    IPv6 DHCP-PD – radvd dies after interface reset - dhcpv6 does not reaquire addr
    166 Posts 21 Posters 75.8k Views
    • B
      BrianPlencner
      Back on May 9th, I did a clean install of this version
      2.1-BETA1 (i386)
      built on Thu May 9 07:05:02 EDT 2013
      FreeBSD 8.3-RELEASE-p8
      I was able to have IPv6 work for around 4 days before the lease from Comcast's DHCP servers renewed.
      After that point, I was not able to get IPv6 working again.
      What's interesting is if I do a full clean install, I still cannot get it to work. Its almost like something is left behind in some configuration somewhere that a full install does not remove.
      I am looking to download and install the latest beta build, but wondering if the problem has been fixed yet.  So, if someone has installed a newer build with some success, please pass that on.
      –Brian
      – Brian Plencner
      E-Mail: CoasterBrian72Cancer@gmail.com
      Note: Kill Cancer to Reply via e-mail
      • R
        razzfazz
        See my 6/10 post; I've had IPv6 connectivity on Comcast for more than four days straight with the June 4 snapshot. Haven't stayed on any one revision for long enough since.
        • P
          priller
          @razzfazz:
          If you would like to do an experiment ….  reboot pfSense and see if it gets IPv6 addressing again.
          If I build a fresh install, it works exactly once.  If I reboot, it will not pull addressing again.
          • R
            razzfazz
            Done. Seems to get both a WAN and a LAN address just fine. (Ditto after firmware updates.)
            • N
              netkeys
              I installed the built on Wed Jun 12 17:13:09 EDT 2013 update and it seems to be working so far.
              • E
                eri--
                Can anybody confirm that when a renewal is not done either 2 dhcp6c processes are running or there is no default gw for v6?
                • B
                  BrianPlencner
                  I've seen a few posts here in the last few days that give the impression that builds after 06/10 appear to fix the issues at hand.
                  Before I go and download the latest beta build, I would like a bit more feedback from those that have, and if they got IPv6 working or not.
                  A few people here, and also on the Comcast forum over at Broadbandreports.com have suggested moving to m0n0wall.  I really don't want to do that as I am very happy with pfSense.  I would rather stay with that product, as it does everything that I need it to do.
                  Thanks!
                  –Brian
                  – Brian Plencner
                  • P
                    priller
                    @ermal:
                    I'm currently on the following and will let it run its normal renewal course and report back.
                    2.1-RC0 (amd64)
                    built on Wed Jun 12 18:24:34 EDT 2013
                    Uptime: 1 Day 02 Hours 35 Minutes 25 Seconds
                    In a previous post, I mentioned that I was able to get IPV6 addressing once and then after a reboot, it was unable to get anything.  Always with the following logging:
                    dhcp6c[68545]: dhcp6_ctl_authinit: failed to open /usr/local/etc/dhcp6cctlkey: No such file or directory
                    dhcp6c[68545]: client6_init: failed initialize control message authentication
                    dhcp6c[68545]: client6_init: skip opening control port
                    … with the current build I'm running, I rebooted twice and it was ok.  So, stay tuned ...
                    • dotOneD
                      dotOne
                      Today I tried to do some debugging.
                      What I found is that the DHCP process itself looks ok and also the PD is working.
                      But during the process the route command isn't found
                      During renewal an XID mismatch is generated.
