    IPv6 DHCP-PD – radvd dies after interface reset - dhcpv6 does not reaquire addr
    166 Posts 21 Posters 77.5k Views
      BrianPlencner
      Yesterday I did a clean install of the following version
      Version 2.1-RC0 (i386)
      built on Mon Jul 8 21:26:14 EDT 2013
      FreeBSD 8.3-RELEASE-p8
      So far (uptime is 17 hours) things appear to be working.  Here are a few items that I have noticed so far
      • pfSense shows that my WAN IPv6 IP is 2001:558:6033:ad:….
      As far as I know, this is a valid DHCPv6 IP from Comcast.
      • IPv6 Test sites (example www.test-ipv6.com) return a 10/10 result
      • IPv6 only sites (example ipv6.speedtest.comcast.net) load without issue
      • Comcast's IPv6 Information Center site (www.comcast6.net) loads and shows the following information
      Your IP address is 2601:d:4c00:ca:1118:.......
      Congrats! You are using IPv6 on the Comcast Cable network.
      • The Service "radvd" is running on pfSense
      The big question in my mind is what will happen once the lease is up on the IPv6 IP, and it goes to renew it?  That was the problem before, and from what it sounds like, that issue has been corrected.  I'll report back in a few days with how things go.
      @saltspork:
      I've done a clean install of 2.1 and IPv6 now works, but dhcp6c reports an error and a filter reload is constantly triggered. Killing dhcp6c fixes the issue but takes down radvd with it.
      Could you provide a bit more information on how I can check my system to see if I am getting a similar error?
      Thanks,
      –Brian
      – Brian Plencner
      E-Mail: CoasterBrian72Cancer@gmail.com
      Note: Kill Cancer to Reply via e-mail
        reslip
        I am also not seeing any immediate issues with the July 8th build. Good job to everyone that helped to fix this!
          netkeys
          I upgraded to the built of Fri Jul 5 18:13:39 EDT 2013 and it's now been running for over 4 days and renewed without problems.  This is the first time it renewed and maintained IPv6 connectivity.  All the tests and comcast6.net are working.  Previous as others report it would not work after the 4 days.
          What ever changes has been made there going in the right direction.
          I'll give it another day or two then update to the latest snapshot and see what happens and post my results.
          Thanks for your dedicated work it's appreciated.
            saltspork
            @BrianPlencner:
            The main symptom is 100% CPU usage on one core while the filter reloads indefinitely.
              BrianPlencner
              @saltspork:
              @BrianPlencner:
              I don't think I have that issue.  I only have a single core CPU (Intel Pentium III) and the usage is mostly at 1%.  Sometimes, it will spike to 34%, but that is not that often.
              –Brian
              – Brian Plencner
                BrianPlencner
                Well, I have bad news to report.
                Back on July 10, I reported that I had did a clean install of the following version
                Everything with IPv6 appeared to be working as it should have.
                Well, my uptime is now just over 5 days, and as you can tell by the attached picture, I have again lost my IPv6 IP.
                A few quick notes:
                • No IPv6 IP on the WAN side
                • IPv6 Test sites return 0/10
                • IPv6 only sites fail to load
                • The Service "radvd" is no longer listed in pfSense.
                If anyone here would like more information, let me know and I'll be happy to get it and post it.
                Thanks,
                –Brian
                Pic.jpg_thumb
                – Brian Plencner
                • E Offline
                  eri--
                  Please provide a system log and configuration of the system to see if its related to this.
                  Also there have been some changes to firewall rules in latest snapshots which might impact functionality.
                    priller
                    @BrianPlencner:
                    –Brian
                    Clear /etc/bogonsv6 and see if it comes back.   You may have to reboot.
                      BrianPlencner
                      @ermal:
                      Thanks for the reply.
                      So that we are on the same page, here is the information on the build that I am running
                      Hardware information:
                      Using a Dell Tower, running with a Pentinum III CPU, 512 MB of Ram, and a 20 GB hard drive.
                      Here are the last 50 entries from my system log.
                      Jul 9 13:57:04 php: rc.newwanip: Creating rrd update script
                      Jul 9 13:57:07 php: rc.newwanip: pfSense package system has detected an ip change 24.13.17.39 -> 24.13.17.39 … Restarting packages.
