    Multi LAN Problem with OPT1
    6 Posts 3 Posters 3.2k Views
      sunch1ld
      Hi
      I am using pfsense 2.0.1
      I have a LAN configured with
      ip address 172.24.128.1 /16
      opt1
      configurate with
      172.24.0.1/24
      wan dhcp
      In  Firewall: NAT: Outbound
      Interface Source Source Port Destination Destination Port NAT Address NAT Port Static Port Description
      WAN   172.24.0.0/16 * * 500 * * YES Auto created rule for ISAKMP - LAN to WAN
      WAN   172.24.0.0/16 * * * * * NO Auto created rule for LAN to WAN
      WAN   172.24.0.0/24 * * 500 * * YES Auto created rule for ISAKMP - OPT1 to WAN
      WAN   172.24.0.0/24 * * * * * NO Auto created rule for OPT1 to WAN
      When i connect a client I can go in internet trough the wan when I connect a client to opt1 i can not reach internet
      I can not understand where is the problem. How can I create multi lan correctly?
      Thanks in andvance
        heper
        did you create a firewall rule on the opt1 tab to allow traffic FROM opt1-subnet TO any ?
          clarknova
          Your LAN and OPT1 networks overlap, which is a problem.
          db
            sunch1ld
            In that configuration I have no problem.
            I Would like to know how disable routing  and enable only some port forwarding between between two interfaces.
            It's possible?
              clarknova
              From your first post:
              And from your last post:
              I'm not going to try to tell you that you have a problem or not, but you did say so at one point, even if you're backtracking now. In any case, your setup is technically flawed in that you have overlapping subnets on your router interfaces.
              db
                sunch1ld
                I solved thanks only adding the rules to go to internet