                      [2.1-RC0][xxxx]/var/run(66): /usr/local/sbin/dhcp6c -d -D -f -c /var/etc/dhcp6c_wan.conf -p /var/run/dhcp6c_pppoe0.pid pppoe0
                      Jun/16/2013 17:18:15: get_duid: extracted an existing DUID from /var/db/dhcp6c_duid: 00:01:00:01:19:50:8e:29:48:5d:60:cb:50:36
                      Jun/16/2013 17:18:15: dhcp6_ctl_authinit: failed to open /usr/local/etc/dhcp6cctlkey: No such file or directory
                      Jun/16/2013 17:18:15: client6_init: failed initialize control message authentication
                      Jun/16/2013 17:18:15: client6_init: skip opening control port
                      Jun/16/2013 17:18:15: cfdebug_print: <3>[interface] (9)
                      Jun/16/2013 17:18:15: cfdebug_print: <5>[pppoe0] (6)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>begin of closure [{] (1)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>[send] (4)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>[ia-na] (5)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>[0] (1)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>end of sentence [;] (1)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>comment [# request stateful address] (26)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>[ia-pd] (5)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>comment [# request prefix delegation] (27)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>[request] (7)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>[domain-name-servers] (19)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>[domain-name] (11)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>[script] (6)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>["/var/etc/dhcp6c_wan_script.sh"] (31)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>comment [# we'd like some nameservers please] (35)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>end of closure [}] (1)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>[id-assoc] (8)
                      Jun/16/2013 17:18:15: cfdebug_print: <13>[na] (2)
                      Jun/16/2013 17:18:15: cfdebug_print: <13>[0] (1)
                      Jun/16/2013 17:18:15: cfdebug_print: <13>begin of closure [{] (1)
                      Jun/16/2013 17:18:15: cfdebug_print: <13>[pd] (2)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>[prefix-interface] (16)
                      Jun/16/2013 17:18:15: cfdebug_print: <5>[bridge0] (7)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>[sla-id] (6)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>[32] (2)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>[sla-len] (7)
                      Jun/16/2013 17:18:15: cfdebug_print: <3>[16] (2)
                      Jun/16/2013 17:18:15: configure_pool: called
                      Jun/16/2013 17:18:15: clear_poolconf: called
                      Jun/16/2013 17:18:15: dhcp6_reset_timer: reset a timer on pppoe0, state=INIT, timeo=0, retrans=383
                      Jun/16/2013 17:18:16: client6_send: a new XID (37f7f7) is generated
                      Jun/16/2013 17:18:16: copy_option: set client ID (len 14)
                      Jun/16/2013 17:18:16: copyout_option: set identity association
                      Jun/16/2013 17:18:16: copy_option: set elapsed time (len 2)
                      Jun/16/2013 17:18:16: copy_option: set option request (len 4)
                      Jun/16/2013 17:18:16: copyout_option: set IA_PD
                      Jun/16/2013 17:18:16: client6_send: send solicit to ff02::1:2%pppoe0
                      Jun/16/2013 17:18:16: dhcp6_reset_timer: reset a timer on pppoe0, state=SOLICIT, timeo=0, retrans=1088
                      Jun/16/2013 17:18:16: client6_recv: receive advertise from fe80::2a0:a50f:fc78:5530%pppoe0 on pppoe0
                      Jun/16/2013 17:18:16: dhcp6_get_options: get DHCP option client ID, len 14
                      Jun/16/2013 17:18:16:  DUID: 00:01:00:01:19:50:8e:29:48:5d:60:cb:50:36
                      Jun/16/2013 17:18:16: dhcp6_get_options: get DHCP option server ID, len 26
                      Jun/16/2013 17:18:16:  DUID: 00:02:00:00:05:83:4a:4e:31:31:45:41:33:30:42:41:46:41:00:00:00:00:00:00:00:00
                      Jun/16/2013 17:18:16: dhcp6_get_options: get DHCP option IA_PD, len 41
                      Jun/16/2013 17:18:16:  IA_PD: ID=0, T1=3600, T2=5760
                      Jun/16/2013 17:18:16: copyin_option: get DHCP option IA_PD prefix, len 25
                      Jun/16/2013 17:18:16: copyin_option:  IA_PD prefix: 2001:980:93ab::/48 pltime=7200 vltime=7200