                      Jul 9 13:57:07 check_reload_status: Reloading filter
                      Jul 9 13:59:00 php: /index.php: Successful login for user 'admin' from: 192.168.1.100
                      Jul 9 15:36:25 php: /index.php: webConfigurator authentication error for 'admin' from 192.168.1.100
                      Jul 9 15:36:32 php: /index.php: Successful login for user 'admin' from: 192.168.1.100
                      Jul 9 22:42:46 php: /index.php: Successful login for user 'admin' from: 192.168.1.100
                      Jul 10 04:49:16 php: /index.php: Successful login for user 'admin' from: 192.168.1.100
                      Jul 10 06:53:51 php: /index.php: Successful login for user 'admin' from: 192.168.1.100
                      Jul 11 06:43:19 check_reload_status: updating dyndns WAN_DHCP
                      Jul 11 06:43:19 check_reload_status: Restarting ipsec tunnels
                      Jul 11 06:43:19 check_reload_status: Restarting OpenVPN tunnels/interfaces
                      Jul 11 06:43:19 check_reload_status: Reloading filter
                      Jul 11 06:43:36 check_reload_status: updating dyndns WAN_DHCP
                      Jul 11 06:43:36 check_reload_status: Restarting ipsec tunnels
                      Jul 11 06:43:36 check_reload_status: Restarting OpenVPN tunnels/interfaces
                      Jul 11 06:43:36 check_reload_status: Reloading filter
                      Jul 11 11:29:54 php: /index.php: Successful login for user 'admin' from: 192.168.1.100
                      Jul 11 12:26:37 php: /index.php: Successful login for user 'admin' from: 192.168.1.100
                      Jul 12 08:57:27 check_reload_status: updating dyndns WAN_DHCP,WAN_DHCP6
                      Jul 12 08:57:27 check_reload_status: Restarting ipsec tunnels
                      Jul 12 08:57:27 check_reload_status: Restarting OpenVPN tunnels/interfaces
                      Jul 12 08:57:27 check_reload_status: Reloading filter
                      Jul 12 14:26:36 php: /index.php: Successful login for user 'admin' from: 192.168.1.100
                      Jul 12 18:46:36 dhcp6c[20735]: client6_timo: all information to be updated was canceled
                      Jul 12 18:50:18 dhcp6c[20735]: client6_timo: all information to be updated was canceled
                      Jul 13 14:01:13 dhcp6c[20735]: client6_timo: all information to be updated was canceled
                      Jul 13 14:03:45 dhcp6c[20735]: client6_timo: all information to be updated was canceled
                      Jul 14 23:25:40 php: /index.php: Successful login for user 'admin' from: 192.168.1.100
                      Jul 15 02:51:03 check_reload_status: updating dyndns WAN_DHCP
                      Jul 15 02:51:03 check_reload_status: Restarting ipsec tunnels
                      Jul 15 02:51:03 check_reload_status: Restarting OpenVPN tunnels/interfaces
                      Jul 15 02:51:03 check_reload_status: Reloading filter
                      Jul 15 02:51:12 php: rc.newwanipv6: rc.newwanipv6: Informational is starting rl0.
                      Jul 15 02:51:12 php: rc.newwanipv6: rc.newwanipv6: on (IP address: 2001:558:6033:ad:3d6d:7e5d:7bea:f1ae) (interface: wan) (real interface: rl0).
                      Jul 15 02:51:13 php: rc.newwanipv6: ROUTING: setting default route to 24.13.16.1
                      Jul 15 02:51:13 php: rc.newwanipv6: ROUTING: setting IPv6 default route to fe80::201:5cff:fe3d:4e41%rl0
                      Jul 15 02:51:15 check_reload_status: Reloading filter
                      Jul 15 05:19:52 php: /index.php: Successful login for user 'admin' from: 192.168.1.100
                      If you want the full log, I can do that if you can provide the command to run to get it.
                      As far as firewall rules, see the two attached pics for the rules on the WAN and LAN side.  I know that whatever is there was added by default on the build that I am running, as I did not make any changes to the firewall rules.
                      Thanks,
                      –Brian
                      LAN.jpg_thumb
                      Wan.jpg_thumb
                      – Brian Plencner
                        BrianPlencner
                        @priller:
                        How would I go about doing this step?
                        Thanks,
                        –Brian
                        – Brian Plencner
                          priller
                          @BrianPlencner:
                          @priller:
                          1. Make sure shell is enabled - http://doc.pfsense.org/index.php/HOWTO_enable_SSH_access
                          2. Then SSH in and you will get the menu; Select option 8 - http://doc.pfsense.org/index.php/Using_the_PHP_pfSense_Shell
                          3. type 'rm /etc/bogonsv6'
                          Note: If you need an SSH client, you can use this:  http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
                            BrianPlencner
                            @priller:
                            I was going through the steps to enable SSH in pfSense this morning.  However, after I logged into the web console, I noticed that my information screen had changed, per the attached picture.
                            Notice that I now see IPv6 Information under both the WAN and LAN Interface section. The service "Radvd" shows up again in the services status.
                            I then went and did a quick test at a test IPv6 site (www.test-ipv6.com) and it came back with 10/10.
