Port forwarding problems
Does it have a fixed IP or is it dynamic?
The wan3 router ip or the modem3 ip? Both of them have fixed IP anyway.
If it's a fixed public IP then just put the NAT on the public interface and add a rule to allow the traffic through to the internal IP. It's exactly the same as the ones you have already setup just on a different interface.
Ok, I'll try that. Thanks :)