                      Jun/16/2013 17:18:16: dhcp6_get_options: get DHCP option identity association, len 18
                      Jun/16/2013 17:18:16:  IA_NA: ID=0, T1=0, T2=0
                      Jun/16/2013 17:18:16: copyin_option: get DHCP option status code, len 2
                      Jun/16/2013 17:18:16:  status code: no addresses
                      Jun/16/2013 17:18:16: dhcp6_get_options: get DHCP option DNS, len 32
                      Jun/16/2013 17:18:16: client6_recvadvert: server ID: 00:02:00:00:05:83:4a:4e:31:31:45:41:33:30:42:41:46:41:00:00:00:00:00:00:00:00, pref=-1
                      Jun/16/2013 17:18:16: client6_recvadvert: reset timer for pppoe0 to 0.771510
                      Jun/16/2013 17:18:17: select_server: picked a server (ID: 00:02:00:00:05:83:4a:4e:31:31:45:41:33:30:42:41:46:41:00:00:00:00:00:00:00:00)
                      Jun/16/2013 17:18:17: client6_send: a new XID (982ee) is generated
                      Jun/16/2013 17:18:17: copy_option: set client ID (len 14)
                      Jun/16/2013 17:18:17: copy_option: set server ID (len 26)
                      Jun/16/2013 17:18:17: copyout_option: set status code
                      Jun/16/2013 17:18:17: copyout_option: set identity association
                      Jun/16/2013 17:18:17: copy_option: set elapsed time (len 2)
                      Jun/16/2013 17:18:17: copy_option: set option request (len 4)
                      Jun/16/2013 17:18:17: copyout_option: set IA_PD prefix
                      Jun/16/2013 17:18:17: client6_send: send request to ff02::1:2%pppoe0
                      Jun/16/2013 17:18:17: dhcp6_reset_timer: reset a timer on pppoe0, state=REQUEST, timeo=0, retrans=977
                      Jun/16/2013 17:18:17: client6_recv: receive reply from fe80::2a0:a50f:fc78:5530%pppoe0 on pppoe0
                      Jun/16/2013 17:18:17: dhcp6_get_options: get DHCP option client ID, len 14
                      Jun/16/2013 17:18:17:  DUID: 00:01:00:01:19:50:8e:29:48:5d:60:cb:50:36
                      Jun/16/2013 17:18:17: dhcp6_get_options: get DHCP option server ID, len 26
                      Jun/16/2013 17:18:17:  DUID: 00:02:00:00:05:83:4a:4e:31:31:45:41:33:30:42:41:46:41:00:00:00:00:00:00:00:00
                      Jun/16/2013 17:18:17: dhcp6_get_options: get DHCP option IA_PD, len 41
                      Jun/16/2013 17:18:17:  IA_PD: ID=0, T1=3600, T2=5760
                      Jun/16/2013 17:18:17: copyin_option: get DHCP option IA_PD prefix, len 25
                      Jun/16/2013 17:18:17: copyin_option:  IA_PD prefix: 2001:980:93ab::/48 pltime=7200 vltime=7200
                      Jun/16/2013 17:18:17: dhcp6_get_options: get DHCP option identity association, len 18
                      Jun/16/2013 17:18:17:  IA_NA: ID=0, T1=0, T2=0
                      Jun/16/2013 17:18:17: copyin_option: get DHCP option status code, len 2
                      Jun/16/2013 17:18:17:  status code: no addresses
                      Jun/16/2013 17:18:17: dhcp6_get_options: get DHCP option DNS, len 32
                      Jun/16/2013 17:18:17: info_printf: nameserver[0] 2001:888:0:6::66
                      Jun/16/2013 17:18:17: info_printf: nameserver[1] 2001:888:0:9::99
                      Jun/16/2013 17:18:17: get_ia: make an IA: PD-0
                      Jun/16/2013 17:18:17: update_prefix: create a prefix 2001:980:93ab::/48 pltime=7200, vltime=7200
                      Jun/16/2013 17:18:17: ifaddrconf: add an address 2001:980:93ab:20:fe:4aff:fec8:9c00/64 on bridge0
                      Jun/16/2013 17:18:17: get_ia: make an IA: NA-0
                      Jun/16/2013 17:18:17: update_ia: status code for NA-0: no addresses
                      Jun/16/2013 17:18:17: update_ia: IA NA-0 is invalidated
                      Jun/16/2013 17:18:17: remove_ia: remove an IA: NA-0
                      Jun/16/2013 17:18:17: dhcp6_reset_timer: reset a timer on pppoe0, state=INIT, timeo=0, retrans=915
                      Jun/16/2013 17:18:17: client6_recvreply: executes /var/etc/dhcp6c_wan_script.sh
                      route: not found
                      route: not found
                      Jun/16/2013 17:18:24: client6_script: script "/var/etc/dhcp6c_wan_script.sh" terminated
                      Jun/16/2013 17:18:24: dhcp6_remove_event: removing an event on pppoe0, state=REQUEST
                      Jun/16/2013 17:18:24: dhcp6_remove_event: removing server (ID: 00:02:00:00:05:83:4a:4e:31:31:45:41:33:30:42:41:46:41:00:00:00:00:00:00:00:00)
                      Jun/16/2013 17:18:24: client6_recvreply: got an expected reply, sleeping.