                            Has my computer been rebooted? No
                            Has pfSense been rebooted? No
                            Has my modem been rebooted? No
                            Did I do anything to pfSense?  Nope!
                            While its still a mystery that it stopped working, it is even more a mystery now that it started up again without any action on my part.
                            Thoughts?
                            –Brian
                            Pic.jpg_thumb
                            – Brian Plencner
                              BrianPlencner
                              Well, whatever caused it to "break" last time has happened again.
                              This morning, I noticed that I lost any items related to IPv6.  My uptime is just over 9 days, so I would guess that it was the dhcpv6 renewal that failed again.
                              I've again not made any changes to the configuration of pfSense, nor have I rebooted pfSense or my modem in the last 9 days.
                              So, I'm going to just let things sit, and see if it comes back again on its own in a few days.
                              If it does, is there any information that people would like to see, to help troubleshoot the issue?
                              Thanks,
                              –Brian
                              – Brian Plencner
                                wallabybob
                                @BrianPlencner:
                                An extract from the system log (see Status -> System Logs) from a few minutes before the "break" to a few minutes after might be informative.
                                  BrianPlencner
                                  @wallabybob:
                                  @BrianPlencner:
                                  Well, here are the last 50 entries from the system log. I think its good (hopefully) that the last 50 entries cover the last 8 days.
                                  Jul 15 06:12:47 	check_reload_status: updating dyndns WAN_DHCP
                                  Jul 15 06:12:47 	check_reload_status: Restarting ipsec tunnels
                                  Jul 15 06:12:47 	check_reload_status: Restarting OpenVPN tunnels/interfaces
                                  Jul 15 06:12:47 	check_reload_status: Reloading filter
                                  Jul 15 07:02:49 	check_reload_status: updating dyndns WAN_DHCP
                                  Jul 15 07:02:49 	check_reload_status: Restarting ipsec tunnels
                                  Jul 15 07:02:49 	check_reload_status: Restarting OpenVPN tunnels/interfaces
                                  Jul 15 07:02:49 	check_reload_status: Reloading filter
                                  Jul 16 03:28:17 	php: /index.php: Successful login for user 'admin' from: 192.168.1.100
                                  Jul 16 14:55:32 	php: /index.php: Successful login for user 'admin' from: 192.168.1.100
                                  Jul 17 14:08:01 	php: /index.php: webConfigurator authentication error for 'admin' from 192.168.1.100
                                  Jul 17 14:08:05 	php: /index.php: Successful login for user 'admin' from: 192.168.1.100
                                  Jul 18 07:41:11 	dhcp6c[20735]: client6_timo: all information to be updated was canceled
                                  Jul 18 07:45:59 	dhcp6c[20735]: client6_timo: all information to be updated was canceled
                                  Jul 19 02:58:53 	dhcp6c[20735]: client6_timo: all information to be updated was canceled
                                  Jul 19 02:59:52 	dhcp6c[20735]: client6_timo: all information to be updated was canceled
                                  Jul 19 03:20:01 	check_reload_status: updating dyndns WAN_DHCP,WAN_DHCP6
                                  Jul 19 03:20:01 	check_reload_status: Restarting ipsec tunnels
                                  Jul 19 03:20:01 	check_reload_status: Restarting OpenVPN tunnels/interfaces
                                  Jul 19 03:20:01 	check_reload_status: Reloading filter
                                  Jul 19 03:20:35 	check_reload_status: updating dyndns WAN_DHCP,WAN_DHCP6
                                  Jul 19 03:20:35 	check_reload_status: Restarting ipsec tunnels
                                  Jul 19 03:20:35 	check_reload_status: Restarting OpenVPN tunnels/interfaces
                                  Jul 19 03:20:35 	check_reload_status: Reloading filter
                                  Jul 19 05:41:51 	php: /index.php: Successful login for user 'admin' from: 192.168.1.100
                                  Jul 20 08:26:22 	php: /index.php: Successful login for user 'admin' from: 192.168.1.100
                                  –Brian
                                  – Brian Plencner
                                    wallabybob
                                    And the DHCP log?
                                      BrianPlencner
                                      @wallabybob:
                                      And the DHCP log?
                                      Well, I went to go get that, but the last 50 entries shown on the screen are all from today.  So, I know that won't be of any help.
                                      Does the DHCP log contain more then the last 50 entries, and if so, what command can I run to extract that information.
