    Pfsense 2.0.1 multiwan and failover problem
    6 Posts 2 Posters 3.7k Views
    • X Offline
      xtreme698866
      what went wrong with my setup?failover is not functioning :-[ wan1 use for browsing failover to wan2 and wan2 use for gaming and failover to wan1
      [IMG]http://img803.imageshack.us/img803/3784/dualwan.jpg
      By xtremeneo at 2012-06-05
        heper
        what exactly is the problem ?
        what rules don't match ?
        • X Offline
          xtreme698866
          thanks figured it out :)
          • X Offline
            xtreme698866
            got problem ;D after installing lusca cache fail over is still functioning but theres no browsing i cant view web pages but when i check the ip of existing connectiong failover work
              heper
              might be the same problem squid has … process binds to the default gateway | lan rules are not applied.
              solution for failover: enable 'default gateway switching' if possible in your setup (System: Advanced: Miscellaneous)
              solution for loadbalance & failover: use floating rules to match proxy http requests and send em out the correct gateway (search for squid + loadbalance)
              kind regards
              • X Offline
                xtreme698866
                @heper:
                kind regards
                ;) this is what i missed thank you sir