                      Jun/16/2013 17:18:24: client6_send: a new XID (e4dbbb) is generated
                      Jun/16/2013 17:18:24: copy_option: set client ID (len 14)
                      Jun/16/2013 17:18:24: copyout_option: set identity association
                      Jun/16/2013 17:18:24: copy_option: set elapsed time (len 2)
                      Jun/16/2013 17:18:24: copy_option: set option request (len 4)
                      Jun/16/2013 17:18:24: client6_send: send solicit to ff02::1:2%pppoe0
                      Jun/16/2013 17:18:24: dhcp6_reset_timer: reset a timer on pppoe0, state=SOLICIT, timeo=0, retrans=1079
                      Jun/16/2013 17:18:25: copy_option: set client ID (len 14)
                      Jun/16/2013 17:18:25: copyout_option: set identity association
                      Jun/16/2013 17:18:25: copy_option: set elapsed time (len 2)
                      Jun/16/2013 17:18:25: copy_option: set option request (len 4)
                      Jun/16/2013 17:18:25: client6_send: send solicit to ff02::1:2%pppoe0
                      Jun/16/2013 17:18:25: dhcp6_reset_timer: reset a timer on pppoe0, state=SOLICIT, timeo=1, retrans=2086
                      Jun/16/2013 17:18:27: copy_option: set client ID (len 14)
                      Jun/16/2013 17:18:27: copyout_option: set identity association
                      Jun/16/2013 17:18:27: copy_option: set elapsed time (len 2)
                      Jun/16/2013 17:18:27: copy_option: set option request (len 4)
                      Jun/16/2013 17:18:27: client6_send: send solicit to ff02::1:2%pppoe0
                      Jun/16/2013 17:18:27: dhcp6_reset_timer: reset a timer on pppoe0, state=SOLICIT, timeo=2, retrans=4252
                      Jun/16/2013 17:18:31: copy_option: set client ID (len 14)
                      Jun/16/2013 17:18:31: copyout_option: set identity association
                      Jun/16/2013 17:18:31: copy_option: set elapsed time (len 2)
                      Jun/16/2013 17:18:31: copy_option: set option request (len 4)
                      Jun/16/2013 17:18:31: client6_send: send solicit to ff02::1:2%pppoe0
                      Jun/16/2013 17:18:31: dhcp6_reset_timer: reset a timer on pppoe0, state=SOLICIT, timeo=3, retrans=8287
                      Jun/16/2013 17:18:40: copy_option: set client ID (len 14)
                      Jun/16/2013 17:18:40: copyout_option: set identity association
                      Jun/16/2013 17:18:40: copy_option: set elapsed time (len 2)
                      Jun/16/2013 17:18:40: copy_option: set option request (len 4)
                      Jun/16/2013 17:18:40: client6_send: send solicit to ff02::1:2%pppoe0
                      Jun/16/2013 17:18:40: dhcp6_reset_timer: reset a timer on pppoe0, state=SOLICIT, timeo=4, retrans=16283
                      • P
                        priller
                        @ermal:
                        At the time the 4 day lease expired, all IPv6 addressing went away.
                        There is no dhcp6c process running:
                        $ ps -aux | grep dhcp6c
                        root   56506  0.0  0.0  9068  1512  ??  S    12:14PM   0:00.00 grep dhcp6c
                        Jun 17 05:58:32 	dhcp6c[34138]: client6_timo: all information to be updated was canceled
                        Jun 17 05:55:08 	dhcp6c[34138]: client6_timo: all information to be updated was canceled
                        radvd is no longer running:
                        Jun 13 05:50:51 	radvd[41186]: removing /var/run/radvd.pid
                        Jun 13 05:50:51 	radvd[41186]: sending stop adverts
                        Jun 13 05:50:51 	radvd[41186]: Exiting, sigterm or sigint received.
                        Jun 13 05:50:30 	radvd[40640]: IPv6 forwarding seems to be disabled, but continuing anyway.
                        Jun 13 05:50:30 	radvd[40640]: IPv6 forwarding setting is: 0, should be 1
                        Jun 13 05:50:30 	radvd[40640]: version 1.9.1 started
                        Jun 13 05:42:24 	radvd[53132]: resuming normal operation
                        Jun 13 05:42:24 	radvd[53132]: attempting to reread config file
                        Jun 13 05:42:05 	radvd[50732]: IPv6 forwarding seems to be disabled, but continuing anyway.