                                      I also want to add that 2 days and 12 hours ago, pfsense "locked up" on me.  The reason I say that is my internet connection did not work.  No pages would load, and I was not able to ping my pfSense box or my cable modem.  Before I rebooted, I plugged in my USB Keyboard and Monitor to see if there was any kind of message on the screen.  How I came to the "locked up" result is that when I did plug my keyboard in, it did not light up.  I have two lights that are always on (a power light, and a numlock).  Pressing the num lock, caps lock, or scroll lock buttons did not cause those lights to come on either when plugged into my pfSense box.  So, I did a hard reset.  Once it came up, I then rebooted it again normally, and has been up ever since.  So far, things are working, but it has been less then 3 days at this point.
                                      –Brian
                                      – Brian Plencner
                                        wallabybob
                                        @BrianPlencner:
                                        Yes. The whole log can be displayed by shell command```
                                        clog /var/log/dhcpd.log
                                        You can change the number of log entries displayed in the GUI by going to _Status_ -> _System Logs_, click on _Settings_ tab, change the value of _GUI Log Entries to Display_ and click _Save_.
                                          BrianPlencner
                                          I'm going to have to start putting together a file that has all these commands in it!  :)
                                          I got the full DHCP log, but I know I don't need to post it.
                                          The important dates in this latest round of testing are
                                          • July 10th: Build from Mon Jul 8 21:26:14 EDT 2013 2.1-RCO(i386) installed.  All is well
                                            • July 14th: Notice that IPv6 is no longer working
                                            • July 16th: Notice that IPv6 is working again
                                            • July 19th: IPv6 stops again
                                            So, the DHCP log shown below is from midnight on July 13th (in case something happened on the 13th, and I just noticed it on the 14th), until 12:00 am on the 20th.  This should cover the all of the important dates that I noted above, and maybe be able to point towards what is going on.
                                            Thanks again for all the help.
                                            –Brian
                                            Jul 13 00:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 00:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 01:06:37 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 13 01:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 01:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 02:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 02:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 03:06:37 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 13 03:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 03:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 04:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 04:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 05:06:36 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 13 05:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 05:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 06:02:26 pfSense dhcpd: DHCPDISCOVER from 00:24:8c:bf:05:9c via xl0
                                            Jul 13 06:02:27 pfSense dhcpd: unexpected ICMP Echo Reply from 24.13.16.1
                                            Jul 13 06:02:27 pfSense dhcpd: DHCPOFFER on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 06:02:27 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 (192.168.1.1) from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 06:02:27 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 06:02:37 pfSense dhcpd: DHCPINFORM from 192.168.1.101 via xl0
                                            Jul 13 06:02:37 pfSense dhcpd: DHCPACK to 192.168.1.101 (00:24:8c:bf:05:9c) via xl0
                                            Jul 13 06:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 06:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 07:02:28 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 13 07:02:28 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 07:02:28 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 07:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 07:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 08:02:28 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 08:02:28 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 08:06:36 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 13 08:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 08:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 09:02:27 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 09:02:27 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 09:06:36 pfSense dhcpd: Information-request message from fe80::34a9:c82a:594b:cd66 port 546, transaction ID 0x30D0F200
                                            Jul 13 09:06:36 pfSense dhcpd: Sending Reply to fe80::34a9:c82a:594b:cd66 port 546
                                            Jul 13 09:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 09:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 10:02:27 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 13 10:02:27 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 10:02:27 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 10:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 10:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 11:02:27 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 11:02:27 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 11:06:36 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 13 11:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 11:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 12:02:28 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 12:02:28 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 12:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 12:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 13:02:28 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 13 13:02:28 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 13:02:28 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 13:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 13:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 14:02:28 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 14:02:28 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 14:06:36 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 13 14:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 14:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 15:02:28 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 15:02:28 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 15:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 15:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 16:02:28 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 13 16:02:28 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 16:02:28 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 16:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 16:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 16:07:51 pfSense dhcpd: DHCPINFORM from 192.168.1.101 via xl0
                                            Jul 13 16:07:51 pfSense dhcpd: DHCPACK to 192.168.1.101 (00:24:8c:bf:05:9c) via xl0
                                            Jul 13 16:09:37 pfSense dhcpd: DHCPINFORM from 192.168.1.101 via xl0
                                            Jul 13 16:09:37 pfSense dhcpd: DHCPACK to 192.168.1.101 (00:24:8c:bf:05:9c) via xl0
                                            Jul 13 17:02:28 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 17:02:28 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 17:06:37 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 13 17:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 17:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 18:02:29 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 18:02:29 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 18:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 18:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 19:02:29 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 13 19:02:29 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 19:02:29 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 19:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 19:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 20:02:29 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 20:02:29 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 20:06:37 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 13 20:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 20:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 20:27:47 pfSense dhcpd: DHCPDISCOVER from 00:22:15:ca:99:e0 via xl0
                                            Jul 13 20:27:48 pfSense dhcpd: unexpected ICMP Echo Reply from 24.13.16.1
                                            Jul 13 20:27:48 pfSense dhcpd: DHCPOFFER on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 13 20:27:48 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 (192.168.1.1) from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 13 20:27:48 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 13 20:28:59 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 13 20:28:59 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 13 21:02:29 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 21:02:29 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 21:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 21:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 22:02:30 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 13 22:02:30 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 22:02:30 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 13 22:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 22:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 23:06:37 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 13 23:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 13 23:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 00:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 00:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 01:06:37 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 01:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 01:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 02:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 02:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 03:06:37 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 03:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 03:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 04:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 04:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 05:06:37 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 05:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 05:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 06:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 06:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 07:06:37 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 07:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 07:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 07:28:50 pfSense dhcpd: DHCPDISCOVER from 00:24:8c:bf:05:9c via xl0
