    Problem with incoming traffic on second WAN interface
    2 Posts 2 Posters 898 Views
    • I Offline
      imcfarla
      I have a setup with 2 WAN connections
      WAN is the default gateway
      OPT1 is the secondary WAN connection.
      Port 443 is Nat'd on both interfaces to the same ip address
      I have an Interface group with both WAN and OPT1 setup with all my firewall rules set on there for incoming connections
      When I try to connect to WAN:443 it works fine when I try to connect to OPT1:443 it fails.
      If I do a packet capture I can see traffic coming in on the OPT1 interface but no outgoing traffic.
      However on the WAN interface I can see traffic going out with the OPT1 address stamped on it - this is obviously wrong but I have no idea how to fix it.
      Outbound NAT is currently set to automatic.
      Any ideas?
        pcklinika
        @imcfarla:
        Any ideas?
        1. Add to your Local Server additional IP (IP1: 192.168.1.10 and add IP2:192.168.1.11)
        2. Set to Advanced Outbound NAT
        3. Add a rule for Source 192.168.1.11/32 (second Server IP) to use OPT1 as Translated adress
        4. Move this rule above Auto created rule for LAN to WAN
        Do NOT forget to set a NAT rule for OPT interface
        Regards,
        Andrej
