonight!
                                  dLockers
                                  Boom.
                                  First pfsense install on MER/Fibre
                                  All you do is use the tool here>http://www.ph-mb.com/products/sky-calc and ensure you select the Sagem one.
                                  Then in hostname under DHCP on the WAN connection add your username|password (with the bar).
                                  Connected first time. Well happy!
                                    Ha. Nice.  ;D
                                      dLockers
                                      @stephenw10:
                                      Ha. Nice.  ;D
                                      Couldn't have done it without you, thanks stephen.
                                        sandman06
                                        glad to hear.
                                        was the MER only enabled when you switched to fibre?, or was it enabled all along.
                                        Do you mind posting a brief guide for all sky users that may wish to use pfsense as their firewall/router
                                          dLockers
                                          @sandman06:
                                          glad to hear.
                                          Yes. For me anyway, I know some users have been using MER for ages on their ADSL line.
                                          I was with Sky since 2008 for broadband though so I was using the legacy PPPoA mechanism with no possibility to use MER.
                                          All you need to do is enter your router username and password (like this (with the | bar) -> USER|PASS) with the bar that you get from the ph-mb website (http://www.ph-mb.com/products/sky-calc) using your fibre routers LAN MAC and wireless key (8 LETTERS).
                                          Drop it into the DHCP connections 'hostname' field:
                                          Simple as that.
                                          Please Note: It is NOT your previous sky adsl username and password
                                            sandman06
                                            thank you very much both of you.