                                            Jul 14 07:28:50 pfSense dhcpd: unexpected ICMP Echo Reply from 24.13.16.1
                                            Jul 14 07:28:51 pfSense dhcpd: DHCPOFFER on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 07:28:51 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 (192.168.1.1) from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 07:28:51 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 07:29:00 pfSense dhcpd: DHCPINFORM from 192.168.1.101 via xl0
                                            Jul 14 07:29:00 pfSense dhcpd: DHCPACK to 192.168.1.101 (00:24:8c:bf:05:9c) via xl0
                                            Jul 14 08:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 08:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 08:24:30 pfSense dhcpd: DHCPDISCOVER from 00:22:15:ca:99:e0 via xl0
                                            Jul 14 08:24:30 pfSense dhcpd: unexpected ICMP Echo Reply from 24.13.16.1
                                            Jul 14 08:24:31 pfSense dhcpd: DHCPOFFER on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 08:24:31 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 08:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 (192.168.1.1) from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 08:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 08:25:41 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 14 08:25:41 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 14 08:28:52 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 08:28:52 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 09:06:35 pfSense dhcpd: Information-request message from fe80::34a9:c82a:594b:cd66 port 546, transaction ID 0xAAE26F00
                                            Jul 14 09:06:35 pfSense dhcpd: Sending Reply to fe80::34a9:c82a:594b:cd66 port 546
                                            Jul 14 09:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 09:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 09:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 09:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 09:28:52 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 09:28:52 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 09:28:52 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 10:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 10:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 10:06:43 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 14 10:06:43 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 14 10:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 10:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 10:28:53 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 10:28:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 10:28:53 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 11:06:37 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 11:06:37 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 11:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 11:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 11:28:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 11:28:53 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 11:32:44 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 14 11:32:44 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 14 12:06:36 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 12:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 12:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 12:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 12:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 12:28:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 12:28:53 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 12:37:45 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 14 12:37:45 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 14 13:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 13:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 13:24:31 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 13:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 13:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 13:28:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 13:28:53 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 13:47:46 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 14 13:47:46 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 14 14:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 14:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 14:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 14:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 14:28:52 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 14:28:52 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 14:28:52 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 15:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 15:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 15:12:47 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 14 15:12:47 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 14 15:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 15:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 15:28:52 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 15:28:52 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 15:33:18 pfSense dhclient: RENEW
                                            Jul 14 15:33:18 pfSense dhclient: Creating resolv.conf
                                            Jul 14 16:06:36 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 16:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 16:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 16:07:46 pfSense dhcpd: DHCPINFORM from 192.168.1.101 via xl0
                                            Jul 14 16:07:46 pfSense dhcpd: DHCPACK to 192.168.1.101 (00:24:8c:bf:05:9c) via xl0
                                            Jul 14 16:09:35 pfSense dhcpd: DHCPINFORM from 192.168.1.101 via xl0
                                            Jul 14 16:09:35 pfSense dhcpd: DHCPACK to 192.168.1.101 (00:24:8c:bf:05:9c) via xl0
                                            Jul 14 16:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 16:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 16:28:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 16:28:53 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 16:39:49 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 14 16:39:49 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 14 17:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 17:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 17:24:31 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 17:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 17:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 17:28:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 17:28:53 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 18:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 18:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 18:22:50 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 14 18:22:50 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 14 18:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 18:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 18:28:53 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 18:28:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 18:28:53 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 18:29:16 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 14 18:29:16 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 14 19:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 19:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 19:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 19:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 19:28:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 19:28:53 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 20:06:36 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 20:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 20:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 20:18:52 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 14 20:18:52 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 14 20:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 20:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 20:28:54 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 20:28:54 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 21:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 21:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 21:24:31 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 21:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 21:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 21:28:54 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 21:28:54 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 21:46:53 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 14 21:46:53 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 14 22:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 22:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 22:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 22:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 22:28:54 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 14 22:28:54 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 22:28:54 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 23:03:54 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 14 23:03:54 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 14 23:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 23:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 14 23:24:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 23:24:31 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 14 23:28:54 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 14 23:28:54 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 00:06:36 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 00:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 00:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 01:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 01:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 01:24:31 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 02:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 02:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 02:51:13 pfSense dhcpd: Internet Systems Consortium DHCP Server 4.2.5-P1
                                            Jul 15 02:51:13 pfSense dhcpd: Copyright 2004-2013 Internet Systems Consortium.
