Problem with two lan networks and access to ap
I do not know if the question fits this forum
If not
Delete itUntil two days ago
I had pfsense 2.0.3
I have one wan connection
And two lan connections
Wired network 192.168.0.1
{Wireless network 192.168.2.1 connects to Router used as ap}from a Computer on the wired
I punch in the address of the ap
192.168.2.101
Address is outside the dhcpAnd reaches The router's management interface
I just upgraded the pfsense
from Version 2.0.3
To version 2.1Now for some reason it does not happen
I get an error {Attached Image}I do not have access to the management interface of the The router through the wired network
Have access only through a computer connected to the wireless
How can I fix it and return to the previous state
I also have access from the Wired network
I think its possible you may have DHCP running on the AP. If you do, need to turn that off.
OR
Its possible that "AP Isolation mode" is running on the AP.
If so, turn that off. -
The dhcp not working on the AP
I had access to everything was normal
After doing an upgrade from pfsense 2.0.3
To version 2.1 {I forgot to mention it in the first post and added it}now I do not have access to the AP
Are there rules on both interfaces to pass any from any for any protocol?
I do not know
When I plugged the ap it just workedI guess there was something automatically tuned
Maybe something deleted in upgrading
Check your firewall rules. Makes sure you have rules on each interface to pass/allow traffic.
The only thing I can think of
It is the first line of the wifi interface
I'm pretty sure it was like the first line of the lan interface
But I do not remember
Can you post Diagnostics > ARP Table?
Of course
In the first line where registered address 192.168.0.1
Registered home.plexIt should be listed also in the last line where the registered address 192.168.2.1
Not?
What is 192.168.2.8?
This laptop computer
Connected to the wireless networkWith it I check the wireless network is working
And have access to the management interface of the ap -
Well, I would suggest to flush the traffic shaping down the drain for starters. Took too long to respond sounds like you've shaped something to almost 0.
So, DHCP works on wireless?
DHCP works on wired LAN?
You can access the AP web interface on wireless?But not wired?
But internet works from either wired or wireless?
Is all that correct?
Is all that correct? – yes
what traffic shaping ?
All that "$foo computer is limited to $bar MB download" stuff.
Do not know if it is related to
Before I upgraded to 2.1Everything worked properly with all these laws
Furthermore there was no law on the computer from which I am trying to access the interface
I think doktornotor is right. Traffic seems to be working and allowed for the most part on both interfaces. All I can imagine is that your limiter is breaking the AP interface access.
Yeah, that may have well worked before but not after upgrade. (Also completely unclear what you've actually done there.) Simplify the configuration to barebones for troubleshooting!
And with that - I'll check back in after some sleep… Alot of it.
Thank you both for your help
I will try to suspend the rules, or remove them and see if i have access