                        Jun 13 05:42:05 	radvd[50732]: IPv6 forwarding setting is: 0, should be 1
                        Jun 13 05:42:05 	radvd[50732]: version 1.9.1 started
                        Jun 13 05:34:06 	radvd[52561]: resuming normal operation
                        Jun 13 05:34:06 	radvd[52561]: attempting to reread config file
                        Jun 13 05:33:47 	radvd[52249]: IPv6 forwarding seems to be disabled, but continuing anyway.
                        Jun 13 05:33:47 	radvd[52249]: IPv6 forwarding setting is: 0, should be 1
                        Jun 13 05:33:47 	radvd[52249]: version 1.9.1 started
                        Gateway is there (same as when it was working):
                        Internet6:
                        Destination                       Gateway                       Flags      Netif Expire
                        default                           fe80::201:5cff:fe24:9301%em1  UG          em1
                        ::1                               ::1                           UH          lo0
                        fe80::%em0/64                     link#1                        U           em0
                        fe80::1:1%em0                     link#1                        UHS         lo0
                        fe80::%em1/64                     link#2                        U           em1
                        fe80::230:18ff:fea5:bdb8%em1      link#2                        UHS         lo0
                        • N
                          netkeys
                          I haven't stayed on a version long enough to see what happens after 4 days.
                          But after every update I loose IPv6 connectivity.
                          I found that by going to "LAN interface" and disabling "IPv6" and clicking "save" then going to the "WAN interface" and disabling "IPv6" then clicking on Save then clicking "Apply changes" then turning "Ipv6" back on for the "WAN interface" as "DHCP6" and set "Prefix to 64" and clicking "save" then switching to the "LAN interface" and setting "IPv6 to Track Interface" and setting "interface to WAN" and clicking "save" then hitting "Apply changes" I can get IPv6 back without rebooting.  It's worked ever time since last Wednesday.  If I reboot then I loose connectivity and have to repeat the above procedure to get it back.
                          • johnpozJ
                            Ok just did that on version
                            2.1-RC0 (i386)
                            built on Wed Jun 19 06:11:14 EDT 2013
                            And no ipv6 – I will give it a bit, and then try to reboot..  But I had a ipv6 while I was away for work..  Figured sweet, but when I got back looking today no ipv6..  So tried updating to the above, as of yet have not been able to get a ipv6
                            Just going to have to go back to a tunnel from HE..  Since this is clearly NOT ready for primetime, I would just use m0n0wall but no openvpn support is not there..
                            Can we please work on getting stable ipv6 where it comes up on its own and best yet maintain the IP range..
                            SG-4860 24.11 | Lab VMs 2.7.2, 24.11
                            • P
                              priller
                              The problem has gotten progressively worse.  If it helps at all ….
                              Prior to the May 9 build, at least you were able to get IPv6 addressing.  It would disappear when the lease expired (RENEW problem on bug #2919), but you could reboot and be back in service.
                              Now, I can't get it to renew by rebooting .. as johnpoz noted.  I have to build fresh to get IPv6 working again.
                              At this point, I need to move on until this gets resolved.
                              • johnpozJ
                                I have just moved back to HE tunnel – this is just not working out..
                                Guess will try the native stuff again when 2.1 is final with a new clean build, etc.  But for now I have also just moved on and went back to my stable HE tunnel..  Its got a bit of latency..  But it works!
                                C:\Windows\System32>ping ipv6.google.com
                                Pinging ipv6.l.google.com [2607:f8b0:4006:802::1012] with 32 bytes of data:
                                Reply from 2607:f8b0:4006:802::1012: time=60ms
                                Reply from 2607:f8b0:4006:802::1012: time=56ms
                                Reply from 2607:f8b0:4006:802::1012: time=58ms
                                Reply from 2607:f8b0:4006:802::1012: time=55ms
                                Ping statistics for 2607:f8b0:4006:802::1012:
                                    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
                                Approximate round trip times in milli-seconds:
                                    Minimum = 55ms, Maximum = 60ms, Average = 57ms
                                • N
                                  netkeys
                                  I just upgraded to the built on Fri Jun 21 15:17:41 EDT 2013 and for the first time it rebooted and IPv6 was working without any problems on Comcast.  I'll do some more testing in the morning.