                                            Jul 15 02:51:13 pfSense dhcpd: All rights reserved.
                                            Jul 15 02:51:13 pfSense dhcpd: For info, please visit https://www.isc.org/software/dhcp/
                                            Jul 15 02:51:13 pfSense dhcpd: Wrote 0 leases to leases file.
                                            Jul 15 02:51:13 pfSense dhcpd: Bound to *:547
                                            Jul 15 02:51:13 pfSense dhcpd: Listening on Socket/23/xl0/2601:d:4c00:ca::/64
                                            Jul 15 02:51:13 pfSense dhcpd: Sending on   Socket/23/xl0/2601:d:4c00:ca::/64
                                            Jul 15 03:06:36 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 03:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 03:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 04:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 04:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 05:06:36 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 05:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 05:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 06:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 06:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 06:55:52 pfSense dhcpd: DHCPDISCOVER from 00:22:15:ca:99:e0 via xl0
                                            Jul 15 06:55:52 pfSense dhcpd: unexpected ICMP Echo Reply from 24.13.16.1
                                            Jul 15 06:55:53 pfSense dhcpd: DHCPOFFER on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 06:55:53 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 06:55:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 (192.168.1.1) from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 06:55:53 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 06:57:06 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 15 06:57:06 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 15 07:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 07:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 07:46:16 pfSense dhcpd: DHCPDISCOVER from 00:24:8c:bf:05:9c via xl0
                                            Jul 15 07:46:17 pfSense dhcpd: unexpected ICMP Echo Reply from 24.13.16.1
                                            Jul 15 07:46:17 pfSense dhcpd: DHCPOFFER on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 07:46:17 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 (192.168.1.1) from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 07:46:17 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 07:46:23 pfSense dhcpd: DHCPINFORM from 192.168.1.101 via xl0
                                            Jul 15 07:46:23 pfSense dhcpd: DHCPACK to 192.168.1.101 (00:24:8c:bf:05:9c) via xl0
                                            Jul 15 07:55:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 07:55:53 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 08:06:36 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 08:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 08:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 08:19:08 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 15 08:19:08 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 15 08:46:17 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 08:46:17 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 08:55:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 08:55:53 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 09:06:35 pfSense dhcpd: Information-request message from fe80::34a9:c82a:594b:cd66 port 546, transaction ID 0xE8705100
                                            Jul 15 09:06:35 pfSense dhcpd: Sending Reply to fe80::34a9:c82a:594b:cd66 port 546
                                            Jul 15 09:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 09:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 09:46:17 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 09:46:17 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 09:46:17 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 09:55:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 09:55:53 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 10:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 10:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 10:17:09 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 15 10:17:09 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 15 10:46:17 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 10:46:17 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 10:55:53 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 10:55:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 10:55:53 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 11:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 11:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 11:36:10 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 15 11:36:10 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 15 11:46:18 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 11:46:18 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 11:55:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 11:55:53 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 12:06:36 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 12:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 12:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 12:46:18 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 12:46:18 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 12:55:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 12:55:53 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 13:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 13:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 13:34:11 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 15 13:34:11 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 15 13:46:18 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 13:46:18 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 13:46:18 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 13:55:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 13:55:53 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 14:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 14:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 14:39:53 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 15 14:39:53 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 15 14:46:18 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 14:46:18 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 14:55:53 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 14:55:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 14:55:53 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 15:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 15:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 15:46:19 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 15:46:19 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 15:55:13 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 15 15:55:13 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 15 15:55:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 15:55:53 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 16:06:36 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 16:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 16:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 16:07:57 pfSense dhcpd: DHCPINFORM from 192.168.1.101 via xl0
                                            Jul 15 16:07:57 pfSense dhcpd: DHCPACK to 192.168.1.101 (00:24:8c:bf:05:9c) via xl0
                                            Jul 15 16:09:43 pfSense dhcpd: DHCPINFORM from 192.168.1.101 via xl0
                                            Jul 15 16:09:43 pfSense dhcpd: DHCPACK to 192.168.1.101 (00:24:8c:bf:05:9c) via xl0
                                            Jul 15 16:46:19 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 16:46:19 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 16:55:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 16:55:53 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 17:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 17:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 17:46:19 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 17:46:19 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 17:46:19 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 17:52:15 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 15 17:52:15 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 15 17:55:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 17:55:53 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 18:06:36 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 18:06:36 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 18:46:20 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 18:46:20 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 18:46:20 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 18:55:52 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 18:55:52 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 15 19:06:16 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 15 19:06:16 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 15 19:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 19:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 19:46:20 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 19:46:20 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 20:06:35 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 20:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 20:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 20:46:20 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 20:46:20 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 21:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 21:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 21:46:20 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 21:46:20 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 21:46:20 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 22:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 22:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 22:46:20 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 22:46:20 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 15 23:06:35 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 15 23:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 15 23:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 00:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 00:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 00:46:20 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 01:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 01:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 02:06:35 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 02:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 02:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 02:11:52 pfSense dhcpd: DHCPDISCOVER from 00:22:15:ca:99:e0 via xl0
                                            Jul 16 02:11:53 pfSense dhcpd: unexpected ICMP Echo Reply from 24.13.16.1
                                            Jul 16 02:11:53 pfSense dhcpd: DHCPOFFER on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 02:11:53 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 (192.168.1.1) from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 02:11:53 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 02:13:01 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 16 02:13:01 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 16 03:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 03:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 04:06:35 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 04:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 04:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 05:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 05:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 06:06:35 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 06:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 06:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 06:18:49 pfSense dhcpd: DHCPDISCOVER from 00:24:8c:bf:05:9c via xl0
                                            Jul 16 06:18:49 pfSense dhcpd: unexpected ICMP Echo Reply from 24.13.16.1
                                            Jul 16 06:18:50 pfSense dhcpd: DHCPOFFER on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 06:18:50 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 (192.168.1.1) from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 06:18:50 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 06:18:55 pfSense dhcpd: DHCPINFORM from 192.168.1.101 via xl0
                                            Jul 16 06:18:55 pfSense dhcpd: DHCPACK to 192.168.1.101 (00:24:8c:bf:05:9c) via xl0
                                            Jul 16 07:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 07:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 07:11:06 pfSense dhcpd: DHCPDISCOVER from 00:22:15:ca:99:e0 via xl0
                                            Jul 16 07:11:07 pfSense dhcpd: unexpected ICMP Echo Reply from 24.13.16.1
                                            Jul 16 07:11:07 pfSense dhcpd: DHCPOFFER on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 07:11:07 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 07:11:07 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 (192.168.1.1) from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 07:11:07 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 07:12:19 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 16 07:12:19 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 16 07:18:50 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 07:18:50 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 08:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 08:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 08:11:07 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 08:11:07 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 08:18:50 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 08:18:50 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 08:18:50 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 08:19:20 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 16 08:19:20 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 16 09:06:35 pfSense dhcpd: Information-request message from fe80::34a9:c82a:594b:cd66 port 546, transaction ID 0x84043200
                                            Jul 16 09:06:35 pfSense dhcpd: Sending Reply to fe80::34a9:c82a:594b:cd66 port 546
                                            Jul 16 09:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 09:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 09:11:07 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 09:11:07 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 09:18:50 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 09:18:50 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 09:28:17 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 16 09:28:17 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 16 10:06:35 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 10:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 10:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 10:11:07 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 10:11:07 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 10:18:50 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 10:18:50 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 10:57:22 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 16 10:57:22 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 16 11:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 11:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 11:11:08 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 11:11:08 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 11:11:08 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 11:18:50 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 11:18:50 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 12:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 12:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 12:11:08 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 12:11:08 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 12:18:50 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 12:18:50 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 12:18:50 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 12:36:23 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 16 12:36:23 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 16 13:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 13:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 13:11:08 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 13:11:08 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 13:18:51 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 13:18:51 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 13:18:51 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 14:06:35 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 14:06:35 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 14:11:08 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 14:11:08 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 14:18:51 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 14:18:51 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 14:25:24 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 16 14:25:24 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 16 14:51:31 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 14:51:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 14:51:31 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 14:51:31 pfSense dhcpd: Information-request message from fe80::34a9:c82a:594b:cd66 port 546, transaction ID 0x809C8F00