                                  Seems to be heading in the right direction.
                                  • S
                                    shavenne
                                    I think I don't see anything in the git commits that is related to this problem, but I will upgrade and test it too.
                                    • N
                                      netkeys
                                      @netkeys:
                                      After future testing IPv6 kept connectivity after multiple reboots and after pulling plug on WAN 1 and letting router failover to backup U-Verse then returning to Wan1 Comcast connection.
                                      I haven't checked out get comments about changes but I haven't been able to get any of the previous versions to work after a reboot or failover test and the last 2 versions work as expected.
                                      I also installed the latest update built on Sat Jun 22 14:54:39 EDT 2013 and it came up after the reboots and after a failover test.
                                      I don't know if it will work for others but it's working well for me.
                                      • R
                                        razzfazz
                                        Comcast home, pfSense snapshot built on Sat Jun 15 05:06:50 EDT 2013, nanobsd if that makes a difference. After over 7 days of uptime I still have working IPv6 connectivity on both the WAN and the LAN side.
                                        • B
                                          BrianPlencner
                                          Well, looks like its time for me to download another build, and test things out for myself.
                                          I'm going to go with the one that user "razzfazz" used (pfSense snapshot built on Sat Jun 15 05:06:50 EDT 2013) and see how that works for me.
                                          EDIT: Well, looks like I cannot go back that far on the snapshot server.  btw, the link I'm using is
                                          http://snapshots.pfsense.org/FreeBSD_RELENG_8_3/i386/pfSense_RELENG_2_1/livecd_installer/?C=M;O=D
                                          user "netkeys" seems to have similar luck with pfsense snapshot built on Sat Jun 22 14:54:39 EDT 2013, so I will download that one, and do my testing with it.
                                          –Brian
                                          – Brian Plencner
                                          • Q
                                            qubit
                                            Yesterday I tried a clean install from June 22 with an imported 2.0.3 config. No packages, just some static DHCP leases and such. I have Comcast and set up DHCP6 appropriately. I'm able to get WAN and LAN IPv6 addresses and ping6 works from both pfsense itself and clients. Rebooted pfsense a few times and IPv6 started up fine. I had some issues in previous snapshots before where radvd would disappear but so far I haven't seen that, however the NTP service starts and immediately stops (core dump) and I have to select listen on WAN and start it a few times for it to come up.
                                            However once things settle down after boot my system log is flooded with the following:
                                            Jun 26 19:18:27 dhcp6c[29245]: client6_recvadvert: XID mismatch
                                            Jun 26 19:18:44 dhcp6c[29245]: client6_recvadvert: XID mismatch
                                            Jun 26 19:19:20 dhcp6c[29245]: client6_recvadvert: XID mismatch
                                            Jun 26 19:20:28 dhcp6c[29245]: client6_recvadvert: XID mismatch
                                            Jun 26 19:22:24 dhcp6c[29245]: client6_recvadvert: XID mismatch
                                            Jun 26 19:24:29 dhcp6c[29245]: client6_recvadvert: XID mismatch
                                            This just goes on about every two minutes or so. I should note that despite this I still have stable IPv6 during this time. I ran a packet capture (I don't have the saved one at the moment) and what seems to trigger this is the following:
                                            Every 2 minutes or so, pfsense on the WAN sends a DHCPv6 Solicit to ff02::1:2, and Comcast immediately replies back with two Advertise packets. The first one has all the details pfsense is currently using: a /128 for the WAN, a /64 prefix for the LAN and two IPv6 DNS servers. The second packet contains a completely different /128 and /64 and is from another DHCP server judging from the mac addresses. So apparently two different Comcast DHCPv6 servers are replying back, and since both have the generated XID from the solicit, dhcp6c doesn't like this and throws an error. This same sequence goes on and on.
                                            I'm not that familiar with IPv6 at the moment, but why is this happening? Why is pfsense sending out a solicit every 2+ minutes when it has stable IPv6 addressing? Is it some kind of keepalive? I'm assuming it went through the solicit-advertise-request-reply sequence upon boot because IPv6 is working fine. I'm just wondering if pfsense is supposed to be sending solicits every couple of minutes or if dhcpc6 just needs to ignore all other DHCPv6 packets once bound unless it's renewing after 4 days.
                                            Has anyone with working IPv6 on Comcast seen this on recent snapshots? Thanks.