                                            Jul 16 14:51:31 pfSense dhcpd: Sending Reply to fe80::34a9:c82a:594b:cd66 port 546
                                            Jul 16 15:11:08 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 15:11:08 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 15:18:51 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 15:18:51 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 15:33:18 pfSense dhclient: RENEW
                                            Jul 16 15:33:19 pfSense dhclient: Creating resolv.conf
                                            Jul 16 15:51:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 15:51:31 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 16:07:57 pfSense dhcpd: DHCPINFORM from 192.168.1.101 via xl0
                                            Jul 16 16:07:57 pfSense dhcpd: DHCPACK to 192.168.1.101 (00:24:8c:bf:05:9c) via xl0
                                            Jul 16 16:11:08 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 16:11:08 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 16:11:08 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 16:18:50 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 16:18:50 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 16:23:25 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 16 16:23:25 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 16 16:51:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 16:51:31 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 17:11:08 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 17:11:08 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 17:18:50 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 17:18:50 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 17:18:50 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 17:46:27 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 16 17:46:27 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 16 17:51:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 17:51:31 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 18:11:08 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 18:11:08 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 18:18:50 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 18:18:50 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 18:51:31 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 18:51:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 18:51:31 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 19:01:28 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 16 19:01:28 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 16 19:11:08 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 19:11:08 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 19:18:51 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 19:18:51 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 19:51:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 19:51:31 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 20:11:08 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 20:11:08 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 20:11:08 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 20:18:51 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 20:18:51 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 20:51:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 20:51:31 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 20:55:29 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 16 20:55:29 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 16 21:11:08 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 21:11:08 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 16 21:18:51 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 16 21:18:51 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 21:18:51 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 21:51:31 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 21:51:31 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 16 22:18:51 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 22:18:51 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 16 23:11:08 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 17 00:18:51 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 17 04:14:46 pfSense dhcpd: DHCPDISCOVER from f4:6d:04:f0:32:43 via xl0
                                            Jul 17 04:14:46 pfSense dhcpd: Information-request message from fe80::34a9:c82a:594b:cd66 port 546, transaction ID 0x97859200
                                            Jul 17 04:14:46 pfSense dhcpd: Sending Reply to fe80::34a9:c82a:594b:cd66 port 546
                                            Jul 17 04:14:46 pfSense dhcpd: unexpected ICMP Echo Reply from 24.13.16.1
                                            Jul 17 04:14:47 pfSense dhcpd: DHCPOFFER on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 17 04:14:47 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 17 04:14:47 pfSense dhcpd: DHCPREQUEST for 192.168.1.100 (192.168.1.1) from f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 17 04:14:47 pfSense dhcpd: DHCPACK on 192.168.1.100 to f4:6d:04:f0:32:43 (BRIAN-DESKTOP) via xl0
                                            Jul 17 06:14:47 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 17 06:49:31 pfSense dhcpd: DHCPDISCOVER from 00:24:8c:bf:05:9c via xl0
                                            Jul 17 06:49:31 pfSense dhcpd: unexpected ICMP Echo Reply from 24.13.16.1
                                            Jul 17 06:49:32 pfSense dhcpd: DHCPOFFER on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 17 06:49:32 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 (192.168.1.1) from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 17 06:49:32 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 17 06:49:38 pfSense dhcpd: DHCPINFORM from 192.168.1.101 via xl0
                                            Jul 17 06:49:38 pfSense dhcpd: DHCPACK to 192.168.1.101 (00:24:8c:bf:05:9c) via xl0
                                            Jul 17 07:24:07 pfSense dhcpd: DHCPDISCOVER from 00:22:15:ca:99:e0 via xl0
                                            Jul 17 07:24:07 pfSense dhcpd: unexpected ICMP Echo Reply from 24.13.16.1
                                            Jul 17 07:24:08 pfSense dhcpd: DHCPOFFER on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 17 07:24:08 pfSense dhcpd: Wrote 3 leases to leases file.
                                            Jul 17 07:24:08 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 (192.168.1.1) from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 17 07:24:08 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 17 07:26:17 pfSense dhcpd: DHCPINFORM from 192.168.1.105 via xl0
                                            Jul 17 07:26:17 pfSense dhcpd: DHCPACK to 192.168.1.105 (00:22:15:ca:99:e0) via xl0
                                            Jul 17 07:49:32 pfSense dhcpd: DHCPREQUEST for 192.168.1.101 from 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 17 07:49:32 pfSense dhcpd: DHCPACK on 192.168.1.101 to 00:24:8c:bf:05:9c (RUTH-DESKTOP) via xl0
                                            Jul 17 08:24:08 pfSense dhcpd: DHCPREQUEST for 192.168.1.105 from 00:22:15:ca:99:e0 (william-desktop) via xl0
                                            Jul 17 08:24:08 pfSense dhcpd: DHCPACK on 192.168.1.105 to 00:22:15:ca:99:
                                          – Brian Plencner
                                          E-Mail: CoasterBrian72Cancer@gmail.com
                                          Note: Kill Cancer to Reply via e-mail
                                          • E Offline
                                            eri--
                                            I think you should open another thread for this since my feeling is not related to the above issue.
                                            Also the log you posted is about dhcpd and not in any scope to this thread.
